Question about Lexmark Office Equipment & Supplies
Lexmark 810, problems communicating with the printer 2 flashs 1 flash
5 Suggested Answers
hogie155
  • 284 Answers
SOURCE: My dell 810 printer green
go into your control panel and open add remove programs. then remove the printer in this list. then reinstall the drivers with the disk that came with the printer. this should solve your problem.
Posted on Jan 05, 2009
mamun97
  • 29 Answers
SOURCE: Dell Studio not communicating with my lexmark X5340 4-n-1 printer
Fiend your solution direct from Lexmark. Here is your solution
http://www.lexmark.com/printer/prob676ijt65/solution
871
Posted on Mar 02, 2009
  • 1335 Answers
SOURCE: Changed cartridge on Dell 810 printer
Remove the cartridge and check to make sure you have removed the tape from the top and bottom of the cartridge. Reinsert the cartridge and make sure it snaps into place, close the lid, close the top of the printer (make sure it's closed completely.
Let me know if this solves the problem. If it does not let me know and we will go to the next step. Thanks.
Posted on May 03, 2009
Roop1980
  • 228 Answers
SOURCE: status light flashing -- no communication with the printer
Please follow the instructions given below:
1. Disconnect the USB cable and the printer power cable.
2. Please disconnect the power supply from the back of the printer.
3. Then remove the cartridges from the printer.
4. Please reconnect the power supply back and turn on the printer.
5. If lights are blinking then printer encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
6. The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
7. The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and let us know if the lights are still blinking.
8. If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer.
9. However, if lights are not blinking then try inserting one cartridge at a time and check if you can see any lights blinking. If light blinks with one cartridge then that cartridge is defective.
Posted on May 26, 2009
Printtech
  • 1087 Answers
SOURCE: I set up my own wireless network and now my
I suggest you reset the Lexmark Z2420 wireless network adapter. To reset, do the following: With the printer on, press and release the power button. The printer will enter power save mode. Now, press and hold the paper feed button. While holding down the paper feed button, press and release the power button. Continue holding the paper feed button for 30 seconds. Release the paper feed button. This will reset the internal network adapter (INA). When the printer has been reset, a solid orange Wi-Fi indicator light should appear. If Wi-Fi light goes back to flashing red, you have not successfully reset the printer. Start the procedure again. Once you have a solid orange Wi-Fi light, reconfigure the printer for wireless connection. Thanks.
Posted on Jul 29, 2010
Wireless printing
Blinking orange means one of the following: 1. The printer is out of range of the wireless access point (wireless router). 2. The printer is trying to communicate with the wireless access point, but the wireless access point is turned off or not working properly. 3. Either the configured printer or the wireless access point has been turned off and back on, and the printer is trying to establish communications with the network. 4. The wireless settings of the printer may no longer be valid.
May 10, 2012 | Lexmark X7675 AllInOne InkJet Printer
Lexmark x5250 flashing green power light
The flashing light could indicate either a communication problem between one of your cartridges and the printer, a short in one of the cartridges, paper jam or the cartridge carrier has stalled. Please follow the steps below to fix the problem:
  1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
  2. Open the printer cover and remove both the cartridges.
  3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
  4. Close the printer cover.
  5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first.
  7. Close the printer cover and check the light status.
  8. If light on printer is normal, open the printer cover and reinsert the other cartridge. Check the light status.
  9. Replace whichever cartridge is causing the light to flash with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
  10. Load some paper. Try to print a document again to verify that the problem is fixed.
Jan 25, 2012 | Lexmark Office Equipment & Supplies
Lexmark x2600 i have ink and ervything my paper isnt jammed but everytime i try to print the button next to the X button keeps blinking orange
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 21, 2011 | Lexmark X2600 InkJet Printer
I seem to have lost communication with my printer. It will not print. The ppwer button keeps flashing on and off. I have followed all of the troubleshooting guide suggestions. I have checked all cables,...
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/aKlcOJ. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 28, 2011 | Lexmark X1270 All-In-One InkJet Printer
The orange paper light with the arrow keeps flashing and my ink cartridges wont come to the center
5. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
10. Load some paper. Try to print again.
Aug 18, 2011 | Lexmark X2670 All-In-One Printer
I get a message saying the printer cannot communicate with computer. Everything is connected properly. Also, the wifi light is flashing. Sometimes it prints, but it randomly cannot...
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Unplug and re-plug the printer into the power source to reset it. Reboot your computer.
You may also refer to this article found in the Lexmark website: How to identify a Wireless Communication Problem and Resolution Tips.
Jul 13, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
My printer wireless indicator is flashing red and I cannot print
The flashing status of the WiFi light on the printer indicates that it's either trying to connect to a wireless network or it has gotten disconnected from your wireless network.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, check the WiFi light status. Try to print again.
You may also refer to this article: Wireless & Network Communication Issues with 2008 Lexmark Inkjet Products
Jul 05, 2011 | Lexmark Z2420 Printer
Wifi light flashing orange. communucation failed
The flashing light indicates that the printer is trying to connect to a network or is not connected to a network. This article Wireless & Network Communication Issues with 2008 Lexmark Inkjet Products will help you identify and resolve the issue.
May 31, 2011 | Lexmark Z2420 Printer
What does it indicates when the wifi light is flashing red in the lexmax z2420
The flashing light indicates that the printer is either trying to connect to a wireless network, a "connection failure" or a communication is not available. This article should give you ways on how to fix wireless connection problems - How to identify a Wireless Communication Problem and Resolution Tips. Hope this helps. Thanks.
Jan 21, 2011 | Lexmark Z2420 Printer
Printer cannot communicate with the computer
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Sep 10, 2008 | Lexmark Z735 InkJet Printer
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
