Question about Canon PowerShot SD3500 IS / IXUS 210 Digital Camera
Hi, I purchased a replacement LCD screen for my SD3500 from Rongstar DigitalInc. Since I've learned they do not have a good reputation and to make matters worse the LCD screen will not function properly. It seems to light a bit and the "touch" seems to cause camera to beep as if the touch screen were working, but no images or "scene to take" is viualized ion the screen. As I said only a faint lighting ( appears to be black as if no light coming off it) . Help! I am sure it is connected correctly. Have you heard of this problem before ??
I had a similar problem with a Canon camcorder. I replaced it with a new LCD screen from Rongstar Digital, and it works! Saved a $350 camera for $20! However, installing the new LCD was very difficult, and is not meant to be done by amateurs. You have to be sure the tiny connectors and screws are placed exactly right and in the right order. Don't blame the seller if it does not work!
Posted on Aug 03, 2012
SOURCE: Canon Powershot has black LCD screen
Best Solution worked for me?!?!?. Not sure if following the instructions got the screen to come back, but it did come back. I just flipped it over to movie messed with the settings and then open up the battery door which turned off the camera. Closed the door, Flipped to photo and turned it back on and it workd. This is the second PowerShot that I have had, current SD750 and an old S230, to do this.
Posted on Jul 16, 2008
  • 18 Answers
SOURCE: Canon S215 viewfinder and lcd display screen blk
There is a temporary fix that works sometimes but eventually it will stop working alltogether. If canon can't help, might try this:
http://cgi.ebay.com/Repair-blank-black-pictures-S2IS-canon-powershot-S2-IS_W0QQitemZ300293064869QQcmdZViewItemQQptZDigital_Cameras?hash=item300293064869&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
Posted on Feb 11, 2009
t00nz
  • 4738 Answers
SOURCE: lcd shows black in picture taking mode
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on May 10, 2009
SOURCE: when the camera is turned on the lcd screen is
I used to have that, try pressing the DISP. button when the camera is in picture mode. The black screen should go away. That's how i solved the problem when i had it.
Posted on Jul 05, 2009
t00nz
  • 4738 Answers
SOURCE: Canon A95 - Blurred/out of focus image on LCD or black screen
By the way, here's the info for India:
http://www.canon-asia.com/index.jsp?fuseaction=support&prod_type=image-phenomena_notice
http://www.canon-asia.com/index.jsp?fuseaction=contactus&prod_type=sales_service_in
Where to get a cheap LCD screen replacement?
Try eBay. Do a search for Dell Inspiron Mini 1012 screen You will get results from $36 and up. I've never dealt with any of these particular sellers, but most of them have great reviews and I have used replacement screens for others computers that I purchased on eBay.
Sep 21, 2012 | Dell Inspiron Mini 1012 Netbook...
My brother embroidery machine's lcd screen is blank
Hi.
On page 81 of your manual it says to adjust your LCD screen brightness.
If you can't find your manual... go here and download it.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_PE_770%20%20%E2%80%93%20New!_EN_1819.PDF
Jul 13, 2012 | Brother Sewing Machines
46in Vizio LCD HDTV distorted black picture when tv is turned on
Hi There are three things that can cause this problem. Your lcd screen, t-con board or the signal board. Most likelly in your case since you say it's only half the screen it's going to be your t-con board. You can try removing it and cleaning all the contacts and replacing it see if that helps. If that doesn't help then replace it. If that does not solve it then it's going to be your screen.
You can get parts at www.interliquidparts.com
Nov 28, 2011 | Vizio VW46LFHDTV10A 46 in. LCD TV
My screen intermittently goes blank (without lighting). I can see that there is something displayed and a connection to an external monitor shows that everything is working fine. I've disassembled the...
I've seen this problem time and time again. Replacing the inverter fixed it every time. HOWEVER it could always be the CCFL backlight as well. Both fortunately are VERY inexpensive. Changing the inverter is easy but the CCFL will be a little harder. Take your time and remember how to put it all back together and you'll save that $100. I'm sure it's either of those two that's causing the backlight issues. NO NEED to change the entire LCD.
Aug 22, 2011 | Acer TRAVELMATE 8371-944G25 LAPTOP LCD...
I have a Videocon 42"
Are all of the functions still working on the TV? If so, then the good news is that it's simply a bad screen, but the bad news is that replacement screens are impossible to come by unless you are an Authorized repair center for Proton. The only option you have is to replace the TV, or contact a shop.
From what I've found out, Protron and Spectroniq are the same company. I just visited the Protron web site and it has not been updated since 2007. I believe the company is no longer in business and will doubt if you will find a Protron Service Center. You are very lucky to find a repair shop that will attempt to work on the TV, most will not. The internet is plagued with issues with this TV. Even the cost of the screen would not be worth repair.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jul 22, 2011 | Protron PLTV-26 26 in. HD-Ready LCD...
Hi I am from the Philippines. I have a ASUS G1S-X1. While I was working my screen went black. I suspected of a defect on the video card. I tried to to boot my laptop, I can here the sound of booting but on...
I've seen this problem a few times with laptops my family/co-workers have. If it's like their problem, you should be able to plug in an external monitor and see on the screen. If that works, it's either your LCD screen or your LCD backlight inverter...One of the ways to tell whether it's one or the other is try to shine a bright light directly at the screen. If you can see anything on the screen, it means it's the backlight inverter. If it's still completely black, it's your lcd screen. Both can be replaced fairly easily, just be sure to look really well, because if you purchase the (more expensive) LCD screen, replace it, and still have the problem, you'll need to do the backlight inverter anyway. You can typically find instructions for replacing them online somewhere.
When plugging in the external monitor, wait for a while to see if it will boot to your desktop, then if there's nothing on the screen look at your keyboard. There should be a button on there to swap projection modes (usually have to hit fn+f5). Try hitting that a few times just to be sure. If you still can't see anything on the monitor, it doesn't mean it's not necessarily a software issue. Download/burn a live CD (any linux version will work) and try booting from that to rule out any possible software issues.
Jun 13, 2011 | ASUS (G1S-X1) PC Notebook
Dropped phone has a bunch of line on display screen on a Samsung comeback
HI there,
it sounds like you've inadvertently broken your LCD screen. These are fairly cheap to replace:
http://www.samsung-accessories.net/samsung-lcd-screens/1380/
Although not for the non tech savvy. If you can't do it yourself, seek a local electronic repair shop and have them do it for you.
May 16, 2011 | Samsung Comeback Cell Phone
I am Looking for a Camera Canon User Guide in english for an IXUS 210. Can you help me.
The IXUS 210 is called the SD3500 in some parts of the world. You can download the English manual for the SD3500 (and more) from the manufacturer's web site at
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/
powershot_sd_series/powershot_sd3500_is#BrochuresAndManuals
May 06, 2011 | Canon SD3500 IS Digital IXUS 210 Digital...
Model D40 Moultrie camera. LCD screen only shows dots, not legible words. Batteries are brand new. Camera is less than a year old.
may be it's a lcd problem see the manual it guied you to the depth
if not contect your service provider neairest you
Sep 21, 2010 | Cameras
Canon PowerShot SD3500 IS / IXUS 210 Digital Camera Logo
487 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
