Question about Acer Aspire 6920 Notebook PC
My acer 6920 restarts automatically when AC power pluged in.. it runs fine in safe mode and on battery too it runs fine..... what to do ?? service center says d mother board is causing problem but no motherboard is available from acer .. what is solution?
  • 393 Answers
Start your system in Safe mode.
and try to restore your system for previous date.
If your are not compatible with how to restore, Go to the link and follow the steps.
http://support.microsoft.com/kb/306084
Otherwise you can try to reinstall the OS.
Thanks for using FixYa.
Posted on May 17, 2011
My Acer Aspire6920g keeps on restarting when plugged the charger, but when it is used in Safe Mode it does not restart
There may be a hardware change or driver issue because in safe mode, it doesn't load VGA drivers or other hardware. Use safe mode with network support and use the help file to guide you.
Feb 13, 2014 | Acer Aspire 6920 Notebook PC
Acer Aspire 6920 Restarts in Normal mode and works only in safe mode
Sounds like the MBR ( boot files) are corrupted. Try formatting the hdd before you instal again. I'm sure you have a restore sector on the hdd in which case, if you have done anything to that then you'll need to have the restore disc set which usually comprises of the restore disc and the drivers disc. Either way....just make sure you format c and not d which is usually the resore partition. Good luck
Nov 24, 2013 | Acer Aspire 6920 Notebook PC
My Acer aspire 6920 laptop keeps freezing . It will load up fine and then after about 5 or 10 minutes it freezes and says the programme is not repsonding. Noting will work i.e. the mouse won't move,...
HI, what program is show this message? is it always the same program? if so try uninstalling that program and reboot the laptop to see if it will freeze up.
Dec 20, 2010 | Acer Aspire 6920-6621 Notebook
Acer aspire 6920 laptop some times automatic restart. in normal mode hang when connected ac adapter
It appears that some of the the Windows files are corrupted on your computer, you can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as
soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction.
NOTE: This will erase all the datas on the computer.
Thanks and regards,
Jitha
Nov 24, 2010 | Computers & Internet
Hi, Cant boot up my Acer 6920, regular start up or in safe mode. Just takes me to a black screen.
Hi. Try to perfrom power drain to your netbook. Take out the battery then unplugged the power adapter. Press and hold the power button for 30 secs. Put everything back in then turn on the computer. If same problem will happen then you need to contact ACER and have your computer srviced for LCD problem.
Oct 11, 2010 | Acer Aspire 6920 Notebook PC
Acer aspire 5315 batt problem
Please run this unit on A/C only and see if it powers up like that. If it does not, then the A/C adapter is faulty and thus cannot charge your battery.
Service the battery by hitting it flat onto your hand palm or onto the back of your shoe and retry to see if it is charging.
May 25, 2010 | Acer Aspire 5315 Notebook
Acer aspire 6920 startup problem (Windows Error Recovery)
You could try booting up in safe mode by pressing F8 if you haven't already. OR, if you have the Windows operating system disc, you might try to boot off of that, or a system recovery disc. You may lose a few files, but hopefully that will get you up and running. Hope this helps!
Nov 09, 2009 | Acer Aspire 6920-6422 Notebook
Window need to chech c desk on file system 32
some pc's like that when you connect the power ac will start automatically withen few minuts then shout off..this from the power suplly.. ragarding the notebooks if you plug the charger and hit power buitton in few minuts will shout down. check the powere switch and board that is Motherboard problem.. or try first the check the system, use safe mode
Sep 17, 2009 | Acer Aspire 3000 Notebook
Start up stuck on Acer Arcade Deluxe screen
if you can boot into safe mode by pressing f8 at startup, check the startup folder for acer arcade and remove it if present.From your start button go to (start-programs-startup).
another option is to check the run key in the registry: one caveat though - please don't mess with things in the registry you don't understand. Deleting or changing unknown registry keys can result in a non-booting pc.
please stick strictly to my instructions and you will be fine. We're going to look and see if windows is calling the acer arcade to run at boot time:
click your start button and type 'regedit' (no quotes in the start search field. A window titled 'registry editor' will appear. Now, to expand a field in the registry, we left-click on the triangle on the left side of the field.
so, click the triangle beside HKEY_LOCAL_MACHINE
go down to 'software' and click the triangle beside it. go down to Microsoft and click the triangle, go to windows and click the triangle, go to current version and click the triangle, go to run and click on the run folder, not the triangle beside it.
Now look in the list of items in the run folder. these are all items that run when your pc boots. If you see an item with 'acer arcade' or just 'arcade' in the name, then delete it. DO NOT DELETE ANY OTHER REGISTRY KEYS....PLEASE!
if you found acer arcade and removed it then reboot and all should be better. if not, boot to safe mode again, click start button and type in 'msconfig' - no quotes. go to the startup tab, and again only uncheck anything with acer arcade in the name.
Hope this helps!!
Aug 09, 2009 | Acer Aspire 6920 Notebook PC
Acer Aspire 6920 Notebook PC Logo
320 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
