Question about CTX S792A (Silver) 17" LCD Monitor
I have a CTX S792a monitor with a blank screen and a "out or range" box that moves around.
  • 11,361 Answers
Faulty monitor ctx pv720a. The screen has the
Try another cable, or check the plug for bent pins. If they are all good, check that the monitor is set for VGA input (if it supports VGA and DVI) as it may be looking for a different input. Then replace the monitor. It's not common, but video processing circuitry can sometimes fail, and yours may have. New 17-inch LCD monitors are quite inexpensive now, so it would probably be more economical to replace this one than to try repairing it.
Jan 01, 2011 | CTX PV 720 17" LCD Monitor
Ctx pv720a monitor goes blank
This is what inverter board looks like:
http://www.shopjimmy.com/catalogsearch/result/?q=CTX%20PV720
Look for bad caps also, more likely to need new inverter board, warning, you can have bad lamp assembly also.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Jul 27, 2010 | CTX PV 720 17" LCD Monitor
I am facing problem with my Samsung LCD monitor, when I switched on my Computer it shows the bootup screen, after booting the LCD screen goes blank, when i turned off the monitor and again turned ON the...
Try to do this: Just before the Windows start up screen (after the bios loading) press F8 and log in at safe mode settings. If at this mode you can see your screen change the resolution settings at a lower set. Save and reboot normally. Now try step by step to increase your resolution. In case of a blank screen appears at a new setting, don't do anything; after some seconds the monitor will come back to the previous settings. Save and go on.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Mar 05, 2010 | CTX S762A 17" LCD Monitor
Ctx monitor
try lowering the screen resolution
Oct 19, 2009 | CTX S762A 17" LCD Monitor
Screen suddenly went blank except for a self test box
well in order to get rid of the self test window from your monitor... check the cable that connects your monitor to system tower & reset the connection... becase that is the only possible cause of the self test showing up on your monitor...
" as the self test option only appears when there is no video signal going from your video card to the monitor...
Jan 18, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor picture turns on its side when it goes to screensaver
Sounds like your screensaver is using a picture of your desktop in it's code intentionally.
Right click on a blank area of your desktop --> select properties
--> click screensaver --> change it to "none" or another screensaver
Jan 17, 2009 | CTX S762A 17" LCD Monitor
CTX monitor menu locks
hold the enter and esc keys while turning on the monitor should relase the key lock
Jun 20, 2008 | LG L1915S 19" LCD Monitor
SCREEN PROBLEM
my monitor screen is totally white
Jan 22, 2008 | CTX S762G (Silver) 17" LCD Monitor
Mag innovision LT716s monitor model 700p blank screen
Try to adjust the frequency.
Right click on desktop , properties, (my windows is in portugese. Dont remember the right name) configuration, button "advanced", display.
I hope to help u.
Good luck
Dec 17, 2007 | CTX PL 9 19" CRT Monitor
No Display on connecting Data cable of PC
The Monitor is bad, with the CRT Monitors you cannot just replace the connections, because it is embedded into the CRT. So it is probably something that lies with in the monitor itself. Try to connect another monitor to the device. See what the result is, my best guest is the CRT Monitor when bad. Time to replace! Sorry!
Nov 23, 2007 | Samsung 793S 17" CRT Monitor
CTX S792A (Silver) 17" LCD Monitor Logo
163 people viewed this question
Top CTX Computers & Internet Experts
Rommel Balcita
Jerry Greenberg
Jerry Greenberg
Are you a CTX Computer and Internet Expert? Answer questions, earn points and help others
