Question about Ovens
TOP OVEN WORKS OK BUT BOTTOM OVEN DOES NOT HEAT UP
    Genius:
  • 1,156 Answers
There are a number of reasons why you may find that your oven doesn't heat up, and troubleshooting oven heating elements is not too complicated, so you should be able to manage this in a few hours. When you are trying to decide what is the cause of your oven not heating up properly, you should be able to identify the different problems, and also understand how to repair the oven without too much difficulty. If you find a lot of problems, then you may need to provide a different solution, for example replacing the heating element and fittings completely.
Heating Element is Broken
This is perhaps the most common cause of the oven not heating up. The element inside the oven will not become hot if the electrical connections are damaged, or if the element itself is not working. The heating element can be removed and replaced easily, and this is perhaps a very good idea if you have any problems with the heating system of your oven. Test the heating element by firing up the oven with the door open, and your hand close to the front of the element. You should be able to feel it warming up, so if it doesn't, take of the screws which hold it in place, and then unplug the connections. You can take the heating element to a store and they should be able to replace the part for you.
Hope this help in solving the problem.....
Posted on May 17, 2011
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    • 1214 Answers
    SOURCE: bottom oven not working
    A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
    If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
    A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
    Posted on Jan 14, 2009
    SOURCE: Top oven will not heat up
    JKP55 The top oven would not heat. Got it fixed for $261.00 with tax. The bake element in the upper oven was bad. My oven unit is 14 years old.
    Posted on Feb 07, 2009
    • 13 Answers
    SOURCE: Neff U1721 bottom oven not heating fan & light are ok
    Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
    Posted on Jul 29, 2009
    heatman101
    • 43501 Answers
    SOURCE: Kenmore Gas Oven doesn't heat
    Here is a tip that I wrote that will help you with that problem...
    The ignitor for your burner has faied...
    http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
    heatman101
    Posted on Apr 07, 2010
    Kenmore electric oven bottom element not working
    check thermostate control sensor its locate behind the heating element. check continuty .if its fail .replaced correct value.
    GKM
    Jan 07, 2014 | Ovens
    Whirlpool akz161 top oven. The lower heat element is not working how do l access this as l need to fix it myself
    open door if you can see screws at element ends remove them and change or you will have to do it from the rear
    Nov 16, 2013 | Ovens
    Top oven does not heat-although bottom oven is ok.
    If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
    Check out this tip that I wrote about the Oven not heating problem..
    Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
    http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
    heatman101
    Jul 29, 2010 | Whirlpool GBD277PD Electric Double Oven
    Oven won't heat
    hi, sounds like the heating element
    Mar 07, 2010 | AEG U3100-4 Electric Double Oven
    GE JTP56 double oven controls OK top OK bottom no heat
    have you inserted the business card as described in the solutions?
    Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
    Jun 08, 2009 | Neff U1721 Double circotherm Electric Oven
    Dear customer,
  • Test the element
    Jul 08, 2008 | Ovens
    Fan assist wont heat oven
    the ring element may have blown. if it works ok with the top and bottom elements, (the convection oven) then it is likely the element surrounding the oven fan.
    Jun 25, 2007 | Baumatic B187 Stainless Steel Electric...
    Ovens Logo
    249 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
