Question about Zebra Symbol Technologies MC909X-G Series Barcode Scanner
MC9090 723100050044There is no laser light from trigger but ok from yellow centre button
  • 58 Answers
BIZAAR BUT ONE OF MY CLIENTS IS SENDING ME ONE OF THESE UNITS IN FOR REPAIR TODAY....I THINK THE SCAN HANDLE TRIGGERS CONNECTION HAS BECOME DETACHED FROM THE CPU.... if you require assitacne please contact jack@codeo.co.uk or 00441179064587
Posted on Nov 08, 2011
Hp color laser jet cp4025 blinking yellow light
Yellow toner is getting low, or check to make sure your print driver is set correctly for this printer.
Mar 22, 2013 | HEWLETT PACKARD - LASER JETS New - Hp...
Copy light
hi,
did you try to print something from pc? Are the print is ok? If the print is ok and copy is not ok, clean the copy glass.
If your copy and print are not ok, clean the laser unit, check the transfer roller and contacts, check the developing cylinder and contacts,... and try with new drum UNIT!
Nov 26, 2009 | Canon iR 2020i Laser Printer
Trying to install factory cd-cassette combo from a 1999 ford explorer into a 1996 ford crown victoria with only a cassette radio player. need to know wiring data on both vehicles.
Hi and welcome to FixYa,
On your need for the radio wiring of 99 Ford Explorer and a 96 Ford Crown Victoria, see below wiring scheme:
Confirm with a voltmeter on the +12 and an ohmmeter for speaker continuity.
Good luck and thank you for asking FixYa.
Oct 30, 2009 | Car Audio & Video
All 3 Error lights are flashing (4 if you count the GO button)!!
When all lights flash it's a service problem. You press and hold the go button and see what lights are on then.error light means main PCB failure, Toner light means fuser failure, drum light means laser failure. Toner and error light means main motor error, drum plus error light means its a fan failure.
Jun 26, 2009 | Brother HL-2170W Laser Printer
How do you turn off BMW X5 tire pressure light once the tires have been inflated
On some X5's you can do it through the instrument cluster whereas other through the button on the centre console depending on the spec.
On the centre console you'll find the tpc button. It looks like a flat tyre with an exclamation. With the ignition turned off, press and hold this button and turn on the ignition to position 2. You'll notice on the instrument cluster the light go red, yellow, off and then come back on yellow. When the light comes back on yellow release the button and wait with the ignition on until the yellow tpc button goes out. Thats it.
If this hasnt worked you have a different spec and therefore a different way of doing it! Let me know and il guide you through it.
Hope this helps!
May 16, 2009 | 2005 BMW X5
I have a Nikon Coolpix P5100. I use it to photograph my paintings
There could be a number of reasons.
First, Have you tried it in P mode and are the results the same? Then, have you tried taking images in M mode and set the exposure yourself? Do you have the same result?
Second, If you are shooting in P or normal mode the Exposure compensation might have been incorrectly set. On the Navigation control to the right of the OK button is where you can set Exposure compensation. Press it there and you will see some information appear at the bottom and left side of your LCD. The bar on the left will consist of a series of white graduations with the centre one yellow. If you have yellow bars above the centre one then your image will appear lighter as if over exposed while if you have yellow bars that extend below the centre one your image will appear darker as if under exposed. To reset it use the navigation control to scroll either up or down then press OK once it is where you need it.
Last, if that doesn't work, try checking the ISO. With the camera on in P mode press and hold the Fn button at the top left of the LCD. Scroll to Auto using the command dial next to the shutter release and release the button. If it was already on auto you could try setting it on 2000 and seeing what the result are like then. Don't leave it on 2000 as you will get grainy images but you should get lighter shots as it will allow the camera to cope with poor light conditions. Reset the ISO to Auto and if it still isn't working properly you will probably need to get it serviced.
Mar 10, 2009 | Nikon COOLPIX P5100 Digital Camera
Pages printing blank
Resolving white, light lines or streaks (eliminate light stripes)
From the printer, print the Troubleshooting Print Quality Pages.
With Troubleshooting highlighted, press the OK button.
Scroll to Print Quality Problems by pressing the Up or Down Arrow button. Press OK.
Scroll to Troubleshooting Print Quality Page. Press OK.
Evaluate the Light Stripes Test page for missing printhead jets (missing cyan, magenta, yellow or black color bars).
Clean the maintenance unit's wiper blade and empty the waste tray. A dirty maintenance drawer wiper blade can cause white lines and weak or missing printhead jets. Using a clean lint-free cloth or a paper coffee filter, gently clean the blade with a wiping motion across the entire length of the wiper blade.
Dec 20, 2008 | Xerox Phaser 8400 Laser Printer
Question
First, i suggest you try this. Remove batteries then press and hold power button for 15 seconds. Wait a further 1 minute then reinsert batteries and try again.
If no good, try this. If you can get to the MENU mode (in stored pics), scroll right to SETUP, press centre button to OK it. Scroll down to SETUP1. Scroll right, then down to initialize which will be lit yellow. Then scroll right and scroll up when ok will be lit yellow then press centre button to OK it. This will return camera to factory defaults including set up language.
Good luck !
Aug 29, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Laser does not trigger
open the OTL program.
go to 1 - Test Apps
go to 6 - Next Page
go to 1 - Auto Wedge On
do the tests now ;)
Feb 28, 2008 | Symbol MC1000 Barcode Scanner
Printer problems
All four lights flashing indicated a problem only a service center can repair.
Press the Go button and a new set of indicators will appear.
The yellow toner light only indicates a fuser unit failure.
The yellow drum light only indicates a laser unit failure.
The yellow toner light AND the red paper light indicates a main motor failure.
The red paper light only indicates a PCB failure (Printed Circuit Board).
The only thing you can do at this point is to actually UNPLUG the power cord for 24 hours and then retry or if that fails take it to a service center or better yet go pay the $89 for a new unit.
Hope this helps.
Dec 25, 2007 | Brother HL-2040 Laser Printer
Zebra Symbol Technologies MC909X-G Series Barcode Scanner Logo
536 people viewed this question
Top Zebra Computers & Internet Experts
pkwc
Mike
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
