Bush hw60-146 giving err7 - Washing Machines
5 Suggested Answers
Daniel S
  • 4323 Answers
SOURCE: my bush WM-1460TVE washing machine
Hi
The problem seems to be with the door lock-switch assembly that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Jan 08, 2011
walesarumi
  • 6993 Answers
SOURCE: bush hw60 1460d wont spin
There are several reasons why a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
Find some possible cause and how to solve the problem:
A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
Good luck.
Posted on Jan 11, 2011
rickyrt441
  • 4399 Answers
SOURCE: have a bush hw60-1460d washing
Have you tried to unplug the machine? It may reset. The locking lid switch may be bad as well.
Posted on Feb 25, 2011
  • 6277 Answers
SOURCE: bush washing machine hw60 display
Suspiciously like 'unbalanced'!
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 24, 2011
How do i fix err7 on the powerfit3003 treadmill
If you wish to get some details about treadmill repair then check the following link
http://electro-medical.blogspot.com/
Aug 12, 2016 | Exercise & Fitness
What is err7 on the 1260tveme
Motor error or failure The washing machine has detected an error on the washing machine's main drive motor circuit but, like other errors cannot pimpoint he exact location or nature of the fault.
  • Check motor connector block
  • Check motor carbon brushes where fitted
  • Check wiring
  • Check tacho connections
  • Check motor
Jul 31, 2015 | Miscellaneous
My proline logic washing machine is displaying a err7 code and not spinning why
follow up if the plug is connected its not the connector Error 7 is also Error code for Motor Bushes which will need replacing !
May 04, 2012 | Washing Machines
Err 7 showing and not spinning, all wires connected to motor?
Haier 'err7' decodes as 'motor overheat protection or is damaged' which points to an engineer visit I'm afraid ;-0(
Sorry,
Good luck,
John C
Mar 26, 2011 | Haier Washing Machines
My xt2700 steelflex treadmill shows err1 code what is the problem amnd how do i rectify it
I an having a STEELFLEX 2700 Treadmill.
In the ELEVATION display its showing "Err7" and the running belt is elevated.Pleas kindly help me to rectify this problem.
My user manual also lost,if someone know the online manual please share the link.
Dilantha.
Mar 10, 2011 | Sport & Outdoor - Others
Err 7
Err7 is a motor error.Check out the following Haier washer manual link (page number 17).
for washer manual click here
The only solution suggested is to replace the motor.
Jan 08, 2009 | Haier Washing Machines
Trouble shooting
if it doesent spin at all could have a problem with motor carbons if you access the motor you will see two long stick like objects attached to the metal casng on the motor remove and chack the contacts have at least 10 mm of corbon
Sep 04, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
