Question about Technical Pro TA-4250 Amplifier
I just bought Technical Pro TA 4250 amp, like 2 days use, had my music down to like 8% volume and i paused my music, came back and unpaused it heard this loud pop n grumble sound coming from my CV JE-36C sub, after a little smelled like something fried. a friend told me it was probably a fuse and I cant even find where the fuses are on this amp. Is this a blown fuse or what? and if so where are the fuses or redirect me to a manual cuz it didn't come with one. Bought brand new str8 from NYC, made sure none of the levels are maxed or anything, when I turn the amp on the blue LED lights up but it shows no detection that music is playing from the sub and the humming noise the sub usually puts out when it is connected to the amp is no longer heard FYI. Its being bridged on ground setting and I have RCA's connected to my bass slot on my sound card, just throwing that out there in case that helps.
2 Suggested Answers
Grubhead
  • 5113 Answers
SOURCE: Hi, I have an HB3502U
The most obvious cause is the failure of the large Electrolytic Capacitor(s) in the main power supply section. These take out the 50/60Hz hum in the mains supply, which is what that noise is!
Posted on Aug 21, 2011
How can I unlock my phone
- Unlock all Sony Xperia 2010 Year (under test, private only)
- Unlock all Sony Xperia 2011 Year( with Test Point) (under test, private only)
- Flash All Sony Xperia/ Sony Mobile Android based mobile phones
- First in the World: Read Trim Area from Running OS via ADB( Android Debug Brigde, ADB - included)
- First in the World: Write Trim Area from Running OS via ADB (Android Debug Bridge, ADB - included)*
- Trim Area Backup Read using ADB/BootLoader(for test or Security reason)*
- Trim Area Backup Write using ADB/Bootloader**
- Single Trim Area element Read/Write*
* Not all TA elements can be written or read and not all Platforms support it.
** Not all TA elements can be written or read.
!!!Software require Internet Connection for all operations!!!
download tool
http://www.mediafire.com/download.php?7gede2no6nsccvd
Usage:
!!!IMPORTANT!!! Before any operation with any new phone - Back it UP! Later
you can restore it if somethings gone wrong.
A) To read/write Trim Area
using ADB:
1. Connect your phone to PC using USB Cable.
2. Enable USB-Debugging in Settings->Development menu
3. Install drivers
4. Go to TA work tab, click ADB in the software and press Connect.
If you need to Cancel you can click cancel to stop operation
5. Wait software to check root in your phone and try to root it.
6. If your phone is not rooted you recieve a message how to root
your phone.
7. Click Backup TA. All your TA will be backed up and saved in new
folder, same as your imei number
8. If you need to restore phone - click Write TA from Backup
9. If you need to read/write single element: enter element number in
heximal (for example 7da) and press read/write
9a. Upon write operation you will be asked to open the file to
write, so please be ready for this file to open.
using BootLoader:
1. Training: Connect phone in Flash mode (Hold the back (or the
Volume down in new 2012+ phones)) key and connect the USB cable.
2. Install drivers (x64 or x86)
3. Check if driver install ok
4. Disconnect phone
5. Go to TA Work tab and click Bootloader
6. Click Connect button. If you need to cancel you can click cancel
to stop operation
7. Connect phone in Flash mode (Hold the back (or the Volume down in
8. After successfull connect Click Backup TA (for your security)
9. If you need to restore click Write TA from Backup
10. If you need to read/write single element: enter element number
in heximal (for example 7da) and press read/write
10a. Upon write operation you will be asked to open the file to
B) To flash a S1_Boot android phone
1. Go to Flasher tab
2. Follow the procedure 1 of the read/write TA using BootLoader
(Traning)
3. Click Open firmware (acceptable formats: zipped firmware bundle,
with loader.sin inside), file format - zip or 7z (7-zip)
4. Select files to flash(eg. 1 file or All files)
5. Connect phone in Flash mode (Hold the back (or the Volume down in
6. Install Drivers (x64 or x86 - according your system OS)
7. Stand by, software detect phone and send the loader.sin from the
archive
8. Click Flash when phone is connected and software hint says "You
can press the Flash button now"
8a. Keep in mind, the system.sin takes longer at 99%, this is ok,
need wait.
C) To unlock phone
without Test Point (2010 phones only):
2. Install Drivers (x64 or x86 - according your system OS)
4. Disconnect phone
5. Enter your user id and password
6. Click unlock
8. Follow the on screen instructions (some phones require one or two
reboot).
with Test Point:
4. Disconnect phone
5. Connect the Test Point.
7. Keep the Test Point connected
8. Click Unlock
9. Stand by.
9a. Longer in description faster in process about 20 seconds.
Apr 19, 2016 | Sony Ericsson XPERIA X10 Cell Phone
12" woofer not working
I bought a 3rd B212D unit that powers on, has white noise, no music. I took the 8 screws off and discovered that the solder connection at the woofer had broken off. I surmise that either the unit was dropped or the speaker wire had gotten hot over the years. Since the amp had an open output from the break, the high output burned up as I heard a pop when I turned the volume up. . If your volume wasn't maxed out, you could check the wiring and make sure it is connected & save yourself some change!!!
Jun 22, 2012 | Behringer B212D Powered Speaker (550...
Hi, I have an HB3502U Technical Pro Hybrid Amplifier/Receiver but no matter how I connect it there is aloud Humming noise. Can you help?
Aug 19, 2011 | Technical Pro TA-4250 Amplifier
I have a sony ta-fe370 amplifier. I bought it 5 years ago. 4 years ago it stopped working. I would now like to repair it. The problem is that it turns on and the power light comes on and so does the...
The problem is hard to track down, but fixable. You need to determine if the pre-amp has failed or the power amp. To determine which try this: Connect a device which plays music and turn the volume control fully up! You can sometimes hear the sound better via a pair of headphones. If you can hear any signal or music breaking through, then the pre-amp section is OK. If you can't it might not be. If you can hear faint music then it will be the main power amp to blame. Now because you have lost both channels you must only investigate devices (such as IC's) which have both channels running to them. Some amps have one big power amp IC that does the work. So if that goes it takes the sound with it. Have a look at whatever is on the big heat sink first, that will determine a lot of your future actions.
Jul 06, 2011 | Sony TA-FE370 2-Channel Amplifier
Can you connect subwolfer as well as speakers with this amp
Well, PASSIVE subwoofers ARE speakers. And this IS an amp. You could use it for a subwoofer (bridged) or two. It would also support a sub on one channel and a different speaker on the other. It's your choice what you want to drive with it.
I'd take that 4250 watts claim with a HUGE grain of salt as no distortion or bandwidth spec is included with it. If the lights in your neighborhood don't dim when you turn it on it's pulling WAY less than 4250 watts.
Jun 23, 2011 | Technical Pro TA-4250 Amplifier
Yahoo messenger music is paused
when i install yahoo messenger it was playing music very fine. I can't remember what I click and the music is paused. What can I do to unpaused the music?
May 10, 2010 | Yahoo Messenger
I need help finding the code for my tv. i have a Philmore universal remote pm-rc13. My t.v is a white-westinghouse
Here is the code for your TV 0154 along with the advanced codes.
Advanced Codes for TV_0154TVs ------------------ <TV Group>
0154 244 ACM 165 Fine Tune Up 251 SAP 167 Surround Mute
244 Auto Chroma 244 MTC 231 Speaker In 168 Surround Vol dwn
251 Bilngual 234 PIP Location 233 Speaker Out 164 Surround Vol up
169 Fine Tune Do 228 PIP Select 247 Stereo 129 Component 2 (discrete)
TELEVISION. Uses with:
TUNER/CD/TAPE/PHONO/AMP..CDs................AUX2 088
TELEVISION...............TVs..................TV 154
VCR......................VCRs................VCR 047
VCR......................VCRs................VCR 104
On some models,
100|AM/PM|1-- may be 100/Enter;
Func|Sel may be Digicon;
Level Up|R may be Control Right, Level Up/Minute or Menu Up;
Level Dn|L may be Control Left, Level Dn/Hour or Menu Down;
Review|Qck View may be CH Recall or Quick View;
SetTime Fast may be Stereo Matrix;
SetTime Slow may be Time/Day, Set Up, Clear or Menu;
TV/Video/AV may be TV/AV, Video Mode, Input or A/V;
Wide|TV|Loud may be Stereo Matrix, Surround or Mode;
MTC|OBC|Auto may be ACM or Auto Chroma.
181 0...............0 185 1...............1
120 ENTER...........1-- 120 ENTER...........100
183 2...............2 187 3...............3
180 4...............4 184 5...............5
182 6...............6 186 7...............7
053 8...............8 057 9...............9
185 1...............A 123 A/B.............A/V
120 ENTER...........AM/PM 059 CHANNEL DOWN....AM/PM
183 2...............B 187 3...............C
249 RECALL..........CH Recall 059 CHANNEL DOWN....Channel Down
055 CHANNEL UP......Channel Up 122 PROGRAM.........Clear
250 STOP............Control Left 246 PLAY............Control Right
250 STOP............Cursor Down 059 CHANNEL DOWN....Cursor Left
055 CHANNEL UP......Cursor Right 246 PLAY............Cursor Up
180 4...............D 055 CHANNEL UP......Day
184 5...............E 120 ENTER...........Enter
182 6...............F 121 SHIFT STOP......Fine Tune Dwn
117 SHIFT PLAY......Fine Tune Up 248 PAUSE...........Function
186 7...............G 053 8...............H
250 STOP............Hour 057 9...............I
123 A/B.............Input 181 0...............J
059 CHANNEL DOWN....K 250 STOP............Level Down
246 PLAY............Level Up 122 PROGRAM.........Menu
250 STOP............Menu Down 246 PLAY............Menu Up
246 PLAY............Minute 116 SHIFT PAUSE.....Mode
245 MUTE............Mute 230 SHIFT FFD.......PIP Freeze
235 FAST FORWAARD...PIP On/Off 232 SHIFT REW.......PIP Replace
119 POWER...........Power 052 DISPLAY.........Recall
249 RECALL..........Review 248 PAUSE...........Select
122 PROGRAM.........Set Up 118 REWIND..........SetTime Fast
122 PROGRAM.........SetTime Slow 056 SLEEP...........Sleep
116 SHIFT PAUSE.....Stereo Matrix 118 REWIND..........Stereo Matrix
116 SHIFT PAUSE.....Surround 122 PROGRAM.........Time/Day
056 SLEEP...........Timer 181 0...............Timer Set
056 SLEEP...........Timer Start 116 SHIFT PAUSE.....TV
123 A/B.............TV/AV 123 A/B.............Video Mode
058 VOLUME DOWN.....Volume Down 054 VOLUME UP.......Volume Up
116 SHIFT PAUSE.....Wide
Hope this helps. Let me know if I can help you with anything else.
JimmyC
Sep 29, 2009 | Televison & Video
How to set date and time
Voice Time/Day Stamp
1. Make sure the answering system is ON.
2. Press flash/answerer/call waiting button on the handset to enter answerer remote mode.
3. Press key [8] to enter Time/Day set menu on handset.
4. To set Hour, key in [00]-[12].
5. To set Minutes, key in [00]-[59].
6. To set AM/PM, press the CALLER ID-VOLUME (5or6) button.
7. Press #PAUSE/ringer button to confirm the setting.
8. Press Caller ID-Volume to set Day
9. Press #Pause to Confirm
10. Phone will then Announce the Day & Time
Feb 02, 2009 | GE 25932 Cordless Phone
Crackling Audio
Is there any other programs running in the background IE Anti-Virus programs, or anything that could be using quite alot of Memory other the stuff your watching?
It could be either down to Lack of Memory being allocated to the Audio & Video (Probably the case if the machine has built in Shared Sound & Video Card). Try opening Task Manager and setting the Application that you use to play Music/Movies to High Priority.
If it's not that try lowering the Master Volume on the Mixer Device by going into the Volume Properties in the Task Tray (By the Clock).
Dec 04, 2008 | HP Compaq Presario V2000 Notebook
Technical Pro TA-4250 Amplifier Logo
80 people viewed this question
Top Technical Pro Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Bapco
Are you a Technical Pro Audio Player and Recorder Expert? Answer questions, earn points and help others
