My disk cd dvd drive have deleted - Computers & Internet
  • Computers & ... Master
  • 27,725 Answers
You might have to physically unplug the leads for this cd rom then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if your computer came with a motherboard disc the sound drivers could be on it
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on May 17, 2011
Some windows files deleted in error can i get them back?
Most of it can be recovered with a recovery disk. You should have it when you bought the computer. Or can ask a friend with the same model.
Put the recovery disk in you CD/DVD drive. Restart computer press F2, or delete either to get in CMOS setup. Set the Boot sequence to CD/DVD drive in the CMOS. Save and reboot computer. It should boot from the CD/DVD drive and follow the instructions.
But if this doesn't fix. Try reinstalling Windows. If you are lucky this should repair. But it could also mean it cannot be repaired and you need a fresh install.
Sorry mate and Good luck.
May 24, 2014 | Dell Inspiron 1521 Laptop
I put either a dvd or cd in the drive and get a message " insert disk in drive
you might have to physically unplug the cd/dvd drive restart your computer this should activate the found new hardware wizard
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jun 03, 2011 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
The cd drive spins and the light flashes but the laptop doesn't seam to see a disk.....a known good disk?
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Nov 25, 2010 | Toshiba (K000833290) DVD Drive
I cannot burn files into my DVD-RW drive anymore. I updated my audio & display drivers after experiencing problems with my audio & display. Now, the Nero program starts the burning process but the...
You may have to delete the device in the "device manager" and reinstall it with the laptop restore disk or download the latest drivers from the Toshiba site for laptops.
Also this DVD-RW may not like +R disks or +/_ Disk . It may only like -R disk.
Jun 22, 2010 | Toshiba Satellite A100 DVD/CD-RW Combo...
Drive c nearly full, what do i do
1) Log onto Filehippo.com download, install and run Ccleaner. Its free and will clean all the web related garbage off you computer you didn't know was there.
It can also be used to un-install all those programmes you no longer use.
2) Burn your music (mp3) files to DVD or CD. Then delete them from you HDD.
3) Burn all your Photo's to DVD or CD then delete them.
4) Burn all the Documents you wish to keep to CD/DVD then delete them.
May 16, 2010 | Acer Aspire 5610 Notebook
Cd/dvd drive missing on my computer
Enter in the BIOS and see in the boot order or the internal units if the dvd unit is still there. If it isn't then it's dead, replace it.
If it is then you didn't do a correct reinstall. Enter the bios again and make sure the dvd unit is the first in the boot order, boot from a Linux Live-CD like PCLinuxOS and from Computer Management/ Hard Disks  delete all partitions, format the entire disk to something else then format it again to NTFS or FAT. This is the only way you can be sure you are doing a clean install.
Oct 04, 2009 | Acer Aspire 4520-5582 Notebook
My computer won't play cd or dvd
It is possible that the lens of the drive has gone bad and you will have to replace the drive to fix the issue.
Jul 25, 2009 | Computers & Internet
Problems dubbing from hard drive to DVD RW disk
Switch CD R or DVD R
RW disks are not suitable for this work.
Dec 17, 2007 | Computers & Internet
LG COMBO DRIVE
Delete drive from device manager
Then change IDE cable and change the drive setting from master to slave or visa versa to re-initialize
Nov 23, 2007 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
C400. DVD - ok! CD- cannot see!!
you can try the steps below to fix this issue.
Edit the registry:-
1. Click Start, and click Run.
2. Type regedit in the Open box, and click OK.
3. In Registry Editor, click the plus (+) sign next to each folder name to expand the following registry path:
4. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class
5. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
6. In the right pane, right-click Upper Filters, and click Delete.
7. Click yes when prompted to delete the registry value.
8. In the right pane, right-click Lower Filters, and click Delete.
9. Click yes again.
10.Close the window and restart the computer
Please do not forget to rate the solution.
Regards,
Musheer.
Sep 24, 2007 | Dell (11588) Internal 8x CD-ROM Drive
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
