Question about Ovens
I have a Whirlpool oven m # GFG471LVBo. It's a spark ignition oven, the broil works fine. When you turn on the bake, it clicks for a few seconds and then the fire comes on, a minute or two later the fire goes off. When you shut the oven, and then turn it back on, it will go on but shut off within a minute or two. What can be my problem?
  • All Make Appliance May 19, 2011
    please know what oven this is before u give a stupid response read this is a spark ignition i understand why u answer questions rather then do service calls
  • All Make Appliance May 22, 2011
    YES!!!!!! if you could read you will see the oven does not have ignitors!! it is a spark ignition do you know what it? this place did not help me at all and i want to request my money back for the months i had it.
  • Ovens Master
  • 1,902 Answers
Hello & Welcome to FixYa
The first thing that needs to be tested/checked is the bake igniter, if the igniter is fine then the problem is either with the thermostat or the safety valve or the selector switch. After reading your problem it seems that either igniter or valve is causing this problem. Please get back to me if you have any other questions.
Kevin
Posted on May 17, 2011
  • Kevin White
    Kevin White May 21, 2011
    Stupid Answer??
Maytag double electric oven. we turn on to bake and would switch to broil then will turn off.
Assuming this is on a gas range, the bake burner ( under the oven floor) and the broil burner ( at the top of the oven) have electric igniters . When switching from bake to broil the broiler goes off due to a defective or broken broil igniter. cheap part to replace ( +-$40.00)
Oct 16, 2014 | Maytag Ovens
We have a Whirlpool Gas Range, model SF357PEKQ. When I start the bake feature, you can hear the gas flow, the ignitor click (about 4 times) yet there is no ignition of the gas (flame doesn't start)....
Whirlpool had some grounding issues with some of their electronic ignition ranges. Make sure your outlet is grounded first. Then you might need to make sure the bake burner itself is grounded very good against the range frame. I have put star washers between the burner and frame and tightened very tight, that sometimes helps. Also make sure the holes in the burner under the spark electrode are clear from debris. Sometimes the burning of gas leaves a residue that can stop up the holes and not let the gas flow out where the spark is hitting the burner. Hope that helps.
Aug 29, 2011 | Ovens
I have a whirlpool gas oven model # SF367LEKB and the oven will not ignite. You can hear the ignitor clicking but it will not light. The broiler and four burners work fine. This happened several months...
What you need to check is if the spark is strong at the bake burner.To do that remove the oven floor and the flame spreader under the oven floor, set the oven to bake and look for a good bright spark. If the spark is good the bake burner needs to be replaced,if it's a weak spark the electrode(spark Plug) will be needed.
The part numbers are
Bake burner 8054077
Electrode 8054129
They could be purchased at your local appliance parts store or online at;
searspartsdirect.com
apdepot.com
repairclinic.com
assuredparts.com
applianceparspros.com
I hope this will help youto beable to repair your oven,
Gene
Aug 06, 2011 | Whirlpool Ovens
I have a two ear old Kitchenaid gas range (KGRS807). It all at once stopped lighting the oven. The top burners still work fine. When you do anything in the oven (Bake , Broil, Convection) the electric...
You will need a new igniter module. The igniter module is told to spark by the control panel. There is also a flame detection for electronic start and that could be bad too.
Apr 16, 2010 | KitchenAid Architect Series KEMC308KSS...
Bottom element doesnt work in oven, but top does.
NOPE!
  1. Broil element does not have welded-on legs and will touch the bottom of oven, overheating itself and will end up the same way your bake element did; besides, the bottom of the oven will corrode pretty quick
  2. Many ovens use both elements during bake cycle
  3. self clean cycle uses broil element
  4. The bake and broil elements typically have different mounting brackets and screw holes ate in different places
  5. you'd have to cover the hole, left after removing the broil element, and insulate the wires, which went to broil element
  6. the ends, protruding behind the mounting bracket may have different length and different connectors. you may end up shorting the wiring to the casing, which may in turn destroy the control board if there is one
  7. Bake elements usually cost only $40-$60. No jury rigging required.
Hope this helps ;)
Mar 29, 2010 | Ovens
I can get the bake function to work on my Whirlpool 465 Self Cleaning oven it flashes numbers. The broil control works fine. What can I do to get the baking to work on my oven. It is digital the Model is...
You can check the lower igniter and see if it is glowing. If it is not glowing then check with a meter to see if it is reading over 120. If it is reading 120 or less then you need a new controler if it is reading over 120 then you will only need a new igniter. Hopes this works.
Jan 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I have a whirlpool gas stove, the bake or broil will not light.
Check to see if the electric ignitors are connected at the ignition module, located under the top surface panel. It is possible that the wire(s) that go to the oven ignitors has burned off or become disconnected from the main spark module,
It is also possible that the electrodes have failed and need to be replaced. These are the two (2) devices that produce the spark (and make the clicking sound) inside the oven compartment.
If those are OK, then check the thermostat, as it could be faulty and preventing the oven from functioning.
If you can smell gas when attempting to turn the oven (bake or broil) then the valves are good, if you don't smell any gas, the gas supply valves (one for each bake and broil tubes) need to be checked.
You might also try lighting the oven manually with a long match or grill lighter to rule out faulty gas supply valves or a faulty thermostat, which if you can manually light the oven, it would prove that the ignitors must have failed.
Here's the exploded line drawings for your stove along with the parts list, just click on each section to see the parts. You can order replacement parts from them as well.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=gw395lepb02&pop=flush
Hope you find this Very Helpful and best regards!
Aug 28, 2009 | Ovens
Broil turns ON when pressing BAKE button on RBS275PD Whirlppol oven
Our Whirlpool oven just started doing the same thing!!!! The Delay Start Time (setting it for one minute ahead) and then Start works just fine.  But we fried the tops of three loaves of homemade bread!!!!
Is Whirlpool just a bad brand for ovens?
Dec 07, 2007 | Whirlpool RBS275PD Electric Single Oven
Electric Oven Won't Heat
Rob, sounds like it was just installed. You need 240V on this unit. On the terminal block in back where the power hooks up, it should read 240V across the two outer terminals and 120V from each end to center terminal. Im ruling out the thermal cut out because you never used it. I would start with the power source first. The display sounds like it's getting the 120V it needs to funtion, but I don't think your making the loop for the 240V needed for the bake and broil. Catriver.
Jul 12, 2007 | Whirlpool RBS275PD Electric Single Oven
Ovens Logo
42 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
