Question about 3Com (3crwe454g72-bundle)
I have a 3 com router , my note book detects the router and signal strenghth is good too , however wi fi connectivity is not there i do not remember the password hence could not log on to http:// 192.168.1.1 as well , i tried to reset the router as well but of no use , can i establish wi fi connectivity with my router , if yes how
  • 394 Answers
Try these combination of ID and password for your router.
Hope this will help you.
Thanks for using FixYa.
Posted on May 17, 2011
Thermostat recognizes wifi but remains off-line
f your thermostat either displays a no Wi-Fi icon on its screen or shows up as offline on the Lyric or Total Connect Comfort app, it is missing the connection to the Wi-Fi network.
A few preliminary things to check:
  1. Does your thermostat have power? If not, check to make sure your C wire (common wire) is connected to your Honeywell thermostat. All Wi-Fi and connected thermostats (except the Lyric Round model, which can operate using Phantom Power/Power Stealing) requires a C wire to power your thermostat. Regardless of model, if you use Apple HomeKit with the thermostat, a C wire is required. If you are not sure that you have a C wire, please reference our Thermostat Wiring Compatibility page for more information.
  2. Honeywell Wi-Fi thermostats are only compatible on the 2.4 GHz frequency. Newer routers can operate on multiple bands, usually 2.4 GHz and 5.0 GHz. Please check that your router is emitting on the 2.4 GHz frequency.
  3. Check the distance between the thermostat and the router to ensure that the thermostat is in range of a Wi-Fi signal. A simple way to check this is by looking at the Wi-Fi signal range on a mobile device when standing near your thermostat, but note that most mobile devices usually pick up 2.4 GHz & 5.0 GHz Wi-Fi signals. In extreme cases a Wi-Fi range extender or repeater may be needed to ensure you have sufficient 2.4 GHz Wi-Fi coverage throughout your house or business.
  4. Check that your router's firewall doesn't block the thermostat.
In addition, please follow the next steps:
  1. Make sure your Wi-Fi router is powered and broadcasting. Restart your router by pressing the OFF/ON button or by unplugging the device from the socket for approximately 5 seconds and plugging it back in.
  2. If the problem persists, please reset your thermostat. Reference your user manual for instructions on how to reset your thermostat. The manual or quick start guide will have come inside your thermostat's packaging.
Feb 20, 2018 | Computers & Internet
I have a Roku in my bedroom & when I try to watch Netflix it just spins & spins & takes forever to load. Once it starts, it stops & starts spending again.
First step, of course, is to unplug the Roku for 10 seconds then plug it back in again and let it connect.
Assuming a Wi-Fi connection is what you are using, it is possible (likely) that your Roku is too far from the Wi-Fi router. Your best solution is to relocate the Wi-Fi router closer to your Roku, or to get a signal booster to extend the range of your Wi-Fi signal.
On a more technical note, your Wi-Fi router may be broadcasting on a channel that has lots of conflict with other Wi-Fi signals in your neighborhood. Changing the broadcast channel requires that you have an administrator login to your router and can make changes. You might have to call your service provider and have them make the changes for you (if you smile right over the phone, they may give you your router's login information, but don't count on it). Best channels to select are generally 1, 6 or 11 to avoid overlap with other channels.
If you have a smart phone and can download an app, look for a Wi-Fi Analyzer app (free). This will show you the other signals around you, what channel they are broadcasting on, and the strength of the signal.
Sep 06, 2017 | Computers & Internet
How can I connect to router with galaxy tab4 and set up for exteNing WiFi signal
To help you connect to the internet via WiFi from your Samsung Galaxy Tab, follow the steps given below:
- First activate the Wi-Fi connectivity: on the Home screen, press the 'Menu' option and then click on 'Settings'.
- Now click on 'Wireless & Networking' and then 'Wi-Fi Settings'.
- Click 'Enable Wi-Fi'.
- The check mark will turn green and your device shall automatically search for available network.
GuruAid.com
May 19, 2016 | Computers & Internet
Can't connect iPhone 5s and hp 1220c
Sir/Madam
iOS: Troubleshooting Wi-Fi networks and connections Symptoms This Issue is Related To Your apple Mobile And Make Sure You Already Install HP Printer Software In Your Desktop or Laptop. If yes I suggest you perform below Solution for Your Apple 5s and HP Priter Connectivity Issue:
Learn how to troubleshoot WiFi.Issues you may encounter while using your iPhone, iPad, or iPod touch.
Resolution Occasionally while using your iOS device, you may notice unexpected Wi-Fi behavior: Difficulty locating or connecting to a network
Unexpected Wi-Fi signal strength or disconnects
Inability to access the Internet
Not automatically connecting to WiFi when expected
Follow these steps to troubleshoot the above issues:
1.Be sure you're in range of your Wi-Fi router (access point).
2.TapSettings WiFiand turn WiFi off and on. If your Wi-Fi setting is dimmed,follow these steps.
1.Confirm that your Wi-Fi router and cable or DSL modem are connected to power, turned on, and connected to the Internet. If not, refer to your network administrator or Internet service provider (ISP) for assistance.
2.Restart your iOS device.
3.Tap Settings WiFi and locate the WiFi network to which you're connected.
4.Tap and Forget this Network.
5.Try to connect to your desired Wi-Fi network.
Note: You may need to enter your Wi-Fi password again if your network requires one.
6.Turn your Wi-Fi router off and on. If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
7.Update your deviceto the latest version of software.
8.Update your Wi-Fi router to the latest firmware. For AirPort Base Stations,install updates using the AirPort Utility.
If the issue is still unresolved Follow the steps below for the issue you're experiencing.
Collapse All'Expand All
Unable to locate a Wi-Fi network
Unable to connect to a Wi-Fi network
WiFi disconnects or signal strength is less than expected
Unable to access the Internet while connected to Wi-Fi
Unable to automatically connect to Wi-Fi
Additional Information Find information onconnecting to a Wi-Fi network.
Some third-party routers may not be compatible with all iOS devices, even after updating to the latest firmware. If your iOS devices can successfully connect to other Wi-Fi networks, contact your router's manufacturer to ensure that your router is compatible with your iOS device.
See recommended settings forconfiguring your Wi-Fi router for use with iOS devices.
Notes
1.iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models supportWLAN.
2.If needed, please consult with your network administrator (which may be your Internet Service Provider) for assistance with this step.
3.iPhone 5, iPad devices, and iPod touch (5th generation) are the only iOS devices that can connect to 5 GHz networks.
If You Still Haveing Problem then Visit official Below Apple Website URL Link:
http://support.apple.com/kb/ts1398
Or
In case you still having HP Printer Issue Then Follow Us On:
HP Printer Support
Feb 12, 2014 | HP DeskJet 1220c InkJet Printer
Finding router ssid
The SSID is not an indication on a label on the Wi-Fi device, it is the identifier broadcasted by the device ; to find it, two possibilities :
1) if you remember its password, access the setup of the wi-fi device (your router) ; this is done thru any computer connected to the router : simply enter the IP adress of the router (try 192.168.0.1 or find the right one using the ipconfig command) in the browser, and navigate to the wi-fi settings.
2) if you can't access the router, go to the wi-fi settings of your smartphone or tablet or netbook, and find he way to show the list of the access points available in the surrounding - yours is probably the first one (the stronger signal) in the list.
Good luck.
Oct 22, 2013 | Samsung Tab Tablets & eReaders
Hoe can i connect my ipone to wiifi on my belkin router
Wi-Fi settings determine whether iPhone uses local Wi-Fi networks to connect to the Internet.
Turn Wi-Fi on: Choose Wi-Fi and turn Wi-Fi on.
Join a Wi-Fi network: Choose Wi-Fi, wait a moment as iPhone detects networks in range, then select a network. If necessary, enter a password and tap Join (networks that require a password appear with a lock icon).
Once you join a Wi-Fi network manually, iPhone automatically joins it whenever the network is in range. If more than one previously used network is in range, iPhone joins the one last used. When iPhone is joined to a Wi-Fi network, the Wi-Fi icon in the status bar at the top of the screen shows signal strength. The more bars you see, the stronger the signal. Set iPhone to ask if you want to join a new network: Choose Wi-Fi and turn "Ask to Join Networks" on or off. Join a closed Wi-Fi network: To join a Wi-Fi network that isn't shown in the list of scanned networks, choose Wi-Fi > Other, then enter the network name. If the network requires a password, tap Security, tap the type of security the network uses, and enter the password. You must already know the network name, password, and security type to connect to a closed network. Some Wi-Fi networks may require you to enter or adjust additional settings, such as a client ID or static IP address. You can type it manually by login onto the Belkin's network page using the browser and by copying the static and dynamic IP address.
Feb 05, 2011 | Belkin (F5D7230-4) Router (587009)
I purchased a new IPOD and I can not access the wifi from my Linksys wireless router.. I reset my Linksys router to try to solve this problem. And at first when the light was amber I was able to have...
Resolution If you know there is a nearby Wi-Fi network, but you are unable to locate it on the Settings > Wi-Fi screen:
  • Move closer to the Wi-Fi router or hotspot.
  • If you are using a personal Wi-Fi network, verify the Wi-Fi router is connected to power and turned on.
  • Wi-Fi networks configured as "closed" or "private" do not broadcast the network name to Wi-Fi devices.
    • Join a "closed" or "private" network by tapping Settings > Wi-Fi > Other and entering the Wi-Fi network name, security, and password.
After joining a Wi-Fi network, if you notice the signal strength is low or intermittent
  • Check for any sources of potential interference.
  • Remove any cases or attachments on your device that could interfere with a Wi-Fi signal.
If you are unable to access the Internet while connected
  • If you are using a commercial Wi-Fi network that requires a special login or subscription, see this article for more information.
  • If you are in a location with multiple Wi-Fi networks, verify that you are selecting the correct network.
  • Verify that the Wi-Fi network settings are correct:
    • Tap Settings > Wi-Fi.
  • You can configure network-specific settings, including IP address, DNS, and Search Domain settings.
  • Use "Forget this Network" to reset settings for this particular Wi-Fi network, including the password. This is also useful if you identify a network issue and want to prevent the device from automatically using this network in the future.
  • Use "Renew Lease" to acquire new IP address, DNS, and Search Domain information from the Wi-Fi network.
  • Note: If the Wi-Fi network uses MAC address filtering, you will need to add the MAC address to the access list for the Wi-Fi router. The MAC address for your device is listed as the Wi-Fi Address in Settings > General > About.
If you are still unable to join a Wi-Fi network, or are unable to access the Internet while connected, try the following
  • Restart the device
    • Hold the power button until "slide to power off" appears. Slide to power off your device. When it is off, press the power button to turn it back on.
  • Reset network settings by selecting Settings > General > Reset > Reset Network Settings. Note: This will reset all network settings, including passwords, VPN, and APN settings.
  • iPhone only: If you continue to experience issues, consider turning off Wi-Fi and using the cellular data connection instead of Wi-Fi.
Additional Information If using a Wi-Fi router at home, refer to your user manual/documentation to assist you with some of these suggestions.
  • Check the manufacturer's website for your Wi-Fi router for firmware or software updates.
  • Verify the Wi-Fi router can broadcast an 802.11b/g signal. If using a 802.11n Wi-Fi router, consult the manual/documentation for how to configure the Wi-Fi router for 802.11b/g compatibility.
  • If you are using multiple WEP keys on your Wi-Fi router, try configuring your Wi-Fi router to use only a single WEP key.
  • Try or resetting (or turning off and then on again) your Wi-Fi router. Note: If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
  • Disable wireless encryption or security on the Wi-Fi router to rule out encryption issues. If this resolves the issue, try using a different encryption or security protocol.
Mar 22, 2010 | Linksys Wireless-G WRT54G Router
MAC Book Pro unable to connect the wi-fi. Connection timed out er
Reset your wireless password/key. Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
Mar 12, 2010 | D-Link Xtreme N DIR-655 Wireless Router
I have wireless - router with built in dsl modem DGN2000. Working fine with my desktop but I have just purchased a laptop and have not been able to connect signal to it.
1. Dear! Check your notebook wireless settings and correct it if it is necessory.
2. Chekc your wireless router settings may it need to update for your notebook.
Good Luck
Sep 28, 2009 | Computers & Internet
3Com (3crwe454g72-bundle) Logo
172 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
