Question about Kenmore 98702 Stacked Washer/Dryer
Where can I find the lint filter for my Kenmore model # 417-90862990. It should measure 12x2. Thanks for any input!
  • Kenmore Master
  • 8,220 Answers
$18
Posted on May 17, 2011
Testimonial: "Thank you very much! I have been looking for this part for so long! "
  • Dan Webster
    Dan Webster May 18, 2011
    Thanks. If you ever need to get into this one for one reason or another I replaced the glides on one of these and made some photos. Included the service manual HERE
How do I get an owners manual for Ross mixer 12x2
What model of Ross Mixer do you have?
Dec 18, 2011 | Food Mixers
My older kenmore elite dryer releases lint into the room. I clean the lint trap after every load. We have redone the venting and made sure seams were taped with duct tape. Very disturbing because other...
You dont mention the model so I don't know where the lint screen is.
If it's on the top and a pull out type, the lint can be escaping past the seal where the filter meets the top of the dryer.Try replacing it as it's relatively inexpensive
Nov 25, 2010 | Kenmore Dryers
Does this washer supposed to have a lint filter
No Lint Filter sorry you have a basic design washing machine, Dont replace it though it wont do u any justice just pocketbook pain
Jun 17, 2010 | Kenmore 44932 Front Load Washer
My Kenmore Series 90 dryer won't run as it appears the door does not hit the actuator. It would appear either the door has moved to a lower position or the actuator has moved up into the dryer. May I ask...
The door switch or actuator is broken. A common problem. On most Kenmore dryers this is replace by lifting the top. Since you haven't given the whole model number I will discuss raising the top on the most common model.
If your model has a lint filter at the top the slide show below should show you how to raise the top.
Kenmore Dryer
Disconnect power to unit. Lift the cover from the lint filter or if yours is the one with a filter and cover together, remove the whole filter. You will see 2 screws under the cover/filter, remove them. Now, you will need a putty knife or a thin shafted straight screw driver to remove the top panel. Push the putty knife or screw driver to "pop" the front top clips. The top panel will hinge back towards the wall and can be left there. Just inside the top of the front panel, you will see 2 screws, remove them. You will see the wires for the door switch on the right side. *** the top of the front panel toward you to gain access to the switch for replacement.
Reverse process for reassembly. Good Luck
Sep 19, 2009 | Kenmore Dryers
Unable to locate lint filter
You can buy it online at this link below, just choose the color of your dryer..
Let me know if this is what you are looking for. Don't forget to rate me!!
Sep 13, 2009 | Kenmore 63942 Dryer
How to get into the cabinet? I have a Kenmore Dryer that hums but the drum won't turn, maybe belt! Model # 110 62942100 thanks, tom
Kenmore dryer belt
  • UNPLUG DRYER
  • remove lint filter
  • remove two screws in lint filter panel securing cabinet lid to filter frame
  • with putty knife or other blunt blade, depress clips ~2inches in from the front corners of the lid to release cabinet lid
  • tilt lid up
  • remove 1 screw from each side 1/3 the way down
  • remove cabinet front and door
  • motor bearings tensioner are all visible
  • lift out drum forwards
  • check support rollers felts and nylon glide bearings for wear
    (worn bearing surfaces are the most common cause of belt breakage, and you dont want to do it again next month)
  • make sure tensioner is still installed in cabinet base, sometimes breaking belts pull them out
  • loop belt around drum at prior wear marks
  • reinsert drum
  • pull tensioner to end of travel against spring
  • loop belt around motor pully and tensioner
  • relax tensioner
  • rotate drum by hand to make sure belt wont jump off.
Thanks
Fame !
May 04, 2009 | Kenmore 63942 Dryer
Finding Lint Filter on Kenmore 70 Series Model 110
I've got a Kenmore 70 Series, Model # 82370120 washer and the lint filter in under the machine. I had to tip the thing over to get at it.
Apr 19, 2009 | Kenmore 22422 Top Load Washer
Disassembling a kenmore dryer
does it have a top lint filter or a inside the front lint filter-?-mike
Oct 21, 2008 | Dryers
Dryer not drying cloths
HI thanks for your question. the lint filter housing is full of lint. remove the lint screen. 2 screws. remove. pry top up with a flat screw driver, from the almost the corner. lift the top up. pull dryer away from the wall remove the air duct that the lint filter goes in clean out the lint. thanks the appliance doc
Oct 16, 2008 | Kenmore 73952 Gas Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
177 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
