Question about Jenn-Air Kitchen Ranges
Jenn Air Range Model# SVE47600B: I keep getting an F7 error code and continuous beeping. What needs to be done to fix this?
SOURCE: Jenn Air Oven Model # SVE47600B Error Code F7
I have a jenn air SVE47600F.It just started beeping and giving a code 7.None of the controls work when it brings the code up,but controls work fine when code is not there. We have to turn the breaker off to reset it.Sometimes when we have been gone all day we'll come home and the range will be beeping and flashing a code 7
Posted on Oct 11, 2008
VANMAN69
  • 23 Answers
SOURCE: F1-1 error on Jenn-Air Range
if it is the stove that is in the picture the fault codes are in the door under the oven door.
Posted on Jun 02, 2007
jsrock516
  • 5911 Answers
SOURCE: Electronic Display
This is a common problem with Jenn-Air and Maytag that I have found. There is no way to brighten the display and usually requires the replacement of the Electronic Oven Control (EOC) board. I think this may have something to do with the placement of the board and possibly being damaged by heat from the oven over a period of time. Do you do a lot of baking? Do you use the self-clean mode for your oven a lot? These seem to be contributors to these boards failing like they do. I know of one person who has replaced the EOC 6 times on the same stove. I don't know if this is the advice you were looking for, but I hope it helps you.
Posted on Jul 14, 2007
VANMAN69, I have looked in the door under the oven door and can not find the codes. Any more suggestions? I have had a repair man come and replace my control board but I am still getting the F1-1 fault code and when using the oven I get the F3-1 fault code.
Posted on Aug 02, 2007
  • 25 Answers
SOURCE: Jenn air range model SCE30600B error code FC
replace oven sensor.
Posted on Feb 12, 2009
Getting a PF7 code with beeping on my stove. Reset breaker, didn't fix it. Any help would be appreciated.
GE oven error code "F7" and how to fix it ' AskGene.com
www.askgene.com/.../oven...codes/ge-oven-error-code-f7-and-how-to-fi...
Jun 23, 2007 - The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic ... We have a GE Spectra Oven - GAS - we keep getting F7 errorcodes and the oven will not heat. ... In my case it was the keypad.
Why is my GE Range model number JBP80SM2SS making ...
www.shopyourway.com > Manage My Life > Questions
Apr 6, 2010 - Get shopping advice from experts, friends and the community! I was boiling water on back burner of ceramic stove top GE range Model ... When anyappliance picks up an error code or starts beeping the problem that caused it ...
Jan 08, 2016 | GE Profile 30" Self-Cleaning Slide-In...
I have a Jenn-Air Model SVE47600B/water boiled over
Start by looking at your owners manual which can be downloaded here if you lost yours:
http://www.servicematters.com/maytag_library/docs/16010191.pdf
On page 23 Also called page (1-3) you will see a test procedure, do that first then check the fault code page. Page 26 will detail what the fault codes mean.
F- means there is a fault between the communication boards (replace display board), while FC says the same thing but the result is the different and says replace the PRB. What this tells me is that the problem isnt the board or prb, but that moisture in the area is causing a short, and should be cleaned out with alcohol. If the error code were constant, the board would be bad. In your case, it changes after replug, so I suspect that a thorough clean of the control board area will be all thats needed.
Mar 23, 2010 | Jenn-Air SVE47100 Slide-In Electric...
Oven inop error code f7
This is your ERC ( electronic range control) that has gone out on this unit. We are factory authorized Jenn-Air service and parts supplies and we LOVE the Jenn-Air brands. Our house is full of Jenn-Air appliances, also.
Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we can next day air the correct part to you first thing Monday so you can start cooking for the holidays!
We answer our phones from 7 AM until 9 PM CST from Monday through Saturday and look forward to helping you to get cooking again.
Thanks, Ella
Nov 22, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Jenn air range model SCE30600B error code FC blinks with beeping noise. After resetting the temp down to 350 to keep from burning a pizza error code FC started blinking along with continual beeping. I have...
replace the entire range: Jennair does not know how to design, make, or program electronics. It makes steel boxes that provide heat but electronics - that's not within their ability. Buy a Kenmore or a GE and your beeping problem will go away.
Feb 03, 2009 | Jenn-Air SCE30600 Slide-In Electric...
Sep 09, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Error code
I have a jenn air range gas cooktop electric oven model # svd48600b the convection fan will not turn off and when you attenpt to use oven an error code F-3 appears and beeping sound what part is defective?
Aug 02, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Jenn Air range model SVE47600 Beeping
f7 is the code for a shorted keypad or membrane have your husband disconnect the mylar ribbion from the range and gently clean the end with a pencil eraser then reconnect and try again if that doesnt work replace the touch pad
Mar 11, 2008 | Kitchen Ranges
Jenn-Air- model # SVE47600B
I was cleaning the oven and leaning on the oven door and now when I close the door it is hard to close
Dec 20, 2007 | Jenn-Air JES9860 Electric Kitchen Range
Kitchen Ranges Logo
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
