Question about Whirlpool GEW9250 Electric Dryer
Model GEW9250PLO duet dryer - press start in any mode and it clicks then sensing light comes on - dryer will not start. I have cleaned the vent, took front lower panel off and cleaned area. Removed wires on thermal fuse and tested with ohm meter on Rx1 - got 0 ohms. Hot wired the wires from thermal fuse together just as a by-pass test and dryer still clicks then goes to sensing. Please help -- thanks
ronpar
  • 27 Answers
SOURCE: Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
Posted on Jun 29, 2008
docjohn174
  • 943 Answers
SOURCE: Whirlpool dryer won't heat
hi. thanks for letting me answer.the only part that was not mentioned. is the timer contacs Y & R . the heat contacts in the heating circuit. thanks
Posted on Sep 29, 2008
TheMobilian
  • 8220 Answers
SOURCE: Kenmore 84152 /94152
probably the heater
Posted on Jan 15, 2009
  • 112 Answers
SOURCE: Can I test dryer timer to see if its any good?
Check if you have 220 at the terminal block. The power is 220 hot to hot and 110 for each leg to ground. Generaly the has two speeds (220 regular and 110 for gentle). There are two heating elements that are ciontrolled the same way. The gentle cycle uses one leg and the heat ing elements use the other. The answer is how the dryer is set. Knowing that and using elmination you will find the problem in the controlls because the heating elements work or thew are open. The motor has two windings or it works or it works or has an open. I could not find a schematic but you may see it on the back oe a piece of paper in the controlls. I have faith in you finding the problem very quickly from what you said and what I told you. Good luck. Don't forget to cycle (turn them off and on) your breakers to make sure one is not intermittent.
Posted on Aug 17, 2009
ronald_kate_
  • 111 Answers
SOURCE: I have a Kenmore, 70 series, Electric dryer,the
Hello, firstly you have it set on volts not OHMS. You need to test the actual part. However I can tell you that from what you are discribing and personal experiance it sound like your heating element is gone. Please if you have never done this before be carefull, electricity is dangerous and doent discriminate as to whot it zaps. I hope thi is helpful.
Posted on Nov 07, 2009
Whirlpool duet dryer won't start
whirlpool duet dryer has power but will not start--when I press start, it beeps once and the sensing light comes but the dryer doesn't start
Nov 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My front loading dryer Whirlpool Duet GEW9250PLO will not come on even after resetting.
check for electrical power if you have 220+ then check the door switch, jump the wirers if necessary. If switch ok, then move timer to 20 minutes and press start--if timer ok then you must have a broken wire in the wiring harness. Good luck.
Sep 04, 2008 | Whirlpool GEQ9800L Electric Dryer
Whirlpool Duet dryer won't start F30
well the sensing light will stay on till it feels wet clothes against it if you in auto dry mode it says it wont start without feeling wet clothes against the silver bars in the vent housing it says it will run in manuel mode even if it doesn't feel them pull the top off the dryer and on the right hand side is a tech service sheet in a plastic bag see what it says
Mar 30, 2008 | Dryers
Whirlpool Dryer wont start
Possible door s/w or thermal fuse. If its blowing thermal fuses with a clean and avg vent run check the relay, cycle unit with no heat fuction if the heat still comes on replace the relay board. Call your local servicer.
Mar 16, 2008 | Dryers
Whirlpool dryer,duet
check the door switch for operation, if the machinr thinks the door not closed == no operation
Jan 11, 2008 | Whirlpool GEW9250 Electric Dryer
DUET Dryer M# GEW9200LQ0 - Not cuttinh on
coasty...I'm a believer in starting small and going bigger. First, turn off power at the breakers and then back on. You must do this on both sides of the line. If this resets everything, you're good. If not, check the rest of the wiring. Still no, then you're going to need that circuit board.
Dec 08, 2007 | Whirlpool GEW9250 Electric Dryer
Duet Model GEW9200LW0 Dryer will not start-Code 3E
I have a GEW9200LW0 whirlpool dryer, that displays 3E when I try and start the dryer. nothing happens,All i get is the 3E code.
Dec 08, 2007 | Dryers
Whirlpool GEW9250 Electric Dryer Logo
173 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
