Question about APC BX800 Back-UPS XS 800 (APNBX800) UPS System
I am replacing the batteries on my apc 800xs and need to know the proper wire connections. The wires came off and I am not sure if I conncect red to red and black to black and yellow to black or red. Please help. Many thanks
5 Suggested Answers
viaujoc
  • 60 Answers
SOURCE: desk top APC UPS ES750 not communicating
Here is an answer I got from APC when one of my client got the same problem as you did:
The error message would pop up if the link between the computer and the UPS is weak. I cannot rule out a problem with the cable or the UPS. In order to confirm the same please try the following steps which might help :
1) Ensure that the USB cable is properly connected to the USB port of the computer.
2) If the PC was powered on before the UPS, communication will not be achieved until you disconnect and reconnect the USB cable to the host. In this case, you need to disconnect and reconnect the USB cable to establish communication.
3) Some other software is polling your USB port for another device, thus causing the UPS software to temporarily lose communication with your UPS. If this is the case, you would need to shut down that application.
4) If you have any other USB devices connected to the PC, disconnect them and then try plugging in the cable.
If the issue persists, please visit the following link which lists few troubleshooting steps :
http://nam-en.apc.com/cgi-bin/nam_en.cfg/php/enduser/std_adp.php?p_sid=oXhRFGEh&p_lva=&p_faqid=2923
Posted on Jan 13, 2008
  • 8 Answers
SOURCE: apc ups flashes red light to replace battery, but battery is new
i think by replacing the battery has not been the solution to the problem
u need to check the battery charging voltage when turned ON with main electricity, if no voltage present from charger, there is no question of battery getting charged and also once the battery is down with charge it may not re charge hence the indicator and alarm.
recomended to nearest service centre
Posted on Sep 13, 2008
  • 186 Answers
SOURCE: changing batteries
black is ground
Posted on May 02, 2010
tech240
  • 169 Answers
SOURCE: APC SmartUPS 3000VA
APC do not release cct diags and these are not easy to repair, if the battery fuse was open and there is some board damage, the thing is toast. Even if you get it going the battery will not be able to be calibrated, unless there the board/processor is 100%, I know this as we have a similar model on the bench right now with new batts in and the unit will not recalibrate, so even though the batts are new, as soon as the mains is dropped it goes to very low battery and shuts down in 2 mins.
Buy a new UPS save yourself a lot of time. Hope this helps
Thanks for using FixYA
Posted on Aug 02, 2010
How to replace an apc battery back up battery
Depend on model.
For 600VA and above
Go to APC site and check model of replacement battery.
Peel open the front plastic panel and unscrew 2 screws of metal panel.
Batteries can be slid out and replacement done when PC is online.
Only two wires to disconnect and connect.
Apr 21, 2014 | APC Computers & Internet
Apc xs800 new batteries
I Bought two RBC32's and had to hook them up to the connector and did it wrong on the first try. Make sure you connect the yellow to the Red terminal on one battery and the Black on the other, then connet the remaining red to red on one and black to black to the other. Once I did that and plugged it back in everything worked fine.
Apr 06, 2012 | APC BX800 Back-UPS XS 800 (APNBX800) UPS...
Even when it was brand new, my computer loses power even if it is not black out and my Back-UPS RS 500 blinking and cotinously beeping, and always my computer did not properly shut down. please help me to...
You need to replace the battery. Go to APC site and order the battery for your model. http://www.apc.com/resource/include/techspec_index.cfm?base_sku=br500i go to about the middle of the page, there are two models for replacement batteries. If you're not sure which one, call APCs customer support. 800-555-2725 I don't know what the shelf life is for your model but the battery usually last 3 yrs or so. Your battery is probably dead now.
Mar 02, 2011 | APC Back-UPS RS 500VA (BR500I) UPS System
My ups does not give enough back up and the others are not powering
It is usually a battery problem.It is not charging anymore.The battery is the power source for your UPS once the AC source is cut off.Open the unit and there you could locate the battery enclosed inside the UPS box unit.Replace it with the same type and size of battery, observe polarity where the red is (+) positive and black is negative (-).Depending on what the manufacturer used for the color coding but still see where the Positive and Negative wires are connected to.But before you open the unit remember to unplug the unit from the power outlet.
Nov 06, 2010 | APC Smart-UPS 1000VA UPS System
Belkin 1500va (uses 2 - 12v 7ah batteries)
check out this picture, it shows the 2 batteries wired up.
Notice that the batteries are flipped opposite of each other.
So from left to right its: bottom red, bottom black, top black, top red
http://www.pcstats.com/articleview.cfm?articleid=1092&page=2
Between the 2 batteries there is 1 red to black connection.
Then black to black-wire to circuit board
and red to red-wire to circuit board.
Aug 22, 2009 | Belkin (F6C800-UNV-PL) UPS System
APC back-ups XS 800 battery backup : warning
Turn it off and unplug it from the wall.
Open it up and make sure that the red and black wires are connected.
If they are the battery needs to be replaced. They are only good for 2-3 years. If you are not comfortable with my instructions, call APC for free support. (800) 555-2725
Vote for this solution if it helps.
Aug 15, 2009 | APC BX800 Back-UPS XS 800 (APNBX800) UPS...
UPS Switching off while working
Hi kumaraswamy5,
it seems that either the UPS is connected to an outled which isn't grounded properly or the battery inside of the UPS needs a replacement.
On APC's website you can find the compatible batteries for your device and where to order them. Replacing the batteries is very easy so don't be afraid of that!
Greetings from Germany,
noris017
PS: Please don't forget to rate this advice after you've tested it out! Thanks in advance and have a nice day!
Feb 25, 2009 | APC (BE500U-WEB) (BE500UWEB) UPS System
Belkin ups not working properly.... green and RED light on ...indicates bad battery. But unit not more than 1 yr old, no battery time at all when plug pulled...not enen i min on (desk to an d monitor
Your batteries are weak...(causes
1:-not powering the UPS for a longtime
2:- long use(3 to 4 years) )...you will have to replace them
PLEASE RATE ME.................
May 25, 2008 | Belkin (F6C1500-TW-RK) (F6C1500TWRK) UPS...
Battery replacement
May i please know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
Apr 23, 2008 | APC Smart-UPS UPS System
Question about APC Smart-UPS 1400
This is the battery you need to replace http://www.batterywholesale.com/battery-store/proddetail.html?prodID=619
Ther are a few places to get one
Nov 03, 2007 | NEC APC Smart-UPS 1400 (050-01803-000) UPS...
APC BX800 Back-UPS XS 800 (APNBX800) UPS System Logo
69 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
