Question about Goldstar MV-1502 Microwave Oven
Where can I get the template for LG microwave so I can install it? instructions how to install it correctly.
I need Template and installation instructions for GE Spacesaver Microwave Model JVM1630CJ02, built Jan 2005. Thank you.
You can download GE owner's manuals and installation instructions here.
If the installation instructions do not have the template, you can also find helpful exploded view diagrams and order needed parts by entering your full model number here.
Apr 29, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
HI,
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Instructions
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
Jun 16, 2010 | Frigidaire Microwave Ovens
When installing over the range microwave does template need to be removed
the paper template that they send to mark for mounting instructions? yes...another template you're refering to?
Oct 25, 2009 | Bosch Microwave Ovens
Have microwave but no install instructions. I have the templates and already put holes where they needed to go but then templates say refer to installation instructions which i don't have. Is there a site...
You can download owner's manuals and installation instructions for several brands (including Amana, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
You can find helpful exploded view diagrams and order parts for many brands by entering your full model number here.
If yours is a different brand,
please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
To allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit.
Oct 08, 2009 | Maytag MMV1153A Microwave Oven
Where can I find a template to hang my microwave MH1150XMB
Part numbers:
8184731 Upper Template
8183743 Wall Template
You can usually find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Your installation instructions are here.
Jun 23, 2009 | Microwave Ovens
LG LMV1680BB top mount not usable
They simply need to drill new holes, I'd say.
The installation instructions will have a template.
Jun 05, 2009 | Microwave Ovens
GE JVM1650CH01 Microwave Template
Aug 17, 2008 | GE JVM1650 1000 Watts Microwave Oven
Installation of MV-1502
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 20, 2008 | Goldstar MV-1502 Microwave Oven
LG Model LMV2061SS
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit http://www.lgservice.com.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 14, 2008 | LG Microwave Ovens
Goldstar MV-1502 Microwave Oven Logo
114 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
