Question about Garden
I have to replace the 48 volt battery on my Troy-bilt 19 inch rechargeable lawn model 18A-188-563 060-1771. How do I get the battery shroud off?
  • 376 Answers
SOURCE: require an operator's manual for a bolen troy bilt ltx 14 hydro
Go to... http://www.buymtdonline.com/webapp/wcs/stores/servlet/FindingYourPart_10101_19502_-1 Scroll down to bottom left and click on Owner Manuals. You will have to have the model and serial numbers from under the seat of your mower.
Posted on Jun 19, 2009
  • 95 Answers
SOURCE: reset oil chang warning light
The oil minder light will blink for 2 hrs and then reset itself, i believe it starts at 49 and ends at 51 and then every 50 hrs it will do the same.
Posted on Jul 30, 2009
  • 202 Answers
SOURCE: I have a Troy bilt 17hp 42 inch cut ride on lawn
yes they have a charging system, not like a car but a charging system one the less. as i said before either under or around the flywheel. some newer mowers also have an electronic regulator.
Posted on Jul 31, 2009
panilling9
  • 284 Answers
SOURCE: how to adjust valves on briggs and stratton 17.5
Remove spark plug
Remove cover from engine that covers the flywheel
Remove rockerarm cover or valve cover
Find TDC (top dead center) by rotating the flywheel by hand and your finger over the spark plug hole as you rotate the flywheel you will feel pressure against you finger at some point then stop.
This is the compression stroke it is called now find a long slim round piece of plastic or plastic ink pen to stick in the spark plug hole (If you are careful a slim screwdriver can be used ) and find the piston top, then slowly rotate flywheel again (cw) as the piston is moving up pushing the plastic up as you rotate the flywheel slowly.
a max. piston up or tdc as you turn you will feel and then the piston starts to go the other way,at that transition this is tdc (piston is on top of stroke) leave it there,,both valves should be closed at that point.
Have a feeler gauge and set the exhaust valve at a loose .002 and the intake a loose .004 be sure engine is cold when valves are adjusted
Feeler gauge goes in between the rocker arm tip and valve stem top for each valve setting.
Note the rocker adjustment at the push rod side of each valve by tightening and loosening to make adjustments,lock your adjustments in place and rotate flywheel a few times and recheck settings
Posted on Sep 20, 2009
SOURCE: need a owners manual for troy bilt 17.5 hp 42 inch
HOW TO CHANGE A BELT ON
  • Troy-Bilt 17.5-HP Manual 42" Riding Mower
  • Posted on Apr 19, 2010
    Troy Bilt 33" walk behind mower blades won't turn on.
    Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
    www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
    Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
    Nov 08, 2015 | Troy Garden
    Need a service manual for a remington 18a-202a783 12amp push mower
    http://www.manualslib.com/manual/498914/Mtd-18a-212a783.html#manual
    Sep 28, 2014 | Remington 18A-212B783 - RM212B 19" 24-Volt...
    My Troy-Bilt line trimmer model no. TB539E Line trimmer disintergrated while using it. My problem is finding and ordering replcement parts and if necessary how to install them.
    Several small engine dealers have parts for Troy Bilt but here is one site that will give you your part numbers and an idea of the costs you are looking at. Good luck!
    http://www.ereplacementparts.com/
    Aug 17, 2010 | Troy Bilt 17 Inch 29 Cc Gas Powered...
    Troy Bilt Pony won't start
    Try taking the shroud off of the motor and and cleaning the magnets on the fly wheel. Also clean the two little prongs next to the fly wheel. You can also clean the end of the spark plug cable that hooks onto the plug. I use fine sandpaper or emery cloth.
    Good Luck
    roundo4
    Sep 03, 2009 | Troy Bilt 5.5hp Self Propelled Mower
    Jul 31, 2009 | Garden
    33 inch Troy-Bilt walk-behind clicks while trying to elect start
    Check the voltage to the solenoid when the key is turned to start, it should be 8-12 volts. IF the voltage is low clean all electrical connections.
    Jul 06, 2009 | Garden
    Troy Bilt 190cc Z-Start Model 12A-446A011 21"Inch Deck
    You need to remove a pulley to put the new belt on.
    Jim
    Jun 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
    How do i replace a drive belt on a troy bilt self propelled lawn
    You turn the mower over, remove the blade with a 9/16 or 5/8 socket. There is a bolt holding shroud on, 3/8 or 7/16, there are two screws by the rear wheels, 7/16 that need to be removed. Once the shroud is removed, belt can be removed and new one put on.
    May 16, 2009 | Troy Bilt 5.5hp Self Propelled Mower
    Garden Logo
    508 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
