Question about Sony SDM M81 18.1" LCD Monitor
Past week or so, it would occasionally make a zapping sound and the display would flicker slightly. Dust inside maybe. Then yesterday, it required powercycling a few times at the cord in the morning (after it was off and computer slept). Each powercycle will show the display for a fraction of a second then it goes black again. Today, the same thing except the image never shows permanently. Just shows for a fraction of a second.
  • 11,361 Answers
That zapping sound can be coming fromt the lamp assembly or from bad inverter section, to verify if it is the lamp assembly or the inverter board, you will need spare lamps for testing. You can at least do the visual inspection inside the monitor first.
Bad lamps pictures:
http://s807.photobucket.com/albums/yy352/budm/Bad%20backlight%20lamp/
http://s807.photobucket.com/albums/yy352/budm/SONY/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on May 18, 2011
I have a toshiba LED TV Model 40PB200, i bought it two months now. Recently, the audio in port started producing a sound as if microphone is on and the VGA for computer flickers when i connect a laptop on...
One thing is that unless it is usb you should always have the devices powered DOWN before connecting them via" wire electric data cables". it only takes 3 static volts of electricity to damage a circuit board. when you zap you buddy when you wear sox its 20 to 30,000 volts of static electricity so 3 volts would not be known let alone felt or seen. Power down and you will be well not you .
Sep 30, 2013 | Televison & Video
Lennox air purifier zapping sound
This may be an electronic style air filter which causes a bug zapper noise when "zapping" dust. I was out doing some research myself on them which is how I came upon your question. It seems they need to be cleaned carefully; which I am seeking instructions for. Best of luck in your ventures! Do some research, they are expensive to repair if you break them in the process of trying to clean or remove them. This page did a decent job at explaining the why it zaps part. http://dhclimatecontrol.com/filter.htm
Jun 19, 2012 | Heating & Cooling
No video output upon restart.
So it sounds like it's heat-related. Does that video card use a cooling fan? Is the fan still working? Maybe the PC needs cleaning out, you might be amazed at the amount of dust that can build up inside the case.
If you're cleaning be careful not to dislodge anything, or create electrostatic zaps. Leave the power cord plugged in to provide an earth, but turn off the power point. A new 2-inch paintbrush is good for brushing dust out.
If the card has a fan it could be clogged with dust, or may have died altogether. Find someone who knows how to clean or replace it, if that is the case.
Jun 18, 2010 | Intel Systemax NO OS Desktop Computer -...
Eletrical snapping sound
This is normal....when dust passes through this filter it is "Zapped" that's how the electronic air filter works
Oct 25, 2009 | Honeywell HFD-130 Air Purifier
Screen Flicker and goes black
I had this issue with my r700 last week. It can be resolved without any hardware changes/fixes (if you have the same issue which it does sound like).
Samsung are aware of this issue and have released a firmware upgrade for the system BIOS in order to implement a resolution to this monitor flicker problem.
Resources
Visit the following webpage -
http://www.samsung.com/uk/support/download/supportDown.do?group=&type=notebookcomputers&subtype=rseries&model_nm=NP-R700&disp_nm=NP-R700&language=&cate_type=all&dType=D&mType=FM&vType=&prd_ia_cd=05010400&model_cd=&menu=download
Instructions
1.download the file listed
2.double click on the file once downloaded to install the update
Additional
Something you and other r700 users may find useful is that the r700 is known as the np-r700 on the Samsung website-there are lots of useful downloads and guides available there.
// j
Jun 12, 2009 | Computers & Internet
GE JVM1650 Microwave Suddenly Stops
Your magnetron tube is leaking RF energy inside and zapping the main board. It is NOT dangerous as any leakage will be contained inside the unit. You will need a new mag tube and it is covered by a 5 or 10 year parts warranty. Call GE Factory Service at 1-800-432-2737or schedule online at www.geappliances.com
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Rca 62" PROJECTION FLATSCREEN - COLOR PROBLEM/FLICKERING SCREEN
Sounds like the red picture tube could be shorting internally which would cause the "all red" condition. In which case you'd have to replace the red tube. Are there horizontal (slightly slanted) lines through the picture as well when this is happening and a very very bright screen? If so it's most likely the tube.
Oct 06, 2008 | RCA F36645 TV
Mac Mini G4 Flickering Screen at Start Up
Did you check the wires?  Sometimes if you pull one loose it flickers.
Aug 13, 2008 | Apple Mac mini G4 Desktop
Fuzzy, unstable display
This sounds like a high-voltage power supply problem, which would need to be diagnosed by an experienced computer or electronics technician.
Check to see if there is a small focus knob on the back. If so try turning it back and forth three or four times to "clean" it....then adjust for correct focus.
Symptoms like this can also be caused by accumulated dust inside the monitor.
Jan 15, 2008 | Sony GDM-C520K (Dark Gray, Gray) 21" CRT...
Sony SDM M81 18.1" LCD Monitor Logo
48 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
