Question about Technics Audio Players & Recorders
Technics stereo keeps switching off - Technics Audio Players & Recorders
    Brigadier General:
  • 8,546 Answers
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on May 17, 2011
Would I be able to connect an external Technics SH-8036 Stereo Graphic Equalizer to my Technics SA-500 receiver?
Yes, it is hooked up using the (cassette) tape inputs and outputs. Use the tape monitor switch on the receiver to switch the EQ in or out.
Feb 11, 2016 | Panasonic Technics Sa-dx930 A/v Stereo...
Where can I get a free manual
go on panasonic website or google the manual you want.i use manuals lib
Jul 02, 2014 | Technics Audio Players & Recorders
Cannot play my ipod through my technics amp
You would need a mini jack to stereo rca wire. Insert the mini jack to your Ipod's headphones, then plug the stereo rca to your amp inputs. If it's a receiver, plug into any of the inputs (aux, tape etc) except "phono or turntable", then switch to respected input on the receiver. Be sure all volumes on both units are down during this process, then gradually turn up both volume to normal level.
Apr 04, 2014 | Technics SA-EX500 Receiver
Technics stereo
switch speaker to see if there is a problem with the speaker.
Aug 17, 2013 | Audio Players & Recorders
Fuse keeps popping on my technics stereo receiver. Model sa - g x 6 90 ...wut s wrong ...????
Be sure speaker wires are not shorted together. If fuse is the main power fuse, the power supply has a bad diode.
Nov 08, 2011 | Technics Audio Players & Recorders
How do i connect technics turntable model SL-QD33 to technics stereo model SC-DV290 and what do i need to switch to on stereo to play records.
Have a look on the back input panel of the sc-dv290. Check for a "PHONO" input. If there is no phono input it will not play turntable. If there is: then plug it the turntable in and switch the SC-DV290 to PHONO mode.
Another way would be to purchase a "phono preamplifier" from ebay: Hook the turntable into the phono preamplifier, and the preamplifer into the SC-DV290 AUX input.
Feb 26, 2011 | Technics SC-DV290 System
I have a Technics stereo integrated amplifier SU G75. The cooling fan began making chirping noises then stopped. Now every time I turn the stereo on I get a overload message. Could it be the cooling fan...
It chirped because the bearings were worn out, then it froze up and isn't moving any air. Get it replaced. DO NOT run the unit if it keeps overloading or you will have a bigger problem.
Dec 27, 2009 | Technics SC-DV290 System
Technics amplifier switches off
1-keep good ventillation around and do not block any ventillation holes with any thing.
2-check your connection cable in good condition no touching of inner conductor with any chasis.
3-check your loudspeakers and apply them to the system one by one until you find the bad one(which make the problem if it is bad)
Jul 05, 2009 | Audio Players & Recorders
Technics hi fi
The audio amplifier IC damaged
May 09, 2009 | Technics SC-DV290 System
115 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
