Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
I have an RCA D52W20B. I have to reset the convergence each time I turn it on. The convergence will adjust, but not hold when the set is turned off. I have ordered a FL231 repair kit because the set will also turn itself off after watching it a while. Anything else I need to do?
  • RCA Master
  • 8,617 Answers
The signal board is the usual cause of that symptom. You should be able to locate a signal board from www.tvrepairworld.com
Posted on May 20, 2011
No power
Posted on Aug 01, 2011
How do you adjust color on a RCA D52W20B other than the remote?
Are you running component input on this--If so, make sure the red cable has not worked loose or gone bad.
Apr 28, 2014 | RCA Televison & Video
RCA D52W20B F013C30N4 when turned on the image it green
Does the set continue to play normal except for the green being too pronounced ? Or does the set turn bright green with curved lines then the set shuts down? Let me know and I will assist you.
Oct 15, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My d52w20b rca tv will not turn on and if you hold down the power buton down the led flashes a code 19
All the ITC222 series will blink 19 if they have a no start situation regardless of the problem, Since the set wont power up the Main eprm cant communicate so it blinks 19 which means it cant identify the chassis. When you press the power to turn it on does the power light come on briefly then go out 3 times? Let me know and I will assist you with the problem. Also do you hear any sounds when the power is pressed?
Nov 27, 2009 | RCA D52W19 52" Rear Projection Television
I have a 52 inch rca dlp hdtv. the color is out of allign and the tvs menu convergence adjustments isnt gooe enough, how do i enter the advanced convergence settings. my S/N is D52W23WX32F445C1002. thank...
Turn off your TV. Hold down the Channel Down and Volume Down buttons on the front of the TV. Hold for 8 seconds. The set will boot into the service menu.
I just fixed my convergence issue with this, no parts.
Jun 15, 2009 | RCA HD50LPW175 50" HDTV
Rca tv d52w20b
When you go to the menu can you get the convergence setting at all?
May 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20B picture problem
most likely ifthe convergence option is missing from the on screen menu you will need to replace CL230, DL231, and FL231 you can get those parts with free instructions at the following link,
http://servicemanuals.vstore.ca/
Jan 30, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence problem on rca model d52w23
Replace convergence board or repair it. Try this with TV off Press and hold vol-and ch- at same time hold untill set comes on Now you should be in service menu Go to convergence Adjust the 16x9 mode.
Dec 21, 2008 | RCA D52W23 52" HDTV CRT TV
RCA D52W20B Vert/ Hor Hold Problem
Nothing inside to adjust. try re-soldering the vertical output IC and also the flyback connections RCA has had some issues with the flyback solder connections
Feb 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Adjusting convergence
try unplugging and waiting over night and then repluging it in this will reset the computer
Feb 20, 2007 | RCA P52928 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
103 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
