Question about Dynex 4-Port Ethernet Broadband Router (DX-E402)
I have a Dynex router model 10/100m router. I hooked up a netgear Prosafe Wireless Access Point model wg302. I have wireless internet connection but I am unable to "secure" the line. I have looked in many places but to no avail. Is it possible?
  • 88 Answers
Any wireless security settings are going to be accessed from the netgear. When you chain one device to another, you need to know what the IP address the access point is assigned in order to log into its web interface. the wireless options will be missing if you just simply log into the Dynex web interface. To figure out the APs address, you may have to manually configure it to keep it simple.
Posted on Jun 15, 2011
How do i connect my WG302 to my laptop using a console cable?
if Windows
go to dosprompt on p.c or start run cmd <press the enter key>
type in ipconfig <press the enter key>
was the ip address of the laptop 192.168.0.210 with a subnet of 255.255.255.0 ?
note the ip address of the laptop and the subnet mask
If the ip address is not 192.168.0.210 then go into the network settings and set the laptop up with 192.168.0.210 and then make it a static ip address.
was the ip address of the laptop 192.168.0.210 with a subnet of 255.255.255.0 ? (if not restart the laptop ) and check again
Next question how did you connect the wg302 directly to the laptop was it directly connected or was it through a network switch or network hub. Most likely the Cable router or DSL router has a DCHP server assigning different ip address lease range. You can either change the ip address of the access point device to one in the original current router lease range and assign it as static for the wireless access point device in the dchp lease table or assign the wireless access point with the second ip address as an example 10.0.0.2 and make sure the router dchp server allocates above 10.0.0.20 then temporarily connect router to laptop and temporily set laptop with 192.168.0.210 and then log into access point and change ip address to 10.0.0.2 for wireless access point device and turn off its dchp server. Then change laptop to use dhcp while connected into network hub or network switch with original router and restart laptop wired back into original normal network.
Dec 04, 2014 | NetGear WG302 802.11g ProSafe Wireless...
My landline is hook up to ciso an thats hook up to netgear how do i make calls out
If it's a cable modem you should have your phone landline connected to the cable model, if you have a "bundle". TV, Broadband, Phone with your provider. For example: I have Comcast/Xfinity bundle, TV, Phone, High Speed Internet. At the Comcast Modem it has a Phone jack RJ-11 for landline and Fax and a RJ-45 for my Wireless Access Point and Ethernet cable.
Jan 18, 2013 | NetGear WGR614 Wireless Router
Cant log in to wg302
you could try a hard reset, back to factory defaults: find the recessed Reset button on the rear of the WG302. use a straightened-out paper clip to push and hold the button for three seconds or more. this will reset the WG302 back to its default IP address of 192.168.0.228, and the login to username: "admin", password: "password" - don't type the quotes.
remember that you'll need to assign a static IP address to the PC you're using, such as 192.168.0.100, subnet mask: 255.255.255.0 - and to change it back to its previous setting once you're done setting up the WG302.
Sep 13, 2011 | NetGear WG302 802.11g ProSafe Wireless...
I lost my cd for setup ipls help me this is my serial number of my netgear 1um8977f03f04tnx
To Configure the Router with Internet Access
Connect to one of the wireless router/access point's LAN Ethernet ports, turn off its DHCP server, and give the wireless router a static IP on your LAN:
  1. Connect a PC directly to a LAN port on the wireless router with an Ethernet cable.
  2. Power on the wireless router/access point.
  3. Reboot the PC.
  4. Log in to the wireless router though a browser. (Usually 192.168.1.1, with User Name = admin and Password = password, unless you changed them from the defaults).
  5. Go to the LAN IP menu and disable the wireless access point's DHCP server by unchecking Use router as DHCP server.
  6. Select LAN IP, and change the IP to 192.168.1.99.
  7. Click Apply to save the settings. You will lose the connection to the wireless router/access point , since its IP changed.
  8. Log in to the wireless router/access point with the URL: http://192.168.1.99
  9. Connect one of the wireless router's Local (LAN) ports to your existing network
Feb 21, 2011 | NetGear WGR614 Wireless Router
Need basic step-by-step instructions on how to install my router.
  3. Reboot the PC.
  5. Go to the LAN IP menu and disable the wireless access point’s DHCP server by unchecking Use router as DHCP server.
  9. Connect one of the wireless router's Local (LAN) ports to your existing network.
This completes the wireless router/access point configuration.
  • You can now log in to the wireless router/access point at its new address of http://192.168.1.99 and configure wireless features such as WEP and Access Control List
  • UPnP, DMZ, Port Forwarding, and Port Triggering are not used on the wireless router/access point, and it doesn't matter how they are configured.
  1. Configure the LAN IP address to be within the same subnet as your PCs.
    • Take care not to use an IP address already being used.
    • Limit the number of addresses in the DHCP range and assign an IP address outside of the range to the router you want to use as the Access Point.
  2. Disable DHCP on the wireless router/access point.
  3. Connect one of the LAN ports on the wireless router/access point to a LAN port on the Router.
  4. Configure the SSID and any security settings on the wireless PCs to match the wireless router/access point's SSID and security settings.
a. SSIDs must be the same on all wireless devices. (These are case-sensitive: netGEAR is not the same as NETGEAR.)
b. Tip: Make sure the wireless PCs can connect before configuring WEP, WPA-PSK, or other wireless encryption.
Jan 02, 2010 | NetGear WGT624 Wireless Router
I can not access my wireless internet network with my new computer. I have a netgear wireless router model MR814v2. I can get onto the internet when directly connected to my modem. However, when I try to...
Hook directly to the router hard wire. Go to configuration page for router and look at wireless security settings. it will show you Wep or some other encryption technique. It will also give you a place to view or change your wireless key. Once you do that write the key down and then connect wirelessly.
Nov 08, 2009 | NetGear MR814 Wireless Router
Sierra Wireless AirCard 595U And PS3
I understand that you want to connect the PS3 using the Wireless card and NETGEAR card. Please note that the setup you have will not work for internet access. You can not configure the Air card to work with NETGEAR router. you need to have wih a broadband connection available for this router to connect to internet.
Once you have the router configured with Internet access then you may either connect the PS3 wired or wireless to the router, like you connect a desktop or laptop to the router.
Jan 12, 2009 | NetGear WGR614 Wireless Router
Wireless router says its working laptop says no its not
Your sister was accessing the wireless access point at school which is connected to the Internet/WEB access via a router and the school's broadband service provider.
For you to access the Internet using your wireless adapter on your laptop, you need your own wireless access point and connect it to a broadband ADSL or cable modem and then connect it to an Internet Service Provider. Some Internet Service Providers (cable and ADSL) can supply a combined modem/router/wireless Access point.
If you already have a broadband modem all you need is a wireless access point/router. You only need to configure the wireless access point and your wireless adapter so they will communicate with each other. Folow the instructions in the manuals.
Dec 07, 2008 | NetGear WGR614 Wireless Router
Can I use the Netgear Rangemax wireless router as an access point?
Yes you can use it as an access point and hook it to your existing router, since this is a wireless router and can work as a wireless access point on your network............
Nov 03, 2008 | NetGear RangeMax WPN824 Router
Dynex 4-Port Ethernet Broadband Router (DX-E402) Logo
149 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
