Question about Gibson GAC105P1A Thru-Wall/Window Air Conditioner
The AC works but the blower fan doesn't - Gibson GAC105P1A Thru-Wall/Window Air Conditioner
    Genius:
  • Gibson Master
  • 1,033 Answers
Hello, this could be a bad capacitor or the motor itself is bad. Try replacing the capacitor first.
Posted on May 17, 2011
  • ramcbayne Jun 01, 2011
    where is the capacitor located
  • Robert Jun 02, 2011
    It is located in tne control section of thw window unit, it looks like either a oval can or round can
Hi i have split and when started the air out hot but Compressor indcation show on
Posted on Jun 01, 2011
Kia Sorento blower fan will not turn off
Sounds like they jumpered a relay and did not put it back correctly.
Have you taken it back to the shop ?
Jul 04, 2013 | Kia Cars & Trucks
Ac/heater fan doesn't work
According to my wiring diagram, the blue and white wire from the blower motor gets power from the key switch. The fan switch and resistor grounds the motor.
No blower fuse is listed.
Feb 03, 2013 | 1988 Honda Accord 4 Door
A/C blower doesn't work
check fuses look for ones marked ac or fan replace any that are bad if not that the fan motor probably needs replaced
Nov 11, 2012 | 2006 Suzuki Grand Vitara
Blower fan on 06 Silverado doesn't work at any speed, fuse O.K.
check the blower relay if ok
check the blower moter for power and that it works
then the last check out the fan switch
Oct 31, 2012 | Chevrolet Cars & Trucks
My a/c (heater & Defrost) doesn't always work, could it be a fuse or the fan blower?
Check whether you might have bad connection or contact,or e ven bad switch.
Sep 03, 2012 | 2005 Kia Spectra
Ac fan doesn't blow hard enough 1985 300zx
If very little air comes from the vents, the fan on the blower motor may be damaged, or there may be a restriction in the vents, or a blend door may not be open completely.
Aug 23, 2012 | 1985 Nissan 300ZX
Fuirnace blower motor doesn't blow very hard and sound rough
Maybe if you put a drop of liquid soap on the shaft for the fan. Since it is a heater, I wouldn't use a lubricant like wd-40. GOOD LUCK. Soap is cheap. Hope it works.
Jul 02, 2012 | Rheem Gas Furnaces 125K BTU 80 AFUE Single...
Rear ac in chevy suburban doesn't work
check for power and ground to rear blower motor. if no power check for blown fuse. if no ground check for bad blower motor resistor for rear unit.
Jun 11, 2012 | 2004 Chevrolet Suburban
Heater blower not working
You call it the blower motor, I assume you mean the interior Heater/AC blower motor. When the motor acts as you have described it is usually a problem in the motor itself like a short or rectifier.
Nov 13, 2011 | Cars & Trucks
I turned on the ac and the light does not work, the vents are not blowing and the car is running hot. I have a saturn SL 1996
First check the 15 amp HVAC fuse located in the main fuse block inside the car on the passenger side of the center console, under a cover. If the fuse is good, then the problem may either be the HVAC blower switch (which is the fan blower selector switch), the fan blower motor resistor, or the fan blower motor. An auto repair manual will explain and illustrate for you the steps on how to check each of these components.
Even after pushing the ac light switch on, the fan blower selector switch has to be turned on as well (working) because it provides an electrical path to the positive side of the battery to complete the circuit and turn the ac light on. What the ac light switch does is provide the electrical path for the ac compressor clutch to come on through the ac control relay which is controlled by the car's PCM(computer) when you want ac, but the ac light switch still needs to run through the fan blower selector switch to receive its power. You can turn on the fan without the ac light switch because it gets its ground path(negative) from the blower motor. So the blower motor has to work in order to provide a ground path for the fan blower selector switch to be functional. You could have a faulty blower motor which is why no air blows through the vents. The fan blower motor is located inside the car on the passenger side underneath the dash at the bottom end of the glove compartment box. You'll see it. It's right above where a person rests their feet on the floor. Therefore, if your 15 amp HVAC fuse is good, check to see if you have voltage at the blower motor connector. Unclip the connector and with the ignition on and the fan blower switch moved to any one of the first 3 selections, check for voltage using a multimeter. The voltage will vary because there is a blower motor resistor. Voltage should be higher on setting 3 than 1. If you do have voltage at the blower motor connector, check for a faulty blower motor. The auto repair manual will tell you how to do it using jumper wires.
It's normal that your car is running hot because the radiator fan works in conjunction with your ac compressor. If the ac is on, the radiator fan will be on and therefore the engine coolant temperature will stay in it's normal operating range. If the ac is off, the radiator fan will stay off as well and the engine coolant temperature gauge will begin to rise and show pretty hot (especially at idle). It will do this up until a certain degree then the radiator fan should turn on thermostatically and stabilize the temperature. It's scary and I know what your saying because it does that to my car if my ac isn't on. Don't worry it won't overheat.
May 29, 2011 | 1996 Saturn SL
Gibson GAC105P1A Thru-Wall/Window Air Conditioner Logo
142 people viewed this question
Top Gibson Heating & Cooling Experts
john h
Are you a Gibson Heating and Cooling Expert? Answer questions, earn points and help others
