Question about Panasonic SC-PT753 Theater System
Panasonic SC-PT753 tray will not release my disc. Display reads "CLOSE" but it is closed. What can I do?
    President:
  • 2,080 Answers
First of all, here is the main ONLINE SUPPORT page for your model:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Home-Theater-Systems/model.SC-PT753
And here is a direct link to the ONLINE USER'S MANUAL for that model:
http://service.us.panasonic.com/OPERMANPDF/SCPT750.pdf
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, the follow the onscreen instructions to install the software on your computer.
First of all try resetting the unit by turning off the power button and then unplugging the power cable. Leave the main power cable out for 1 hour and then plug it back in and turn the set on. If the reset procedure does not solve the problem, then disassembly of the unit may be required in order to clear the fault condition.
If your warranty is still valid then just bring it back to your place of purchase for a refund, exchange, or no cost warranty service.
If the warranty is expired then you have nothing to lose by taking the unit apart and having a look inside. Your disc may have dislodged while inside the unit and is jamming the tray opening gear mechanism. One thing you can try is to unplug the unit and remove the screws holding the casing cover on. Remove the cover and then you should be able to see the disc and the drive / tray opening mechanism.
You can either remove or replace the disc by hand or you can carefully plug the unit back in and try to eject the disc again. If the tray mechanisn still refuses to open, you can try jiggling some of the components like the tray drive gear or the sliding rails to see if you can re-engage the tray opening mechanism.
Obviously be very careful not to touch any of the electrical components inside while the unit is plugged in. If you are uncomfortable with this type of live circuit maintenance, then you can just try jiggling the parts with the power off then replug it in to try it again each time. Otherwise just bring the unit in to a qualified electronics repair technician for them to carry out the necessary repairs.
Please comment back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
Thank you very much and good luck.
Joe.
Posted on May 17, 2011
Panasonic DMRES15 DVD Recorder disc not spinning
Troubleshooting Solution
1.Display Message " Please wait" Not
booted
2.DVD-Rom Two-Three times make noise but doesnt spinning
3. Doesn't
open tray, No video OUT
1.Bad Main Board VEP79117
2. Bad DVDROM
3. Bad Prosessor
PCB
Mar 16, 2013 | Panasonic DMRES15 DVD Recorder
Panasonic SA-PT170 disc tray will not open
You may as well replace the player, as the parts to fix it are not available for this type of device, just no demand .
Jan 31, 2012 | Panasonic SC-HT70 System
Panasonic dvd players error codes
I tried the WD-40 and it worked........thanks a million !!
Mar 28, 2010 | Panasonic DVD RV22K
Panasonic sc-pt1050 just displays close. Ive tried unplugging it and leaving off for a while, but that didnt work. The disc tray is closed and when it turns on it dosent even try to read the disc nor can...
I have the same exact problem. Turns out my toddler has stuck a piece of paper in the tray, so the tray was just stuck. I just undo the four screws on the side and 3 in the back, lifted up the top cover, remove the paper causing the jam, put everything back together. Problem solved. Saved $140 from having to sent it to Panasonic
Jan 18, 2010 | Panasonic SC-PT1050 System
Panasonic SC-HT95 display says "NO DISC" after reading DVD
Hi,you need to have the laser replaced in the unit.
Aug 09, 2009 | Panasonic SC-HT95 System
Disc tray on Insignia BRDVD player will not open. Any help would be appreciated. Press the open/close button and display says either open or close. The tray does not eject though.
the disc is probably stuck out of the tray and stopping it from opening. unplug, and you should be able to pry open the front case and pull the tray out.
Apr 13, 2009 | Panasonic SC-HT730 System
Open/close disc tray won't open
I have a Panasonic SC-HT810V home theater system and the dvd door will not close after inserting disc.
Dec 20, 2008 | Audio Players & Recorders
DVD-RAM will not eject via "OPEN" tray command
Hey I just found out how to UNLOCK the tray
Power up the unit, wait for it to read the disc if one is inserted.
hold the stop button and the power button down together for 5 seconds
the display will show UNLOCKED
Open/close button should be restored
Apr 03, 2008 | Panasonic DMR-T2020 DVD Recorder
PANASONIC dmr-es10
The DVD RAM drive is mis-aligned and does not load the disc correctly.
contact our local service center for a quote
Dec 14, 2007 | Panasonic DMR-ES10 DVD Recorder
Panasonic SC-PT753 Theater System Logo
91 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
