F21 flashing now light at start buttom - Washing Machines
  • Washing Mach... Master
  • 8,220 Answers
F-21 is not the same on all machines. On some it means the drain pump is clogged and on others the touchpad has gone haywire. To be sure remove the base panel and consult the tech sheet for your model.
More Here
Posted on May 17, 2011
Bocsh 1400 express f21 keeps flashing
This Bosch looks like a Kenmore HE2, and may be made by the same manufacturer.
In the Kenmore HE2 manual it states:
"F" Variables [F4 to F16] (Electrical problem)
Select PAUSE/CANCEL twice to cancel the cycle.
Select DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call for service.
If it's not working still, try asking advice at RepairClinic.com . They have helped me in the past, and they have parts too.
May 29, 2014 | Kenmore HE2 Plus Front Load Washer
MY TV FLASHES 7 TIMES ON THE POWER/STAND BUTTOM
ensure the lamp cover door is firmly pressing the kill switch and the red light will stop and u can turn on the telly
Jul 05, 2013 | Sony Grand WEGA KDF-60XS955 60" Rear...
I actually have a 250. bulb is new but stopped working. When plugged in green power indicater lights then flashes two red lights.
The projector is bloked, you need reset the lamp timer. Press and hold the VOLUME + buttom, then press the VOLUME - buttom. Hold both buttons down for 10 seconds.
Jun 16, 2010 | InFocus LP 240 Multimedia Projector
F21 flashes on the time screen -- am unable to power washer off
Lets see: F21 Long drain Possible cause: Clogged filter0c09ded.jpg, clogged/failed pump Remove the bottom panel299686f.jpg go for the pump cleanout, get the googus outb1cfae3.jpg. Tech sheet is located behind the white box to the left which is the motor control unit (MCU). The tech sheet is an excellent tool which gives directions on diagnosing those pesky fault code. LOL7b78889.jpg
May 18, 2010 | Kenmore Elite 45986 Front Load Washer
How to program in the 3 pre sets for garage door openers We have a 2001 dodge grand caravan es
Hope this a Homelink. Put new batt in garage door remote. Park outside garage. #(1) Press & hold 2 outer buttons on Homelink. Release ONLY after light starts to flash. Don't hold for longer than 30 sec. Don't repeat to program the other 2. #(2) Hold the remote 3 inches from Homelink. #(3) Press & hold the Homelink buttom & the remote button at the same time. #(4)The Homelink will begin to flash slowly then rapidly. After the Homelink flashes rapidly release the buttoms. #(5) Press the just trained Homelink button if the light stays on constantly, programming is complete..... To program the other 2 links DO NOT REPEAT #1
Jan 10, 2010 | 2001 Dodge Grand Caravan
All of the lights are flashing and will not print
please hold on the start buttom for 1 min to check it works back or not.
if still not working, please unplug the cable and rest for 5 min then plug it back on.
May 28, 2009 | Brother HL-2040 Laser Printer
Program Optoma EP-739 remote to Bell Express Vue 3100 remote
1 - Hold the clear tv buttom until all 4 light flash red
2- Press the red tv buttom
3- Press the amount of time needed on the up cursor ( around select buttom) until your tv shut down
4-When the tv goes off press the search buttom ( at the end on the right side )
5-Press record
Then u can use the red tv buttom to control ur tv and u can control the volume on satelitte mode without going back to tv mode , if u press too much time while searching the code and the tv wont light back , do the same thing but instead pressing the up cursor press the down one to go back on the code it will be faster .
Feb 23, 2009 | Optoma EP739 Multimedia Projector
Remote codes
5-Press record
Jan 03, 2009 | Bell SH50102 Remote Control
Brother HL 2040 toner light flashing
Push the start buttom and hold for 30 sec.
Nov 26, 2008 | Brother HL-2040 Laser Printer
Display frozen
I think if you push the heated wash and heated dry buttom several times until all the buttoms light up this may fix your problem.
You may have different kind of light flashing indicator, but the same solution.
Possibly check the sequence switch
Feb 09, 2008 | Dishwashers
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
