Dell 3100 cn prints only now and then. Error message 016799. Right now it won't print. Turning it off and restaring it sometimes works, but all the time. I want it to wor all the time.
  • 27,725 Answers
click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
?extend the events there you will ((see errors in red)) you will no what exactly what the error was and at what time it occured you might be able to uninstall then reinstall some of these files/software or only if you don't need to
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
hope this helps
Posted on May 17, 2011
I've been using a dell 3100 through a home network for several years. Suddenly I can't print. The network can't find the printer. I can print to it if I connect through USB. I have tried...
Hi
Please check the mention below option
1) First you get any error in your printer screen
2) If you are print through Network please ping your printer if you are not getting the print.
Open command prompt and type ping 192........your pinter ip, if you r getting reply to your printer
its mean your connect to printer.
3) Remove your printer driver and install again.
Jun 01, 2011 | Dell 3100cn Laser Printer
My Dell V305 printer will not print the whole page of an email. This is a document that I need the whole page.
You can get the half document when yhr printer runs out of memory ie too big a or too detailed a print job or if the document itself contains what the printer is seeing as control or commad characters and errors out. It can also be a port error.
Usually its just too detailed a print job. When you print click on the printing preferences and then look for either a DPI setting or a Quality setting. Turn any of those down and try printing. You may have to turn it down more than once to get it to behave. Most new printers can print at 2400 dpi. Unless you know what too look for you won;t be able to see much if any difference even down to about 300 dpi.
Sometimes you cn get port errors and those can be hardware or operating system caused. You can try another usb port. Also try rebooting and printing with nothing else running.
Aug 26, 2010 | Dell Office Equipment & Supplies
1/2" white line appearing down right side of page
Try replacing the toner cartridge. This seems to be a problem with the photo-sensitive drum, which is located in the cartridge.
Jan 05, 2010 | Dell 3100cn Laser Printer
Hello My printer(3100 cn dell) every time I
This means that loose toner powder has gotten in the way of the lazer "eye". If you open up the front door, you will see a blue tab toward the right, pull that toward you, then look on the right side of the printer, you will see that a door has opened. Pull that blue stick out as far as you can and you will see some toner powder on that, clear it off, and make sure the little pad is clean. After you have cleared the powder off, slide it back in and out a few times, this will clean the eye. Run another document through, if the line is still there, just clean another time. Should go away. I have this problem alot.
Aug 13, 2009 | Dell 3100cn Laser Printer
Dell 3100 CN Prints a stip on black all the way
There is a known issue for these printers to "streak." If under warranty, call Dell. If not, there is a fix
for the defective drum unit design but requires a little technical expertise.
The procedure is explained here:
http://www.ahfx.net/weblog/133
Jul 08, 2009 | Dell 3100cn Laser Printer
Dell 3100 CN replace drum cartridge
No. There is no reset as there is with some units. This unit actually knows via a smart chip in the drum unit if it has reached EOL ( end of life ).
Jun 19, 2008 | Dell 3000cn Color Laser Printer
Dell 3100cn printing horizontal stripes
Sounds like a bad imaging drum to me...
Aug 14, 2007 | Dell 3100cn Laser Printer
Linux printing with Dell 3100CN
OP provides the solution! (BTW, I'm able to print to this printer from MacOS too.)
May 01, 2007 | Dell 3100cn Laser Printer
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
