Question about Tappan TGFS_63 Gas Kitchen Range
My gas oven will only light at 500 degrees and I have to cook everything at this temperature. What is the problem?
2 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: tempature does not heat properly
Replace the oven temperature sensor.
Posted on Oct 27, 2009
Gas Pizza Oven - Heat issues
Many of the Pizza ovens require ceramic plates that line the bottom surface of each oven. These ceramic plates absorb the heat and retain the temperature. I never used our ovens with a bare lower surface, always applied the plates for even heat and distribution.
Mar 05, 2014 | Ovens
Oven temperature does rise and gas smell
MOST LIKELEY YOUR OVEN IGNITOR IS WEAK.REPLACE IT AND YOU WILL BE COOKING AGAIN.
Mar 05, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven not cooking at correct temperature & loses heat
Had a similar issue - but my unit is eight years old. Turns out my issues were my oven ignitors were failing and one of the burners had corroded causing the flame to only light on one side. To fix I replaced two ignitors (apparently they are to be replaced every 3-5 years) and cleaned the burner with a brass wire brush. If you are handy the ignitors are easy to replace - one screw and two wires each. Burner was one screw to remove.
Ceramic ignitors if wearing out can cause delayed lighting of the oven burners and/or reduce the gas flow - hence not heating up.
That was my experience ....
Jan 11, 2010 | Viking VGSC366-6B Gas Kitchen Range
Translate temp gauge numbers to degrees
I recommend you buy a cheap oven thermometer and check the oven temperature yourself. As a gasfitter I know temperature conversions (numbers to degrees) are approximate and I think may be done on purpose so consumers won't complain if they put a thermometer int he oven and it differs from the thermostat. Check the temperature in the centre of the oven. do not use pans and trays that fill the sheld as gas ovens need room to circulate the hot air. Also do not place items in the oven so the top of it is near the top of the oven - otherwise it will burn. I have found when cooking a chicken it needs to be turned otherwist the bottom of it may not be cooked.
Cheers
John
Nov 30, 2009 | Ovens
Amana Gas Stove M/N ARG 7302WW set temp. is higher than desired t
the oven safty valve is goin bad. that the part that most oven burners sits on.
Dec 09, 2008 | Amana ARGS7650SS Gas Kitchen Range
Big 18 pound turkey and no manual
Place turkey on trivit in roaster and add 2 cups oof water. place lid on roaster and seal edge with foil. Preheat oven to 500 degrees.  Place in oven for one hour and turn oven off and go to bed.  Turkey will cook while temperature is coasting down.  Turkey will be still warm in the morning.  We have been doing this for several years and always comes out golden brown and juicey.  Do not stuff bird while cooking.
Nov 30, 2008 | Rival 18 Qt Roaster Oven with Buffet...
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
Lincoln Impenger 1100
hellow my name is ash i sale linclion ovens and repair they have only one burner and they only go up to 600 degree F make sure that the impenger plates one on top and one bottem are possion prapley, 2nd set temp at 500 and 530 f time 6.5 m if still under cook blow use plates with holes
Apr 27, 2008 | Lincoln Conveyor Oven - 1133-000-A
Hotpoint stove
the light only indicates that the oven elements are on.A blinking light i would have checked out for a short
Nov 22, 2007 | Hotpoint RGB745 Gas Kitchen Range
try changing the oven sensor its in the oven looks like a small rod coming out you need to remove 2 phillip screws the take it out
Jun 08, 2007 | Hotpoint RGB745 Gas Kitchen Range
Tappan TGFS_63 Gas Kitchen Range Logo
77 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
