Question about HP Pavilion dv6275us (RP284UA#ABA) PC Notebook
When I turn on mt dv6275us laptop, I get verticle lines with a pale background. If I leave it on for a few minutes the lines change colors, I plugged in an external monitor, same thing appears on the monitor, when I start up without the hard drive ---same thing, without memory black screen. thanks for your time !
    Scholar:
  • 35 Answers
Unfortunately, if this situation occurs in both the internal monitor and the external one, this is almost certainly a burned-out video card that is no longer able to output correctly. Without the hard drive the BIOS will still engage and try to boot, thus engaging the video card - but without memory, the PC will not POST, resulting in the black screen you're seeing.
This laptop will almost certainly either need to have a new video card installed or be replaced entirely.
Good luck, and hope this is helpful!
Posted on May 17, 2011
It works fine for about a few minutes and then the light is slowly getting pale and the sound slowly looses power until it doesn't give any sound at all. Tried a few different batteries, same thing.
Battery is not the problem.
It could be transistors, IC, elco etc. It must be checked.
This electronic parts, could be almost breakdown. At the beginning of the device is turned on, it work fine, but after a while it became hot, then the value is changed, then the circuit was not working.
Can also occur on the DC input, the diode and the elco (D006,C019,C40,C41). View image.
23095950-2ss5ycyvkoajtv035dpuezke-1-0.jpg See the full diagram here :
Boss MT 2 Metal Zone distortion pedal schematic
Jan 24, 2014 | Boss Mt 2 Metal Zone Effects Pedal
Verticle lines/streaks down screen
The Display panel could be bad/damaged or the main board that controls every thing could be bad---parts for Dell equipment are known to be hard and sometimes impossible to find.
Dec 07, 2012 | Dell UltraSharp E248WFP 24" LCD Monitor
My mitsubishi projection tv comes on and works fine for a few minutes then lines like a verticle hold in different colors mostly green flicker up and down the screen like a verticle hold, I would like to...
Mine has the same problem. This kind of TV does not have a color wheel. I changed the 4 1000 uF caps on the DM board like advised here, but it did not fix the problem, but it did change it, so I suspect it's a similar problem somewhere on the signal or main board. The caps were getting ready to burst.
Sep 23, 2010 | Mitsubishi WS-55513 55" Rear Projection...
I thin k I am having back ilight and/or inverter program with my HP dv6275us Notebook based on the following: - machine powers on but o video or image on screen or image is extremely faint. Upon closer...
These are typical symptoms of a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
As for the cost, I would suggest a search on ebay.com
Sep 06, 2010 | HP Pavilion dv6275us (RP284UA#ABA) PC...
Inside light does not turn on and verticle colored
Sorry, no help. There are no spare parts for these scanners.
Nov 24, 2009 | Mustek A3 USB Flatbed Scanner
LG Model# RT -42PX11,screen is not working.. shows verticle line color pattens and turns shades of black when a button is pressed
My LG RT-42PX11 after a few minutes the screen starts to flicker and colors go psychedelic and after some time no picture at all
Oct 24, 2009 | LG 42LC2D 42 in. LCD HDTV
I have a Sony KDFE50A10 50 inch HDTV When I turn it on for it has the lines verticle on it it takes a few minutes and then clears...tv or cable?
Hi,if its a an LCD RPTV it sounds like a light engine problem.Basically your tv uses 3 LCD chips that create the image .Each chip is like a tiny screen that blend together to get the colors and picture right.They are green,red and blue.When they start to fail you will start to get color discoloration or vertical lines.You will need to replace the light engine.God bless you!
Oct 20, 2009 | Sony KDFE50A10 50" HDTV
Spot on the screen
This problem is covered by Mitsubishi even out of warranty.
Jan 14, 2009 | Mitsubishi LT-52144 52 in. LCD HDTV
Verticle lines on screen
This is a very easy fix. Your cable box is not grounded correctly. To fix this you need a AC Plug adapter. This will change your TV ac plug from a 3 wire to a 2 wire. This may sound funny, but trust me on this. I have fix a lot of TV in NY doing just this.24001fc.jpg
Sep 10, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Mitsubishi with no picture
. Suspect the DM PCB part # 934C116002 if pinkish color
Jul 13, 2007 | Mitsubishi WD-52525 52" Rear Projection...
HP Pavilion dv6275us (RP284UA#ABA) PC Notebook Logo
67 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
