Question about Refrigerators
Refigeratoer keeps defrosting & leaking water
  • Refrigerators Master
  • 8,220 Answers
Is your door gasket worn out? It could be letting in air.
This makes the unit defrost more.
If the door gasket is bad the ice box will also leak and sweat.
Posted on May 17, 2011
Why is freezer cold and refigeratoe side not
It maybe something wrong with defrost system or maybe the evaporator fan motor is not working open the panel of freezer back wall and see if its iced up all over but the fan is working then you need to locate the defrost timer on your fridge in some fridges there is no defrost timer it controlled by the electronic circuit board in that case just defrost the ice so it will start working again for few days and its better to call technician because it will be hard for you to diagnose that which part need to replace. Just for your information if the fan is working on your fridge then there are three things which need to get checked 1. Defrost timer of Defrost Board 2. High Limit Thermostat and 3. Defrost Heater
Aug 23, 2014 | Amana Refrigerators
Why is water leaking out evey day???
Is the water leaking from the refrigerator compartment or the freezer compartment? Can we assume the "leaking" water is more than some accumulated humidity/moisture (check your door gaskets)? Have you checked all water lines/fittings for the water dispenser/ ice cube maker (if you have one)?
If it is is the freezer section, the problem may be a clogged drain line (is there ice blocking the trough drain hole?) at the bottom of the freezer (evaporator) coils? You may need to defrost the freezer, check for any faulty parts (e.g., defrost time/ADC, defrost thermo, defrost heater), and clean the drain trough/tube. See Refrigerator Defrost Parts for illustrations.
May 22, 2014 | Roper Refrigerators
JENN AIRE LEAKING WATER ON FLOOR. NOT SUPPLY LINE PROBLEM. HELP
Open freezer, remove lower crisper & look for solid ice on freezer floor & area at rear of freezer. If present, defrost drain is restricted. Depending on make & model remove ice, remove rear wall and clear defrost drain trough and drain path. Verify by removing kick panel, pour a cup of near boiling water through drain and watch as it drains into pan. Once clear, pour one ounce of bleach into drain tube. Also check as water is draining into pan that the pan is not leaking due to pan cracks. This solution is based on the fact that you are stating no hoses are bad.
Mar 27, 2012 | Freezers
Water leaks inside
It's due to wrong temp setting and malfunction of defrost cycling. Keep thermostat setting at 5 degree or little less. And don't keep it in minus,as defrost cycle will take longer time. And also you will get less cooling in fridge compartment and also water leaks.Check drain line hose may freezed. And also freezer tray get blocked due to over frosting around freezer. Defrost manually by unplug your fridge and after defrost all ices, plug again and keep correct temp setting. Thanks.
Feb 01, 2011 | Whirlpool 21.0 Cu. Ft. Frost-Free...
Water leaking from under the freezer
Until defrosting the block of ice you canot see if is a hole or crack in the bottom. But I suppose is leaking from the door gasket under the pressure of the ice inside. Anyway, if you want to keep alife your refrigerator, better unplug it, defrosting and clean it before complete annihilation.
Sep 10, 2017 | Frigidaire Refrigerators
GE Side By Side Ice Machine & Water dispenser not getting water
you may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
Jun 05, 2010 | GE Profile PSW26P Stainless Steel Side by...
Water pooling & freezing in the bottom of a kenmore model 795.75252400 freezer compartment
The problem is the water drain tube in the freezer is clogged. As the evaperator goes into deicing mode the water from the evaperator is not going down the drain tube. Instead it's over flowing those two air ducts to the refridgerator and causing your water problem. But it's not as simple as simply clearing the clogged drain tube. You need to install a heating element inside the drain tube to keep it from freezing during the deiceing process.
Sep 04, 2009 | Kenmore Refrigerators
Refrigerator is leaking water into drawers and out on floor
Your defrost drain is clogged . Remove the rear freezer panel and using a hair dryer , defrost the aluminum tray below the coils . When you see the drain hole , defrost it and use a small tube to insert and blow thru to remove any possible "gunk" . You may have to use a little hot water to help defrost the drain , but keep at it until you can blow thru it .
Mar 21, 2009 | Kenmore 64522 Top Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
