Question about Tunturi T30 Treadmill
I have a T30 that is a few years old but has not been used to much. It works fine then after a few minutes it stops and displays error code 1. Can I fix it or does it have to be a repair man?? Gary
I have a DV42H5400 dryer less than a year old that runs for a few seconds than stops. No error code but the cooling light flashes. After a few minutes it repeats the process.
Clothes Dryer Stops and Starts ' HomeTips
www.hometips.com/repair-fix/clothes-dryer-stops-and-starts.html
Apr 23, 2015 - The dryer's heating element works and the motor runs smoothly, But it... and then running the dryer with nothing inside for a few minutes-if it ...
Sep 26, 2015 | Dryers
Error code f 21, what does this mean?
The error code F-21 refers to Long Drain. The washer has sensed that it has not drained out completely and cannot go into further cycle.
If yours is a HE 2 washer, afer few minutes, Sd error will be displayed and then after couple of minutes F21 error code will appear. Water valves will be turned off and stops running.
If yours is a HE front load, when drain time exceeds 8 min, F21 error will be displayed. The water valves will be shut off and pump will stop running.
Generally, by re-storing the power to washer, it may fix the problem.
You may press the pause or the cancel button twice to clear the display.
You may have to double check the drain hose to see if there are any kink, clogs.
Also, you may unplug your washer, turn the circuit breaker off for 1-2 minutes and then plug it back in to check if it works. After this, check to see if the washer drains.
May 18, 2010 | Washing Machines
My 7 year old GE Profile Side by Side will not get
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display
can be illuminated by pressing an adjacent temperature adjustment button. When both displays are
illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all
4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and
freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button
will increment the numbers up and the WARMER temperature adjustment button will increment the
numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the
freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in
the refrigerator display. When a test code has been entered, the displays will flash to confirm the test.
Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will
increment the numbers down and the WARMER temperature adjustment button will increment the
numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the
freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test
code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. GSS manual
May 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My nokia 3110 handset is fails to play songs and ringtones.
dear sir i am using nokia 3110 from last 1 year,but now i am facing problem in it,it is getting automatically switchedoff after few minutes.
Jul 09, 2009 | Nokia 3110 Cellular Phone
Blinking display of advantium m/w oven
by unplugging the m/w for a few minutes and then replugging the problem is gone.
May 29, 2009 | GE Advantium SCA1001SS Convection /...
My washer will stop mid-cycle and flash error code F. the book says its an electrical problem.
Peace Friend,
ngfam1 At your service!
With an error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!
Aug 31, 2008 | Kenmore Elite 45986 Front Load Washer
How to stop the beeper and reset the "code' light on panel?
You have a shorted 2 pad on the keypad.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating a servicer or parts at 1-800-695-0098.
Aug 21, 2008 | Microwave Ovens
Error Code ER FF
FF is your freezer fan. You may need to defrost the unit.
Feb 28, 2017 | LG French Door Cabinet Depth Refrigerator...
Sreen says amp error
The audio Amplfier IC are damaged.
May 22, 2008 | Pioneer Audio Players & Recorders
Tunturi T30 Treadmill Logo
52 people viewed this question
Top Tunturi Exercise & Fitness Experts
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
