Question about Dell Latitude E4310 Laptop
Unable to type on keyboard. The mouse works fine but I can not type any text. unsure how this happened??? currently using a different computer for help.
  • Dell Master
  • 998 Answers
"I'mlooking for drivers and downloads". If you don't have the proper versionof Adobe you will be prompted to install it. Once installed return to"drivers and downloads" and enter the "service tag",(serialnumber) of the laptop. Dell keeps a listing of drivers for every customer'scomputer they sell.
To boot from a CD disk, power on your computer and tap the key to bringyou to the "One time boot menu". Insert the CD into the top CD/DVD drive andthen select "Boot from CD/DVD" and hit key. Select the "Runthe 32 Bit Dell Diagnostics.
If all tests pass then reload OS ( Operating Software ).
Posted on May 18, 2011
Cantusekeyboard
You should be a little bit more specific. But since you were not, I will try to be more specific about this.
First thing to know is that connecting keyboard and mouse to the computer will always work, no matter what. Meaning that once you connect either one, they will always work. Here are some things to try:
1. Check to make sure that the connector used for the computer is fine, its not broken or bent in the connecter. Check both the computer slot and the connector itself.
2. Make sure that the batteries are new if its wireless.
3. If mouse and keyboard use a separate connectors, and you know that mouse works. Try unplugging the mouse and connecting the keyboard in the same slot.
4. Try a different USB slot in the computer
5. Try a different keyboard all together
6. Make sure there are no off switches on the keyboard that might be in the off position.
I hope this helps.
Oct 17, 2012 | Acer Aspire One PC Notebook
My mother just gave me a toshiba laptop and she had a wireless mouse for it before. I do not have the mouse on it now and the mouse pad is not working. How do I restore it to the original setting?
Hi parothead91...
To fix an unresponsive touchpad on your laptop, reactivate it by using the Function key on the keyboard and the Fn key.
This process is different for each computer manufacturer.
If unsure which Function key enables and disables the touchpad, try each one at a time and then
attempt to use the touchpad after each one.
A...Locate the "Fn" key of the laptop keyboard.
The "Fn" key has different colored text or the key is a different color.
B...Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
C...Press both the "Fn" and touchpad Function key at the same time to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
Note: Mac computers use "F2" to enable and disable the touchpad.
Please take time to rate me
Sep 05, 2011 | Toshiba Computers & Internet
Problem description: hp 110-97TU netbook, windows 7 starter. without me touching the keyboard/touchpad or even type, it automatically continues to type in search text box letter ...
Hi Welcome to Fixya!
Obviously after the steps that you just did, its not a software issue.. Even though the Q key is not stuck physically, it could be a problem with the keyboard connections inside the computer..
And its really a bad thing that the warranty already expired because you will not be eligible for free hardware support.
The least thing you could do is have a local technician take a look on your netbook. They can open the keyboard for you and take a look for any malfunction on the keys or if its with the inside connections of the keyboard.
Hope this could help!
Jul 04, 2011 | Computers & Internet
I just purchased a new pc and it came with an Inland 70119 2.4GHZ wireless keyboard and mouse. The mouse works great, but I cannot get the keyboard to do anything. I have tried different batteries,...
If the keyboard and mouse came together, and the mouse works fine, and you've tired drivers, batteries, etc, then the only other possible issue is that the keyboard is bad.
Try connecting the keyboard and mouse to a different computer to verify this, otherwise replace the keyboard and see what happens.
Hope this helps
Mar 15, 2011 | Inland Pro Wireless Optical Keyboard/Mouse...
Unable to log onto computer keyboard double spacing and double ch
Try a different keyboard, if a different keyboard works properly then your original one is defective. If another keybaord does the same thing then its a setting in the operating system for the keyboard that needs to be changed.
May 01, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Product installed correctly as far as I know. Mouse is working fine. Keyboard has power - connect button beeps when pushed. Green light is flashing on receiver -- Keyboard doesn't connect for typing on...
First, try replacing the batteries with fresh ones.
Then, hold down the connect button on the receiver and on the keyboard (usually located underneath) AT THE SAME TIME for five (5) seconds, and then release them both.
Try using the keyboard.
If same problem occur, try connecting the receiver into different USB ports of the computer. Or might as well, try different computer.
Feb 20, 2010 | Logitech Cordless Desktop MX3200 Laser...
Microsoft Wireless Laser Mouse 7000 'sticking' issue
You did not say what type of surfaces you tried. For example, a laser mouse with no ball in it, will not ever work right on a glass table top. And texture has nothing to do with it either, so putting a pure white sheet of paper under it won't help either. The best is to find something with a nice fine pattern on it. Something rough works better than something smooth, but only because texture indirectly causes a dark pattern.
Jan 01, 2010 | Microsoft Wireless Laser Desktop 7000...
I have four Compaq EVO D510 computers that all have the same problem. They are used computers that were pulled out of an existing site. I have a USB mouse & keyboard connected to the computer (no...
Hi sdd555,
Restart the computer after plugging the USB keyboard into a different USB port, or remove the keyboard in Device Manager and then refresh the system to work around the issue. This will cause the device to be re-enumerated and the driver will be reloaded.
Good Luck,
Mark
Jan 13, 2009 | Compaq Evo D500 PC Desktop
Nothin works and nothin is detected
doesnt need batteries does it dl latest driverers form website maker try ohter ports
Oct 09, 2008 | Microsoft Wireless Optical Desktop Comfort...
Keyboard locked
hi!
Have you tried restoring the computer to a previous state when the computer was still working fine? are you running vista? type system restore after you click the pearl or start button. restore it and let me know if it works ok?
Thanks,
Karlox™ :)
Jun 12, 2008 | Compaq Presario 700 470024-192 Notebook
Dell Latitude E4310 Laptop Logo
586 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
