Question about HP LaserJet 2300d Printer
Feed switch switch seems loose on the cassette and not recognizing paper being loaded after i changed the pickup roller
  • jaslex May 18, 2011
    Thank u very much, that`s exactly what I ended up doing! Unfortunately, I ended up breaking the tab of the sensor that "seems" to secure it to the shaft. Tried looking into getting the sensor itself, but the only thing I could find is the entire feed assembly....and it doesn`t look like a fun job!!
  • HP Master
  • 1,915 Answers
When you changed the roller you knocked the sensor out of place. Normally when you change the roller you want to release the right side roller lock first so that you can retract it and it keeps everything in place. You will need to remove the roller and then move the sensor lever on the roller shaft until it is in the correct position and them reintall the roller. This is sometimes easier to do if you tilt the printer on it's back so you can see what you are doing. Remove the toner cartridge first.
Posted on May 17, 2011
How to replace pickup rollers
This should help. Good luck !
Cassette (Tray 2) paper pickup and feed rollers
To remove the paper pickup and feed rollers
1 Remove the cassette.
2 Locate the two rollers on the bottom of the paper pickup unit (above the cassette). The pickup
roller is the smaller roller, and the feed roller is the larger roller.
3 Pinch the tab on the end of the cassette pickup roller (callout 1), and pull the roller out.
4 Pinch the tab on the end of the cassette feed roller (callout 2), and pull the roller out.
Figure 6-24 Removing the cassette pickup and feed rollers
Note Always replace the cassette pickup roller and the cassette feed rollers at the same time. Also replace
the separation roller (located in the paper cassette) when replacing these rollers
Aug 14, 2014 | HP Color LaserJet 4600n Printer
I have a hp laserjet 4250 printer it had a paper jam in tray 2 i have cleared the jam but it keeps saying i still have the jam in tray 2
There is still paper stuck in the printer. try lifting the printer off of tray 2 to inspect it or here it is straight from the service manual...
Jams in tray 2
Table 7-10 Causes of tray 2 jams
Cause Solution
The feed or separation rollers are dirty, worn, or damaged. Clean the rollers. If they are dirty after cleaning, or if they are
worn or damaged, replace the rollers.
The pickup roller is worn or damaged. Replace the pickup roller.
The tray 2 paper pickup assembly drive gears are damaged
or the assembly is defective.
Check the drive gears in the paper pickup drive assembly.
Replace the pickup drive assembly if the gears are
damaged. See Paper-pickup drive assembly.
The tray 2 pickup solenoid (SL101) is damaged. 1 Disconnect the connector for the tray pickup solenoid
from the dc controller PCA (location J92).
2 Measure the resistance between the cable connectors.
3 If the measured resistance is not approximately
160 ohms for the HP LaserJet 4200/4300, or 110 ohms
for the HP LaserJet 4250/4350, replace the tray 2
pickup solenoid.
The tray 2 lifter-drive assembly or the stack position
sensor (PS107) is defective.
Replace the lifter-drive assembly. See Tray 2 lifter-drive
assembly and/or Printer switches and sensors.
The dc controller PCA is defective. Replace the dc controller PCA. See Dc controller PCA.
Dirty, worn, or deformed pick-up roller, cassette separation
roller, and cassette feed roller.
Clean the rollers if they are dirty. Replace any worn or
deformed rollers. The cassette separation roller and the
cassette feed rollare are to be replaced together.
Damaged gears in the cassette pick-up drive unit. Move the gears in the cassette pick up drive unit. If the
gears are not rotating correctly, or are damaged or worn,
replace the cassette pick-up drive unit.
Dec 25, 2010 | HP LaserJet 4250 Printer
I cannot get the paper to load into the printer
I had an issue with the cassette tray paper feed. I loaded paper in the rear tray, manually used the printer properties button to make it print from the rear tray and printed from there. The next day I manually did the same thing but forced it to print from the cassette (bottom) tray. It worked fine today. It no longer thinks that there is no paper and the rollers are picking up the paper edge for proper feeding of the paper. I did not go through the roller cleaning procedure but I would do that if switching back and forth manually between trays doesn't work.
Sep 20, 2010 | Canon MP560 All-In-One InkJet Printer
Printer does not attempt to pick up paper but gives out of paper message and or flashing paper sign on panel
steps:
(a) driving a pickup roller, picking up printing paper stacked in a paper cassette, and then, feeding the picked up printing paper to an image forming unit
(b) after picking up the printing paper in step (a), checking to determine whether or not the printing paper has been fed to the image forming unit(c) when it has been determined in step (b) that the printing paper has not been fed and a paper feed error has been generated, again driving the pickup roller, so as to attempt to pick up the printing paper stacked in the paper cassette again.
Apr 21, 2010 | HP Officejet Pro K5400 All-In-One InkJet...
"paper-feed error"
Had the same problem with mine, very intermittent. Remove all the paper and open the feed tray lid so you can get access to the three grey pinch rollers. Start printing then push on the roller with your finger to try and 'rough it up' (if it clicks you are pressing too hard).
The fault appears to be that the pinch rollers are loosing their grip and can not pull the glossy paper through. I dare say using a mild washing up liquid solution would be better but this is a safe quick fix.
Did this to mine and it has worked fine ever since.
Jun 24, 2009 | Canon Selphy CP510 Thermal Photo Printer
MFC-7420 "Change Drum Soon" I have had this message for a while. I purchased a new drum. In the meantime the printer continues to print fine, except we have paper feed problems. Is the drum related to...
the only time i've seen the drum affect paper feeding is if paper jams in the drum unit. i would use your current drum until print quality decreases to an unacceptable level. it will not shut down, and you will not see a "change drum message." if your paper feed problem is centered around the cassette/paper pickup area, you can try cleaning your rollers with water and a soft rag, and also make sure your rear paper stopper in cassette isn't pressing too tightly against the rear of paper stack. best to leave 1/8" gap, otherwise paper will not lift properly to the rollers.
hth,
razors
Apr 14, 2009 | Brother MFC 7420 All-In-One Laser Printer
Feed switch unresponsive
your case seems the cassette feed unit can not detected by cassette unit sensor which locate around the paper input roller area.you need to check
1) the cassette push in the well position which can touch the sensor well egnough
2) find out this sensor and adjust the sensor sdander position (more sensitive).
Feb 03, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP600 printer - paper feed
Issue: Paper feeds skewed
Solution: Clean The Paper Feed Rollers Using The Operation Panel - MP600
Clean The Paper Feed Rollers Using The Unit's Operation Panel If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit. Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary.
  1. Ensure that the machine is powered on and remove any paper from the auto sheet feeder or the cassette.
  2. Use the <Feed Switch> button to select the paper source where you do the paper feed roller cleaning. Click for here additional information.
  3. Press the <HOME> (A) button.
  4. Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Settings], then press the <OK> button.
  5. Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Maintenance], then press <OK>.
  6. Use the Easy-Scroll Wheel (B) or press the up / down arrow to select [Roller cleaning], then press <OK>.
  7. Use the up / down cursor button to select [Yes], then press the <OK> button. (The paper feed roller cleaning starts.)
  8. To check if the rollers are clean, load a sheet of Letter-sized plain paper in the same paper source you selected in step 2.
  9. Use the Easy-Scroll Wheel (B) or press the up / down arrow to select [Roller cleaning], then press <OK>.
  10. Use the up / down cursor button to select [Yes], then press the <OK> button. (Paper will be fed.)
    Note: If paper is not fed properly, repeat steps 4 through 10 above up to three times.
Paper Source
Press the <Feed Switch> button to switch to toggle between the Automatic Sheet Feed (ASF) or Cassette. The light will come on when the <Feed Switch> is set for that paper source.
ASF
The above illustration shows a PIXMA MP500
Cassette
Note: When printing from the computer, if paper does not feed from the source you have selected on the operation panel, check Paper Source setting in the printer driver. If the option is not set to 'Paper Feed Switch', paper will feed from the source selected in the driver.
Click here to return to step 2
May 31, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Won't take paper
Clean The Paper Feed Rollers Using The Unit's Operation Panel If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit. Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary and no more than three (3) times.
  2. Use the <Feed Switch> button to select the paper source where you do the paper feed roller cleaning. Click for additional information.
  3. Press the <Menu> button.
  4. Use the right / left cursor button to select [Maintenance/settings] press the <OK> button.
    Note: This procedure is skipped if your machine is in Scan mode. Proceed to step 5.
  5. Use the right / left cursor button to select [Maintenance] and the press the <OK> button.
  6. Use the up / down cursor button to select [Roller cleaning] and press the <OK> button.
  8. To check if the rollers are clean, load a sheet of Letter-sized plain paper in the same paper source you selected in step 2, and press the <Open> button.
  9. Use the up / down cursor button to select [Roller cleaning] and press the <OK> button.
Paper Source
ASF
Cassette
Click to return to step 2 above.
Mar 30, 2008 | Canon Pixma MP500 All-In-One InkJet...
Paper "grabber" won't grab
Sounds very similar to my problem. In my case the Feed Switch ( Button on front console) got changed to load from the front tray, although paper was in back. I hit feed switch and changed to rear tray. Now it loaded and printed.
Feb 10, 2007 | Canon PIXMA MP780 All-In-One InkJet...
HP LaserJet 2300d Printer Logo
47 people viewed this question
Seeker5211
Seeker5211
