Question about Refrigerators
I have a homeking fridge freezer and there is a really bad smell coming from the fridge which is not because of food. i have emptied the fridge and thoroughly cleaned the fridge but the smell is still there
  • Anonymous Aug 18, 2008
    Cleaned entire unit
I have an Electrolux bottom mount EBM4300SCR refrigerator. It is just over 1 week old. From the time I first opened the packaging, the fridge has a strong offensive odour. I have tried baking soda (in the fridge, several batches on a saucer, changing it each day) but still the smell persists. It is not a food smell but the smell must have origined in the manufacturing process. Can anyone suggest what it may be and how long it may take to disappear?
Thanks
Kath
Posted on Apr 18, 2011
Hi, i have the same problem with my Homeking fridge. Because it is a frost free firdge, there is a little resevoir at the back, with a small little tube leading from the base of the fridge into it. There are 2 screws holding it in place. Unscrew these but keep the resevoir firmly in place as the nasty parmesan-type smell is actually stagnant water and you really really dont want to spill it. Empty it and then what i did was bleach and anitbacterialise the resevoir tray and the little tube thing. Though I had the problem solved but now it is doing it again less than 2 months after this, so I'm going to contact the people who sold it to me. This is how you get rid of the smell though!!
Good luck
Laura
Posted on May 17, 2009
Fridge and freezer smell like fish
I suspect u have a plugged evaporator drain plug hole and rooting food smelling
Jul 17, 2014 | Kenmore Refrigerators
Fridge smell and taste makes you sick, very clean and no food in it
Keep it open for a 4 or 5 hours... Then keep some cut lemon inside it.
Oct 27, 2012 | Hotpoint HSS25GFP Side by Side...
I have a Kenmore Elite refrigerator model number 59673503201 and there is a terrible fish smell coming from the bottom portion of the appliance where the freezer is. It is not coming from trash, or food...
Please note when you keep fish in freezer once, the smell will be longer even you remove it. O.K. Now solution for your problem- Please unplug power.Keep fridge door open. Take wet cloth dipped in soap water and clean all compartment including freezer . Keep freezer door also opened.Then clean with dry cloth. Spray room spray in your room not into the fridge. And allow 5 hrs to circulate fresh air to pass thr' your fridge and then close fridge and freezer doors. Plug fridge and run for one hour on empty. After one hour store items in fridge and/or freezer.
Keep all food items in closed style which will avoid odor spreading and also be a hygienic. Thanks.
Jan 30, 2011 | Refrigerators
The fridge and freezer smell like a dead animal. cleaned the inside with bleach but still smells for weeks. model w10212088
There are two reasons for bad smells. 1. Long time not being used. 2. Lack of cleaning inside compartment.
Solution: Unplug fridge. Keep open fridge door. Dip a dry cloth in soap water and start cleaning each and every compartment. Keep freezer door also open. And then clean with another dry cloth. Keep both doors open for nearly 5 hrs. It will be enable fresh air to **** the smell inside fridge.
After 5 hrs close the fridge and run on empty for one hour. Keep food items after one hour. Please keep all food items closed vessel. Not only it's avoid odor but also be hygienic.
If you use to keep fish items in freezer, clean fridge once in a week.(Spray roo spray in the room when you keep fridge door opened. Don't spray into fridge.)Helpful.
Jan 30, 2011 | Whirlpool Refrigerators
Chemical smell in refrigerator
wipe it out with a clorine bleach solution,leave the door ajar to gas off and use a syringe to blow out the drain hole.wipe dry then cover any open topped food containers with cling film.as all fridge/freezers work best when 3/4 full.use empty airtight boxes to fill any spaces,she/he will notice a big difference in lower running costs...
whilst the freezer may be frost free, the fridge is not, so expect condensation to form on any gloss surfaces...(the more airspace the more condensation........)
Jul 26, 2010 | Sub-Zero 695/S Side by Side Refrigerator
Disgusting smell from my Liebherr fridge
use a syringe to blow clorine bleach down the drain hole.(the clorine will gas off and leave no smell after about an hour)
Jul 23, 2010 | Liebherr KIKNV3056 Bottom Freezer...
Bosch classixx fridge freezer - smell coming from fridge. Can only smell when door opened.
bad eggs smell coming from behind Bosch fridge freezer. There is no bad food in fridge. Any comments appreciated. Linda
May 02, 2009 | Refrigerators
Refrigerator smells strange
I may have found the problem. I pulled out the Fridge again. The odor was in the water pan.
What I found was that the cooling grills in the front was caked with dust. I vacumed this area but it was not until I got down with a flash light and saw this issue. I took a small duster that uses static to pull the dust out. There was a lot. I will see if the smell starts up again.
Aug 05, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Ice and Refrigerator and Freezer smell like alcohol chemical
I believe that you might have a coolant leak causing the chemical odor. You really should get it checked out by a fridge repair-person because it's not healthy to breathe in the fumes.
May 21, 2008 | Hotpoint HSS25GFP Side by Side...
Freezer smell
could be that your freezer is leaking gases some leaks are fixable but if its an internal leak you will have to replace the complete appliance
Aug 15, 2007 | Turbo Air TGM22RV
Refrigerators Logo
253 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
