Question about Watches
How do I get the back off without damage - Watches
Seiko wristwatch opening instructions
Take it to a jeweler for a demonstration of how to remove the back without damage.
Jun 30, 2018 | Seiko Watches
Can’t get the back on my Marc by Marc Jacobs mbm3194 after replacing the battery
Take your Marc Jacobs watch to a jeweler to have the back reinstalled without damage.
May 12, 2018 | Marc Jacobs Watches
How do I get the back off a timex indiglo watch
Take your Timex watch to a jeweler to have the back removed without damage.
Apr 28, 2018 | Timex Watches
How to take back off of armitron 20/m4210gp
Take your Armitron watch to a jeweler who will show you how to remove the back without damage.
Oct 09, 2017 | Armitron Watches
The battery needs replacing on my JL U44 Champ League watch.Three jewellers cannot remove the back plate saying its vacuum sealed. Any ideas how I can get the battery replaced please?
Some watch backs are very difficult to remove without scratching or damaging the case. The three jewelers consulted do not want to chance damaging the case so they invented the vacuum sealed excuse to pass on it.
Aug 24, 2016 | The Watches
Battery
With respect, if you have to ask you should get a watchmaker or jeweller to do it for about 5,pounds, without the correct tools it is highly likey irreparable damage will be done to the case in trying.
If you insist, there are broadly two main types of case back. One is a pressure clip that requires 'flipping' off with some force and the other is a screw type with keys meshing for at least three or four different models of tools to unscrew them. They mainly differ by make or model. It is the amount of force needed that usually causes damage when trying without the correct tools. When a watch is water resistant, a new gasket or two would need to be fitted if you want to retain the case integrity.
Jun 25, 2013 | Freestyle Shark X 75036 Watch for Men
How to unscrew back without damage
It's made to be about the width of the edge of a coin. Try your smallest coin currency, and work up from there.
May 30, 2012 | Swatch Watches
I'm trying to replace the battery, in my mother's Indigo Acqua watch. I can not get the back off?
If you are struggling with the back then the best advice I can give you is to take to a local jeweler as they have the correct equipment to do batteries, easily and without damage to your watch. Most batteries are going to be less then $15 and its worth it to not have the headache and damaging it if unsure what to do
Aug 11, 2010 | Watches
How to remove the back cover of the Swiss Army Victornoix pocket watch so to replace the battery?
The back will either have a small slot on one edge to pry it off or indentations around the perimeter for a case wrench to unscrew it. Specialized tools are used to avoid scratching the case. You best bet is to take it to a watch shop and let them do it. Most places charge between $3 - $8 to properly do it without damaging the case and they should also change the gasket to maintain water resistance if so equipped. Once you have it open you risk damaging the movement as you change the battery. It's not that it's a tricky procedure but you can easily damage something that will cost a LOT more than $8 to fix if you don't have experience.
Apr 09, 2010 | Swatch Irony watch
Watches Logo
44 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
