Question about HP OfficeJet D135 All-In-One InkJet Printer
Scanner failure - HP OfficeJet D135 All-In-One InkJet Printer
  • 7 more comments
  • superbeee27 Sep 10, 2008
    Scanner failure message. Please turn power on then off.
  • Henby Oct 04, 2008
    Please HELP! when sending a fax it dials the number, connects, part loads then the message appears 'scanner failure, switch off and restart' which I obviously do but to no avail as we just go through the same procedure over again.Can anyone suggest what to do now....other than throw the machine out of the window...its too big!(the machine)
  • lesleydpoet Oct 11, 2008
    I plugged in my hp all in one and I keep getting scanner failure. It states to turn power off and on. I have done this numerous times, but I get the same message. I am not able to touch any other buttons.
  • kathypettit Oct 27, 2008
    After turning on the printer, I am getting a message stating "scanner failure" turn off printer. Can't do anything else.
  • j_kelley1 Oct 28, 2008
    Scanner failure please turn back off and on then it will do it again...
  • erik244 Jan 28, 2009
    Same problem here... must be structural!
  • jcp48 Jan 28, 2009
    I have been using my 7210 all-in-one for more than 3 years with no problems, today it started giving me the scanner failure error, too. It looks like I am not alone.
  • Anonymous Mar 06, 2009
    same problem - scanner failure. Turn power off then on and it goes away for a time, then comes back/.
  • Anonymous Apr 29, 2009
    Same problem on HP Officejet 7210: Scanner failure. Turn power off then on again. I've done that to no avail.....
Posted on Jan 26, 2009
Posted on Mar 03, 2009
SOURCE:
Whats the meaning of error E0202 canon ir copier
Description
An error occurs during the Scanner Unit (Paper Front) HP detection operation (outward).
E202 -0002 -04 Title Scanner HP error
Remedy 1. Connector disconnection/open circuit of the Scanner HP Sensor (SR2).2. Failure of the Scanner HP Sensor (SR2).3. Failure of the Scanner Motor (M1).4. Failure of the Reader Controller PCB (PCB1).
May 11, 2016 | Canon Office Equipment & Supplies
How do I solve the "scanner failure power off and on again" message for an h.p. 6110 officjet all-in-one printer/scanner/fax?
Hi Paul,
Scanner Failure usually results in Hardware Failure. However there is one step you can try. Try connecting the printer directly to wall outlet or any other power outlet and the issue should be resolved.
Regards,
Sean
Apr 19, 2013 | HP OfficeJet 6110 All-In-One InkJet...
Failure in initialization of Scanner. Scanner is offline or , scanner is turned off.
First check if the scanner is working in 'offline' mode by 'counting' a few pages.
Connect to the comp, if SCSI is the interface, you need to start the scanner first, if USB you can connect the scanner even after comp powering on. If the scanner is not recognised, reinstall driver software and scanning software.
S. Mohan, Chennai, India
Dec 21, 2010 | Canon DR-9080C Path-Through Scanner
Try to copy and get scanner failure motice
scanner failure is a hardawre problem. try to copy again and check if the scanner light is on. once the scanner light is not working then try to return your printer in the store that you have purchased it.
Oct 20, 2009 | HP Officejet 5610 All-In-One InkJet...
What are errors 1to5 and 7to8
1- face down sd ram failure
2 face up dram failure
3 cpu dram failure
Sep 23, 2009 | Kodak i30 Path-Through Scanner
Scanner Failure
Scanner failure means the scanner is not making enough light to see the home position. It happens when the scanner lamp ages or is covered with dust. Cycle power is just power off and on again, and see if it goes away.
Jul 02, 2009 | HP Photosmart C6180 All-In-One InkJet...
Scanner link failure
This scanner requires a "Parallel or Centronics" cable and if you have a newer computer, you may only have USB connections. A "USB to CENTRONICS" cable may do the trick, but I'm not sure. Check on the web for one.
Jun 27, 2009 | Umax Astra 1220P Flatbed Scanner
Scanner failure
you just open start-->settings-->control panel-->scanner and camers
delete old scanner
click add imaging device
you can now reinstall
May 24, 2009 | HP PSC 2175 All-In-One InkJet Printer
Try to print--scanner failure appears
I think your printer has been, for some time now, trying to tell you something and the scanner failure message
is the last in a series of messages.
First, the copier and the printer and the scanner worked fine, "for years",
Then, the copier stopped accepting scans, while printing from data sent by your computer.
Then, you received a scanner failure message again, and will not accept data from your computer, and
"won't print at all"
Your printer/scanner/copier/fax has needed service for some time after years of continuous service.
Evaluate now, based on its initial cost and the lesser cost of All In Ones whether you have already
obtained sufficient service to amortize the cost over time, and you may conclude that service is eitherr
cost effective or ineffective at this time.
Apr 17, 2009 | HP Office Equipment & Supplies
Scanner failure
scanner failure, turn unit off and back on, does not help
Oct 01, 2007 | HP OfficeJet d145 InkJet Printer
HP OfficeJet D135 All-In-One InkJet Printer Logo
1,099 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
