Question about Pds GE Profile Bottom-Freezer Drawer Refrigerator Energy Star 19.5 Cu. Ft. - PDS20MFS
GE Profile refrig, Bottom freezer drawer rolls out on a gear drive, how do I remove the whole drawer to access the ice maker?
SOURCE: GE top freezer ice maker leak
I have the same problem -
Posted on Aug 11, 2008
  • 8 Answers
SOURCE: Ice maker is making hollow ice cubes, some only half frozen
Most ice makers have an adjustment screw to control the cube size. Its usually hidden behind a plastic panel on the front of the ice maker. A quarter turn either way and some trial and error testing should get you pointed in the right direction to your ideal ice cube.
Posted on Nov 05, 2008
SOURCE: removing freezer drawer
my son fixed it - thx. problem solved
Posted on Nov 24, 2008
Maanita
  • 1142 Answers
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Posted on Mar 24, 2009
    • 145 Answers
    SOURCE: frost build up in freezer (ice maker section)
    Your ice maker is overflowing and asking for to mush water to make the ice, you may have a real hi water pressure on your water supply
    the is a easy way to adjust that but you are going to have to take
    your ice maker out
    then using a flat head screw driver remove the white square cover
    you will see a gear and a adjustment screw and a lever like this
    ( - I + )
    turn the screw to the minus sing a quarter way and install the ice maker back up.
    Or a easier way is just closing the water valve before your fridge a little so it wont have so mush pressure and will not fill your ice maker so fast.
    the ice maker feel up buy time not buy water level.
    Posted on Jun 28, 2009
    I have a Amana Bottom Freezer Refrigerator Model BC20ML that is about 20 yr.s old, works fine except the drain tube from refrig. compartment to evaporator drain pan sames to be plugged. Water and ice...
    You have to remove the bottom drawer, remove one of the drawer slider mounts on the freezer wall, and remove the rear panel. If yours has an ice maker you will have to disconnect it and remove it also. Unplug it so the water valve does not dump water on you while you are working inside.
    Aug 13, 2011 | Amana Refrigerators
    Ice cubes are turning into a clump of ice
    I found a high density foam and a plastic retainer under the freezer drawer, inspected ice maker and found a wire with a rectangular senser hanging down. Removed freezer drawer and door to gain access to icemaker. Reinstalled foam piece and plastic retainer to lower front of icemaker (there are recess and a small retainiing tab) Reassembled freezer door and drawer, system working normally
    Feb 23, 2010 | Whirlpool Refrigerators
    We have a GE Profile refrig, circa 1995. The ice
    If you are sure it is caused by the ice maker or if it is not it can be fixed. The only way an ice maker would leak like that is if ice is blocking the inlet tube and when the water comes on the water is spewed in a different direction than the ice maker. Most times this is caused by a slow leak in the water control valve for the ice maker side at the rear of the refrigerator. You can stop the problem by melting the ice in the fill tube with a hair dryer and keeping an eye on it until you see ice beginning to build up there again. That would indicate a slow leak in the water control valve that is not closing all the way when off. The other reason for large pools of ice in the freezer is a frozen over defrost condensate drain behind the cover in the rear of the freezer and would require you to unplug power and remove the rear panel. I will try to get some photos and a link shortly that covers that problem a lot more in just a few minutes. Sea Breeze
    Aug 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    Ge monogram bottom freezer ice maker spills ice
    It takes weeks for ice to dissipate in a freezer.
    You may can adjust your cut off lights or wire cut off to cut off before it's so full.
    Jul 01, 2009 | GE Monogram ZICS360NRRH C... Bottom...
    Frost inside and ice on floor of freezer
    The water can only come from 2 places, the drain is blocked or the ice maker is over filling.The temps are too good to have any other things going wrong. Let me know, Thanks, Sea Breeze
    May 18, 2009 | GE Refrigerators
    Feeler arm on ice maker prevents freezer drawer from opening
    Hi, There is no adjustment on the level arm other then bending it. Is it posible that something snagged it as the drawer was being pulled out and bent it? The arm should collapse all the way down tothe side of the icemaker and level with the bottom of the icemaker.
    Hope this helps. Please let me know if I can help further.
    Vic
    May 11, 2009 | Refrigerators
    Pds GE Profile Bottom-Freezer Drawer Refrigerator Energy Star 19.5 Cu. Ft. - PDS20MFS Logo
    104 people viewed this question
    Top Pds Refrigerators Experts
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Charles T Nevin
    Charles T Nevin
    LARRY BARAN
    LARRY BARAN
    Level 1 Expert
    Are you a Pds Refrigerator Expert? Answer questions, earn points and help others
