Question about Kenwood Car Audio & Video
My kenwood kdc-x983 will not pick up my bluetooth anymore. My phone does say its found and says it contected but the radio don't find my phone. Is there a way to reset the entire radio or something??
  • 78 Answers
SOURCE: Kenwood car stereo KDC-W3534 : warning message PROTECT
This is a safety feature and it usually suggest that there is a problem with the internal amplifier, it could also be a trapped speaker wire. Remove the radio and check if any of the cables have been damaged and if you power up the radio with the speaker plug disconnected that will tell you if the fault is in the car or the radio
Posted on Dec 23, 2007
Lounatech
  • 23 Answers
SOURCE: i pressed my radios reset
Per page 26 in the following manual: http://www.sirius.com/pdf/manuals/kdcx679.pdf
The security code can't be changed, once it's set. Did you go through the sequence of steps on page 26 of the manual?
If you did (in fact) lock in and approve a security code, you'll need to contact Kenwood support and prove ownership (e.g. receipt) before they can give you instructions for resetting the code.
There is a hack for the ASIC that stores the security code out on the Internet (use Google to find it).
If my response helped you, please reward me with positive feedback (Fixed it!). Thanx!
Lounatech
Posted on Apr 24, 2008
i had the same problem and i just disconnect the battery and and reconnect it and everything works fine!! try it
Posted on Aug 28, 2008
reynosaelect
  • 165 Answers
SOURCE: Kenwood KDC-C717 - E-99 error
Reset the unit ithe reset button is on the cd changer
Posted on Mar 24, 2009
SOURCE: Problem with Demo mode turning off Kenwood KDC-WF431
Hello. Have the same problem. Have just downloaded the Manual in German. It says In Standby Mode use the small joystick up to FM or AM till it says DEMO OFF and then press the small joystick for 2 Seconds. Hope this helps.
Paul
Posted on Aug 18, 2010
Hi, this is Angel, My radio is a kenwood KDC-MP 238. The display said Bluetooth unit ready, how do I pair the radio with my phone? Thank you.
Hi Angel, you will need to use your phone to connect, search from phone for connection relating to radio......like Kenwood or KDC-MP 238 and then accept!
Jan 30, 2015 | Kenwood Car Audio & Video
Kenwood kdc838u
Kenwood KDC-BT838u
After a call it will not go back to radio, just says call on the display. i can make calls on it. i have to disconnect my phones bluetooth to get the radio on, one or the other. whats up with that?
Nov 15, 2013 | Car Audio & Video
I have a Kenwood kdc -mp245 and when its on it reads protect. How do I stop that?
you need to check all your speakers first. just because they play don't mean they aren't blown. This protects your radio from blowing out any channels. Once you replace that bad speaker or shorted out speaker, reset the radio and you are good to go.
May 21, 2012 | Kenwood Car Audio & Video
Will a Kenwood KDC-HD548U work in a 2001 Monte Carlo
I am sure that you could make it work but you would loose your message center.
Dec 31, 2011 | 2001 Chevrolet Monte Carlo
Ive got a vauxall astra and just taken the sterio out of this as it did not work .ive rplaced it with a kenwood kdc 237 cd player which plugged straight in ,only problem is if i store a radio station...
You will need to wire into the permanent live , if the unit has bluetooth then you pair the unit with the phone and play your tracks via bluetooth.
Aug 09, 2011 | Kenwood Car Audio & Video
How do I connect the bluetooth from the radio to my phone?
This radio is Bluetooth "Ready" and will not pair to any blue tooth device until an additional peice of hardware is purchased and installed. Page 13 of the manual describes this as a "Bluetooth HANDS FREE BOX.
Unless you have purchased this and installed it - pairing is not possible. I hope this helps & good luck!
Mar 23, 2011 | Kenwood KDC-MP238 CD Player
Kenwood kdc-mp242 main sceen doesnot light up anymore or when it wants to,radio work well
you probably have bad solder connections on some surface mount resistors inside of the radio. they would be on the right side of the radio as it is facing you. they need to be resoldered.
Sep 28, 2010 | Kenwood KDC-MP242
KDC-W7537U model number Code for bluetooth
most of the default codes are 1234, 0000, 1111 unless changed by the user. if this doesn't work, you can always do a hard rest of your radio by pressing the small pin hole button on the face of the radio.
hope this helps
Oct 04, 2009 | Kenwood KDC-W7537U CD Player
Need to disable bluetooth cell phone feature.
it is specifically made for iPod - iPhone. You must be near a vehicle that is accepting a call on a Kenwood.
The Kenwood Excelon KDC-X493 CD receiver was built from the ground up to accommodate an iPodĀ® in your vehicle. This versatile stereo features a front-panel USB input for connecting and controlling your iPod, along with a 13-character display that shows off your artist and song info.
Looks like there is no way to disable Bluetooth. What you could do is borrow 5 phones and add them to the system. It will ignore any after 5 are installed.
Kenwood KDC BT742U Instruction Manual Bluetooth Setup Registering...
Your manual is here and there is very little to be found with the search word 'disable', I suspect because that is what the unit is sold for.
Car Electronics Support Information Kenwood
Apr 23, 2017 | Car Audio & Video
Car Audio & Video Logo
37 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
