My number keys on the left no. 4 types a daimond shape no 1 and 7 don't work the rest work fine?
  • 134 Answers
Just replace the keyboard....for another
Posted on May 18, 2011
HP Pavilion dv5 gets hot in left hand corner. I've had this laptop for 9 months with no problems. This morning I noticed it getting very hot on the left front corner where my left hand rests. About...
HP Tech Support & HP help phone number 1-8002044427 for troubleshoot HP problems.Our certified technicians are available 24/7 to deal with your HP ...
Jun 01, 2017 | Computers & Internet
When I type 12!/5!7! I'm getting 2.01180672e10. My answer is suppose to be 792. Please help.
Somehow you're calculating 12!/(5!/7!).
Press 1 2 MATH left-arrow 4 / 5 MATH left-arrow 4 / 7 MATH left-arrow 4 ENTER to calculate the desired value. Alternatively, you can press 1 2 MATH left-arrow 3 5 ENTER or 1 2 MATH left-arrow 3 7 ENTER to calculate the same thing.
Aug 10, 2011 | Texas Instruments TI-83 Plus Calculator
Battery went dead radio security kicked in and i don't have the code
I'm hoping that you are in the states, because I have a free stateside number that you can call. Here are a full set of instructions to get you sorted out:
If it says "OFF" turn the key to ACC for 5 minutes with the radio on, and displaying "OFF". After 5 minutes the radio will turn itself off. Turn the key off then back on again. The radio should now display "CODE". If this doesn't work disconnect the battery for 5 minutes, and repeat the 5 minutes radio on displaying "OFF" with key in ACC until the radio turns itself off. Now that it says "CODE" go to step 2. The radio must display "CODE" to enter unlock code.
  • 2 Find the radio serial number The radio's serial number is on the left side of the case that is inside the dashboard. You will have to remove the fascia that is around the radio carefully to reveal it. In most models you can use a small dental style mirror to see the code without completely removing the radio. If you can't see it this way you will have to take it all the way out. Don't disconnect anything just pull it out far enough to see the numbers. The model number starts with MNxxxxx, this is not the number you need. The serial will be an 8 digit number, no letters. It will be close to the model number however.
  • 3 Now that you have your serial number call Mitsubishi Motors of North America at 1-888-648-7820, M-F 7am - 4pm Pacific time. They will give you your unlock code for free.
  • 4 Now that you have your unlock code you have to enter it into your radio. They should take you through this on the phone, however, here's how:
  • The 1,2,3,4 preset buttons on your radio toggle up only through the digits 0-9. The 1 preset button is the first digit holder, and so on for the 4 digit code. If you go too far just keep pressing the button, and it will go back to 0, and you can get back to the right number. If your unlock code has a 0 in it you have to press the button once to get to 0. It starts with a dash (-). This doesn't count as the 0. For instance if your unlock code is 0873, you will press preset 1 once, preset 2 9x, preset 3 8x, and preset 4 4x. Once you have the correct number in the diplay press the "CD" button, and it will unlock your radio. If you didn't do it right, it will display "ERR1" before going back to the "CODE" display. Don't mess up more than twice. After the third failed try things get a lot more complicated!
    Aug 09, 2011 | 1998 Mitsubishi Eclipse
    The right position of the finger in the keyboard,on what particular letters do each finger were assigned.
    I don't know exactly what you're asking here, but if you mean the home keys, where your fingers are supposed to rest for touch typing, then it's: ASDF for the left hand, and JKL: for the right. Index fingers on F&J, middle fingers on D&K, so on.
    Jul 16, 2011 | Lenovo Keyboard
    How to use number keyboard
    You use the number pad as follows: your index middle and ring finger rest on the 4, 5, and 6 keys. The index finger reaches up or down to use the 7, 4, 1 keys. The middle finger uses the 8, 5, 2 keys. And the ring finger uses the 9, 6, 3 keys. And the thumb is for the 0.
    Jun 18, 2011 | Computers & Internet
    My 1tb hard drive external don'tseem to be recognised.the driver is in device manger but it is not showing in my computer
    First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
    Jun 18, 2011 | Samsung S2 Portable HX MU010EA 1 TB...
    Router working fine,but when i try to make it a secure system,even i cant get onto the wifi
    WIRELESS SECURITY ISSUES
    Step 1 : Connect Router - Computer ( Wired)
    Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
    Step 3 : On the left under wireless click wi - fi protected setup
    Step 4 : Leave the password blank and click on submit
    Step 5 : Disable it and Click on apply changes
    Step 6 : On the left under wireless click Security
    Step 7 : Enable 64 Bit WEP
    Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
    Step 9 : Click apply changes
    Step 10 : on the left under wireless click channel and SSID
    Step 11 :Change the Wireless channel to 6
    Step 12 : Change the SSID to a different name ( no Spaces )
    Step 13 : Click apply changes
    Step 14 : Now Scan and connect to this network ( Wireless )
    Let me know if it works
    Dec 17, 2010 | Belkin (F5D7230-4) Router (587009)
    Belkin My Essential Wireless Router ver 1000 i'm unable to link the rest of my home appliances with it. They pick up the signal but the WPA key doesnt work
    Hi Friend,
    Please follow the below steps so that you can connect all the wireless home appliances
    Step 1:I hope you may have a desktop computer
    Step 2:Open an Internet explorer and type 192.168.2.1
    Step 3:Now you will see a belkin router setup page
    Step 4:On your left hand side click on Security,it will prompt for Login Password,you leave it blank and click on Submit
    Step 5:Now change the Security type from WPA to 64-bit WEP or WEP
    Step 6:In Key 1 you have 5 small boxes,type any two numbers in each box only in KEY 1,,please make a note of the numbers you have typed in each box and then click on Apply Changes
    Step 7:Now try to connect all the home appliances in the wireless,it will ask for WEP Key,now you have to type the numbers which you entered in the belkin router and then connect it.You will be able to work
    If you have any clarification,please feel to free to reply
    Regards,
    Ayyasam
    Mar 10, 2010 | Belkin My Essential (ME1004-R) Wireless...
    How are the coil packs numbered, whats the firing order and what is the cylinder numbering "as in left side right side " 1987 oldsmobile deltaa 88 3.8 v6
    The coil packs are numbered 1-4,5-2,3-6.The firing order is 1-6-5-4-3-2.The 1-3-5.cylinders are in front and the 2-4-6 are in the back.There are 2 types of coils.Type 1 the coils are all in one pack.A complete system.Type 2 the coils can be replaced separately.(ie.)1-4 are separate and 2-5 so on.Good luck.
    Nov 30, 2009 | 1987 Oldsmobile Delta 88
    Spring w/2 tiny rollers loose
    On my i455 all the rear slots are occupied. The front only has 2,5,7, 8 occupied. It works fine that way. I think the rear is more critical than the front to proper paper feeding. Good luck
    Jan 16, 2007 | Canon i 450 InkJet Printer
    Computers & Internet Logo
    14 people viewed this question
    David Payne
    David Payne
