Question about Nortel 2526T-PWR Ethernet Routing Switch with PoE - 24 x 10/100Base-TX LAN, 2 x 1000Base-T Uplink, 2...
Test Internal Loopback - FAILED Loopback error bitmap 86C76700000
Kyocera Mita c610 error
C0610 Bitmap (DIMM) problem
There is a problem with the data or
address bus of the bitmap DRAM.
Defective main
PWB.
Replace the main PWB and check for correct
operation.
DIMM installed
incorrectly.
Check if the DIMM is inserted into the socket
on the main PWB correctly.
Defective DIMM. Replace the DIMM and check for correct
operation.
Dec 15, 2014 | Kyocera Office Equipment & Supplies
Tip
Samsung Android secret code
This is secret code on Samsung <a href="http://www.androidmanual.net/">Android</a> phone. With this secret code you can access hidden phone information.<span></span>*#*#4636#*#* Phone Information<br />*2767*3855# Hard Reset*<br />*#*#7780#*#* Factory Reset**<br />*#*#7594#*#* Change End Call/Power Option<br />*#*#197328640#*#* Service Mode<br />*#*#273283*255*663282*#*#* File Copy Screen (Backup Media Files)<br />*#*#526#*#* WLAN Test<br />*#*#232338#*#* Shows WiFi MAC address<br />*#*#1472365#*#* GPS Test<br />*#*#1575#*#* Another GPS test<br />*#*#232331#*#* Bluetooth test<br />*#*#232337#*# Shows Bluetooth device address<br />*#*#8255#*#* GTalk Service Monitor<br /> Codes to launch various Factory Tests:<br /> *#*#0283#*#* Packet Loopback<br />*#*#0*#*#* LCD test<br />*#*#0673#*#* Melody test<br />*#*#0842#*#* Device test (Vibration test and BackLight test)<br />*#*#2663#*#* Touch screen version<br />*#*#2664#*#* Touch screen test<br />*#*#0588#*#* Proximity sensor test<br />*#*#3264#*#* RAM version<br /> Codes to get Firmware version information:<br /> *#*#4986*2650468#*#* PDA, Phone, H/W, RFCallDate<br />*#*#1234#*#* PDA and Phone<br />*#*#1111#*#* FTA SW Version<br />*#*#2222#*#* FTA HW Version<br />*#*#44336#*#* PDA, Phone, CSC, Build Time, Changelist number<br /> <b>Note :</b><br />* Hard Reset to remove all files and settings in internal memory, or equal to reformat the firmware<br /><b>* Warning! when it is direct push hard reset, there is no cancel option</b><br />* Factory Reset just delete the account, system & application settings
on Feb 02, 2011 | Cell Phones
Tip
Coping with and avoiding Hard Drive Volume Bit-map Errors
If your computer "locks up" or reboots itself, the problem is frequently lost or corrupted files on your hard drive. Most of the time the problem can be corrected by running chkdsk. However, one of the exceptions is when chkdsk reports that the hard drive has volume bitmap errors.<br /> To run chkdsk, click on Start, All Programs, Accessories and Command Prompt. This will open a "DOS Box" where you can enter DOS commands without the results scrolling off the screen before you can read them. Then key in chkdsk C: (assuming that drive C is the letter of the hard drive where your operating system files and applications programs are stored).<br /> Chkdsk will run in the read-only mode and report (but not repair) problems found on your hard drive. Chkdsk will then ask you to run chkdsk with the F switch to fix the file system. Make a mental note whether or not chkdsk reported any problems with the volume bitmap, then key-in chkdsk C: /F <br /> You will get a message that the drive will be checked (and repaired) on the next system restart.<br /> Enter exit to close the DOS box and the restart your system. Chkdsk will run automatically when your system restarts. If no volume bitmap errors were noted earlier, chkdsk should have repaired the problems with the hard drive. You can verify this by opening another DOS Box and running chkdsk without the /F. However, if bit-map errors were reported initially, chances are they will still be there as chkdsk cannot repair them.<br /> If you still have volume bitmap errors, you can either take your PC to a professional who may be able to repair the volume bitmap with specialized software, or you can back-up all of your data, format the hard drive, and reload the operating system and all applications.<br /> A frequent cause of volume bitmap errors is cloning (copying) a hard drive with more than one partition to another (usually larger) hard drive. The partitions should be sized proportionately on the target drive but sometimes the partition sizes are not reported correctly in the partition table and sometimes in the master boot record. <br /> Avoid cloning drives with multiple partitions, or if you do, immediately run chkdsk on the target drive to check for bit-map errors.
on Oct 25, 2010 | Computers & Internet
We have an HP 3600 printer we are trying to use with windows 7, and got the error, PCL XL Error, Subsystem : KERNEL, Error : MissingData, Operator: VendorUnique, Position : 81
First, delete the printer from the "devices and printers"
Second, go to www.hp.com/support
Download and install the latest drivers.
Now try printing.
Looks like the PCL driver got hosed.
Jun 07, 2011 | HP Office Equipment & Supplies
Fluke 1651portable multifunction tester is displays Err 1
Error 1 is an indication that the self test has failed. This will require repair at an authorized Fluke service center. There is an internal problem with the meter. The only thing that you can try is to replace the internal battery. Should the battery be defective, the internal testing can be effected. I have only seen this occur once, but it is worth the attempt. Should a new battery not fix the problem, return the meter to Fluke for repair.
Dan
Apr 15, 2010 | Fluke Networks Fluke T+PRO Electrical...
Loopback failed - 127.0.0.1 blocked - web page test not possible
Please explain:
Does it work if you use http://localhost?
Does it work if you use http://127.0.0.1?
If the first one does not, but the second does, it is possible that the issue can fixed simply by selecting.
IE-->Tools-->Options--> Connection --> LAN Settings Check Bypass Proxy for local addresses
If you can't telnet into your computer, make sure you have the Telnet service running :
  1. Click Start, then Run, and type "services.msc" (without quotes) and click OK.
  2. Find the "Telnet" service, right-click and select Properties, select "Automatic" instead of "Disabled" in the startup type box.
  3. Click Apply.
  4. Right-click the "Telnet" service and select Start.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
May 19, 2009 | Zyxel Prestige 600WH Wireless Router...
Hello. I ran a hardware diagnostics test on my network card (NVIDIAnForce), the cable, link, and loopback test passed, but the Network communications test failed displaying an error code- NC315-1W. Could...
as for the error code, it's fairly generic, but indicates that your network card is having trouble communicating with the network. The good news is this is most likely not a hardware issue, but would most likely be caused by either a bad driver.
It is also possible that a firewall product, such as McAfee provides with it's antivirus software could be interfering with your network card's communications.
After you've tried replacing the driver, disable your antivirus software for a minute and test you connection to another computer or the internet (only a name brand site you absolutely trust) if the problem goes away, then try changing your firewall settings on that program or try a different program altogether.
That should cover most of the problem.
Jul 09, 2008 | Computers & Internet
NIC too close to USB port?
Hi Antatg,
Go into your bios and make sure all your USB option are enabled, specially Enable USB for legacy devices, and check to make sure you NIC is enables. Hope that helps!
Good Luck!
Jan 07, 2008 | Dell Dimension 1100 PC Desktop
Nortel 2526T-PWR Ethernet Routing Switch with PoE - 24 x 10/100Base-TX LAN, 2 x 1000Base-T Uplink, 2... Logo
436 people viewed this question
Top Nortel Computers & Internet Experts
Jax Planet
Jax Planet
kwiz
Level 1 Expert
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
