Question about Refrigerators
I have a Kenmore model 253, and the refrigerator section stopped working yesterday but the freezer was fine. I de-dusted the back, and when I checked the compressor was hot to the touch. At a paid site an online tech told me the compressor was broken and had to be replaced (a $200-400 fix on a 6 year old $350 fridge). When I checked it this morning the compressor was just warm to the touch, and the fridge was cool, but not up to the correct temperature. I'm not sure if it's related, but at the time the fridge section died yesterday the bulbs burned out
    Genius:
  • 1,156 Answers
Sounds like you have a defrost problem since the freezer side is working okay . It probably is not blowing cold air into the refrigerator side , so to check the defrost circuit , unplug the refrigerator and inside the refrigerator section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and forward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrig's , a white box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug going to the board and on the right side of the PLUG , the far right wire is yellow , then another color , then white . Useing a small insulated wire with both ends stripped , insert one end into the yellow wire hole and the other into the white wire hole . This will bypass the adaptive board and send power directly through the defrost bimetal ( thermostat ) AND heater to check if they are good .Plug the refrigerator back in . Now , wait about 3-5 min and look for a red glow at the bottom of the inside freezer panel , which will be the defrost heater or listen for sizzling which will be the frost melting and dripping onto the heater .If NO red glow , watch for a spark while removing the jumper wire you installed , from the plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost board should be replaced . If no glow , sizzling or spark , then unplug the refrigerator and reinstall the refrigerator control section .
Remove the food in the freezer section enough so that the 2 screws holding the lower freezer panel on and the freezer panel , can be removed . Remove the panel . If the heater (black element at the bottom of the coils ) wires are visible , trace then to the top of the coils and disconnect . Use an ohm meter to determine if the element is good . If the element IS good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils . This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good . If the element shows bad , replace the element . NOTE 1 : sometimes the element and the bimetal come wired together and the replacement part comes with a new heater and bimetal already wired together . This would be the adviseable replacement part . However , each part can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic " cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its designed function .
Good luck.....
Posted on May 17, 2011
Good morning Richard. I own an Kenmore Model # 253-55693402 (side by side) built in 2004. Yesterday afternoon it stopped cooling (both sides). I emptied it and turned it off last night before going to...
Check to see if you hear the fans running whlie having the doors open and holding the light switch in.
If the unit is running and cooling but the fans are not, you may have a fan out. Post back your results to me.
Sep 17, 2011 | Kenmore Side by Side Refrigerator
Kenmore 253 refrigerator/freezer won't stop running on any setting. The food in the top of the refrigerator would freeze unless I partially blocked the vent. I am wondering what the problem could be. i...
I have a Kenmore model 253 freezer/refridgerator upright model. I am getting cold spots in the refridgeration in and near the vegetable drawers on the bottom of the refridgerator. The icemaker works but the water dispensor has stopped working too.
Nov 28, 2010 | Refrigerators
I have a Kenmore refrigerator/freezer model # 596.65232401, this is the one with the freezer on the bottom and refrigerator on top. The freezer works fine, the refrigerator was not cooling, I removed the...
What you didnt state was whether you had cold air blowing when the damper opened up. If you did, then the problem will be with the damper assembly itself, or the control board, which is what you would adjust to change temperatures. This microswitch you mentioned, was this on the control board? then the control board is the problem. If you did something with the damper assembly, then that might be the problem.
If you dont have any cold air blowing when you opened the damper door, then airflow is your issue, and you will have to include more symptoms for a refrigerator repair diagnosis.
Nov 27, 2010 | Kenmore Refrigerators
Its not getting cold
MAKE SURE THE FANS ARE RUNNING FREEZER AND COMPRESSOR, THEN CHECK THE BACK WALL OF THE FREEZER IF ITS FROSTED UP YOU HAVE A DEFROST ISSUE. IF THE COMPRESSOR AND FANS ARE WORKING AND NO FROST IN THE FREEZER THATS NOT A GOOD THING..
Jan 13, 2010 | Kenmore 74852 / 74854 / 74859 Top Freezer...
Will not get colder then 40 degs on the coldest setting.
Bill I would like you to look inside the freezer compartment and see if frost is building up on the rear walls indicating that the refrigerator is not defrosting properly. The part number for the defrost timer is 215846602
It is located at the bottom of the refrigerator and behind the kick plate. Remove the kick plate and turn the timer clockwise slowly until you hear the compressor stop. Leave like that for up till about 25 minutes or until the compressor restarts. Which ever comes first. During that time open the freezer and see if you can hear water sizzling or dripping indicating defrost. If this solves the problem of temperatures in the fresh food section the most likely the defrost timer will need replaced. Let me know your results so if this does not help I will be able to give other things to check, Thanks Sea Breeze
Oct 27, 2009 | Kenmore Refrigerators
Refrigerator not cool, freezer ok
Either the freezer continues to freeze up (most likely due to low refrigerant, due to a leak), or there is an obstruction between the freezer and the refrigerator (refrigerators get their cooling from the freezer).
Given that it works after you defrost it, I'm going with low gas. Call a professional to see if the leak can be fixed. If the unit is more than 10 years old, just get a new one.
Aug 22, 2009 | Kenmore Refrigerators
Kenmore refrigerator model 253 not getting cold
i have the same problem: botttom of refrigerator does not cool.
freezer working ok.
Sep 30, 2008 | Frigidaire FRT17G4B Top Freezer...
GE Side by Side Refrigerator
Check for frost on the back wall of the freezer section. If no frost buildup is noted check that the condenser under the refrigerator behind a removable panel in back is clean and that the fan there operates when the compressor runs.
If you have frost buildup in the freezer section on the back wall you have a defrost system problem. These problems are not related to the cleaning ladies work unless some paper or other item may be stopping the fan from turning.
Jun 11, 2008 | Refrigerators
Ice catch bin
JK, if your model number starts with 253. this is your ice-bin. Part number 240385201. You can order it at http://www.repairclinic.com/0081.asp?RccPartID=891419 If your model does not start with 253, you'll need to post the complete model number...Catriver..post back.
Apr 23, 2007 | Kenmore 74810 / 74813 Top Freezer...
Refrigerators Logo
85 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
