Question about LG WM-2277HW Front Load Washer
LE indicator light coming on - LG WM-2277HW Front Load Washer
    Problem Solver:
  • 14 Answers
LE means there is a problem with the motor, must likely he motor hull sensor. The hull sensor will need to be replaced. Part number 6501KW2002A. It is attached to the motor stator. There is a access panel in the rear of the machine to service the motor. Remove the rotor and stator, replace the sensor, and you should be good to go.
Posted on May 17, 2011
2005 sienna turn signal light comes on when i push the brake
sounds like a crossed wire , I saw problems with the brake light switch that is located on the brake pedal
Nov 28, 2012 | 2005 Toyota Sienna LE
LE Message coming on
The 'LE' stands for 'Lock Error' and indicates there is a problem with the door lock. Either the locking solenoid or the door lock sensor is malfunctioning and requires attention. Sorry- Service call!
John C
Mar 16, 2011 | LG WD14121 Front Load Washer
Dishwashing cycle starts for about 3 minutes then flashing LE light comes on and the machine stops. Why?
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Try the following steps:
Unplug the washing machine if you see an LE error on the two-digit display electronic readout. This error indicates a miscommunication between the control panel and wash motor.
Press and hold the "Start/Pause" button on the front panel for five seconds.
Plug the LG dishwasher back in.
Run a cycle. The LE code will clear.
Aug 31, 2010 | LG 24 in. LDF 7811 Stainless Steel...
Le comes up and stops cycle
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Jun 28, 2010 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
LE sign comes on
over suddsing is what this erro indicates. Clean the pump out as well as the hoses and use less soap.
Please rate my help++++Thanks for using FIXYA
Jun 25, 2010 | LG WM-2277HW Front Load Washer
2004 Nissan Titan LE 4x4 4LO position indicator light flashes
As far as your 4WD light problems, can't help you. The loose hose sounds like the front diff vent hose.
Feb 06, 2010 | 2004 Nissan Titan
Emission control system light on dash
audi a4 tdi Emission control system light on dash
Jun 02, 2009 | 2007 Audi A6 Avant Wagon
LG WM-2277HW Front Load Washer Logo
232 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
