Question about Gateway FPD2275W LCD Monitor
When powered on, it shows the Gateway splash screen and all of the blue LEDs light up for a second but then nothing. It's like its not hooked to the video card but it is. Older system with windows 98se which normally have a Dell LCD monitor on it. I'd really like to get it to work but I don't know much about monitors. Any help would be appreciated.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 119 Answers
If the monitor is a multiple source monitor then it could be stuck on an incorrect source or may not support auto source detection. See if there is a button to change the source. This will typically, but not always, be labeled source or have an icon that looks like a square with an arrow.
If there is no way to change the source or it is a single source monitor then you should see if it works on another system.
Since you shared that there is normally a dell monitor on the system then it is safe to say the computers video output is working correctly, but it is possible that the Gateway monitor will not work with the older hardware of the system.
I wish you the best of luck
Posted on Sep 29, 2011
Gateway laptop i push power button it wont boot up but leds in front flash 4 times
Try holding down the power button instead of just pushing it. I had this problem with my HP dv7 and holding the power button down for around 5 seconds worked for me. Also make sure that its plugged in to a power source.
Oct 23, 2012 | Gateway Computers & Internet
I have a Gateway M 1625 laptop. When I power it on the blue light is on for power and I can hear the fan turn on, but nothing shows up in the screen. Replaced the hard drive and still nothing. I hooked...
This indicates a motherboard issue, remove main battery and test, if no change! remove the ram memory one at a time and test each, if no result! it is time to get a professional in to assess.
Apr 17, 2012 | Gateway Computers & Internet
Gateway FPD1750 monitor's keep go black screen, no picture at al
tgordon60, If you know how those NEW "CURLIE-Q" energy efficient CFL light bulbs produce WHITE LIGHT, then you will know what makes an LCD display panel produce all the pretty colors and the WHITE BACKGROUND of the FIXYA web page!!! Only difference is that your "cold-cathode-fluorescent-lamps" are thinner and straight, and hung on rear of LCD glass panel and have a DC to AC electronic ballast called an "INVERTER" circuit to produce 600 to 1000vac to light them up. Get to my FIXYA profile and read my responses to other BLACK screen lcd owners to learn about all your options for repair. Follow any of the links to other web pages you find there. Your monitor not any different than ACER, DELL, VIEWSONIC, BENQ, SONY, AOC!!!!! 12fixlouie aka louie12fix
Dec 30, 2009 | Gateway Computers & Internet
Slow flashing blue power lite. Monitor shows no
First when you power up the computer press F8 key then enter in enable vga mode.
If you are able to enter then go to start menu->control panel->display property ->settings.
Change screen resolution to 1024*768 then apply and ok.
But if you are not able to see safe mode and other menu.
Then open cpu cabinet .
Refix RAM memory.
Pull cmos cell from motherboard for 10 minutes.
Reattach all connection harddrive.
Open processor fan and processor remove dust from all parts.
Make sure motherboard is not ground with cabinet.
Remove PCI cards if any.
After all above still same then change RAM then try.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 19, 2009 | Gateway DX4640-UBC01A PC Desktop
Toshiba A105 keeps Restarting ---
maybe the power input is error
the uncorrect power input will result bad
or, it's your mobo broken
Jan 25, 2009 | Toshiba Satellite A105 Notebook
Gateway 400SD4 won't power up
replace the battery or have it tested. If these batteries don't have a minimum charge the machine will not boot into windows & will just shut down.You might try checking the battery condition with the "battery conditioner" in the bios
Rockman
Nov 26, 2008 | Gateway 400SD4 Notebook
When I hit power button on computer, power light doesn't come on...and the fan kicks on, but nothing else happens. nothing shows up on monitor except the test screen with 3 colors...the computer doesn't...
THis sounds like a power supply issue.. I had a similar issue with mine. my fan would kick on for about 2 seconds then shut off.
Hope that helps
Ciza
Oct 29, 2008 | Gateway (4000274) Motherboard
Gateway 450ROG screen problem
This could be the inverter, or screen cable. Try replacing the cable first.
Jul 28, 2008 | Gateway 450ROG Notebook
Gateway FPD2275W LCD Monitor Logo
32 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
