Question about Microsoft Windows 7 Home Premium 64BIT Operating System Software OEM DVD
My system restore couldn't run and so as all of my .exe files couldn;t open...
  • 496 Answers
Please take a close look in your System restore pane are there any restore point(s). If there are no restore points you will not be able to restore your system. System restore point is an image file taken from a previous Windows state is time and is vital to restore your system.
Posted on May 17, 2011
Hellow.. can you help me, because everytime I open my files and programs has an error message like this "no such interface supported". and even I use my restore system the same message appeared,...
As of right now I know that these "No such supported" errors are caused by a dll issue. Which dll I am unaware of at this time. So to resolve the issue I re-registered every dll on my system. To do this follow the below steps.
Register all dll files within registry
1) First go Start/Run, and type in 'cmd' to bring up the Command Prompt.
2) Type 'CD \' and hit enter.
3) Type 'DIR *.dll /s /b > regdll.bat' and hit enter.
4) Type 'Notepad regdll.bat' and hit enter.
Now Notepad is going to bring up a list of your .dll files, never mind that for a moment.
5) Now type 'Path' and hit enter to see your current path. It will bring up something like: Path=c:\Windows;c:\windows\Command
6) (supplement your Windows Version, ex: C:\WINNT, or C:\Windows) Now type: 'Path=c:\windows;c:\windows\Command;c:\Windows\Pro g
ram~\Accessories' and hit enter.
7) Verify again by typing 'Path' and hitting enter, and then type: 'C:\WINNT\System32\Regsvr32.exe /s C:\' and hit enter again.
Now, go back to Notepad and if you have Win98 use the replace feature in Wordpad (CTRL + H) or notepad to search for 'C:\' and replace it with this: 'C:\Windows\System\Regsvr32.exe /s C:\'
If you have Win2000, etc. use the replace command in note pad to search for 'C:\' and replace it with this: 'C:\WINNT\System32\Regsvr32.exe /s C:\'
*Be sure to type the replace string exactly like above or it won't work*
9) Use "Replace All" to make the changes to the entire file.
10) When it finishes, save it, exit notepad or wordpad, and return to the Command Prompt.
11) Type 'regdll' and press enter. If you followed the above steps correctly it will now go through and re-register all your .dll files.
An example of a line from my bat is below
"C:\Windows\System32\regsvr32.exe /s C:\Program Files\Common Files\Microsoft Shared\ink\IPSEventLogMsg.dll"
You may receive numerous errors during this mass registration, simply clear them by clicking OK or whatever you need to to clear the error and the bat file should continue to run. The process may also seen to hang and become unresponsive. Be patient, go get a cup of coffee, a bawlz or smoke a cigarette. I am confident this will resolve your issue. It solved three for me, one involving media player, one involving the right click screen resolution option in the context menu and one involving the personalize context menu option.
Thanks so much for this cool solution..! It not just takes care of this error, but I believe it refreshes every other library related stuff too.. Thanks again!
Jul 05, 2011 | Microsoft Windows 7 Ultimate for PC
Tip
How to remove the scvhost.exe Virus.
Svchost.exe is the name of a generic host process for services that run from dynamic link libraries (DLLs). A variety of worm malware programs spread a similarly named file <b>Scvhost.exe </b>via Yahoo! Messenger that blocks the Task Manager and Registry Editor, as well as use of the command prompt.<br /> <br /> <b><u>Warning</u></b><br /> Manual removal of Scvhost.exe may be very difficult as the removal process requires knowledge of the Operating System's command prompt and Registry Editor. If not performed properly, your computer system might experience permanent damage. Consequently, manual removal might be best for experienced users. Less experienced users might want to consider using an automatic spyware removal application, such as that offered by Trend Micro. This worm duplicates itself to different locations of shared folders. The duplicated program uses a folder icon that has an .exe file extension. DO NOT double click on any of these folders.<br /> <br /> <b><u>Follow these step by step instructions to remove the scvhost.exe virus.</u></b><br /> <b></b> <br /> <b><u>Step 1 (Turning off System Restore)</u></b><br /> This is so that if you ever need to use System Restore after you have removed the virus, it doesn't restore the virus aswell.<br /> <br /> If the operating system of the infected computer is either Windows Me or Windows XP, turn off System Restore while this fix is being implemented. To turn off System Restore within Windows Me, click <b>Start &gt; Settings &gt; Control Panel</b>. Double-click <b>System</b>. Select F<b>ile System</b> from the Performance tab. Left click the <b>Troubleshooting</b> tab and check the <b>Disable System Restore</b> box. Click <b>OK</b>. <br />To turn off System Restore within Windows XP, log in as Administrator and click <b>Start</b>. Right click <b>My Computer</b>" and select <b>Properties</b> from the shortcut menu. Check the <b>Turn off System Restore</b> option for each drive on the System Restore tab. Left click <b>Apply</b> and <b>Yes</b> to confirm when prompted. Click <b>OK</b>.<br /> <b></b> <br /> <b><u>Step 2 (Run in safe mode)</u></b><br /> Restart your computer in Safe Mode and log in as Administrator. Press <b>F8</b> after the first beep occurs during start up, before the display of the Microsoft Windows logo. Select the first option, to run Windows in Safe Mode from the selection menu.<br /> <b></b> <br /> <b><u>Step 3 (Accessing Command prompt)</u></b><br /> Access the command prompt. Click <b>Start &gt; Run</b>. Type <b>cmd</b>. Click <b>OK</b>. Then in the command prompt type <b>cd </b>to<b> </b>change directory then press the space bar. <br />Type the name of the full directory path of the folder containing your Windows system files. It will be either <b>C:\Windows\System </b>or<b> C:\Windows\System 32</b><br /> <b></b> <br /> <b><u>Step 4</u></b><br /> From the command prompt, type the following to unprotect the files for removal:<br /><b>attrib -h -r -s scvhost.exe</b> and press <b>Enter</b>;<br /><b>attrib -h -r -s blastclnnn.exe </b>and press<b> "Enter</b>;<br /><b>attrib -h -r -s autorun.inf</b> and press <b>Enter</b>.<br /> <br /> <b><u>Step 5</u></b><br /> Delete the files by typing the following from the command prompt:<br /><b>del scvhost.exe</b> and press <b>Enter</b>;<br /><b>del blastclnnn.exe</b> and press <b>Enter</b>;<br /><b>del autorun.ini</b> and press <b>Enter</b>.<br /> <b></b> <br /> <b><u>Step 6</u></b><br /> Type "<b>cd\</b>" to return to the main Windows directory.<br />Unprotect and delete the Autorun.inf file by typing the following from the Windows directory command prompt:<br /><b>attrib -h -r -s autorun.inf</b> and press <b>Enter</b>;<br /><b>del</b> <b>autorun.inf</b> and press <b>Enter</b>;<br />Type <b>regedit</b> and press <b>Enter</b> to open the Registry Editor.<br /> <b></b> <br /> <b><u>Step 7</u></b><br /> Locate the following entry:<br /><b>HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run</b>.<br />Delete the incorrectly spelled Yahoo! Messenger entry with the value<br /><b>c:\windows\system32\scvhost.exe.</b><br /> <b></b> <br /> <b><u>Step 8</u></b><br /> Locate the following key:<br /><b>HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon</b>.<br />Within the key, there is a <b>shell</b> entry with the value of <b>explorer.exe, scvhost.exe</b>. Edit the entry to remove the reference to Scvhost.exe, leaving Explorer.exe as the remaining value in the registry entry.<br /> <br /> <b><u>Step 9</u></b><br /> Locate the following key:<br /><b>HKEY_LOCAL_MACHINE&gt;SYSTEM&gt;CurrentControlSet&gt;Services&gt;<br /></b>Delete the following subkeys from the left panel:<br /><b>RpcPatch</b><br /><b>RpcTftpd <br /></b>Exit the command prompt and return to the operating system. Type <b>Exit</b>, and press <b>Enter</b>.<br /> <br /> <b><u>Step 10</u></b><br /> Reboot the PC.<br />If Scvhost.exe still resides on the computer, repeat these steps or try using an automatic removal program from McAfee or Symantec.<br /> <br /> <br /> <br />
on Feb 25, 2011 | Computers & Internet
Tip
Generate a .cab file to troubleshoot System Restore
To generate a system restore Cab file please use the following procedure:
1. Click Start, click Run.
2. Type or paste the following: "%windir%\system32\restore\srdiag.exe" (without the quotation marks) and either press Enter or click OK.
3. A CMD window will open while the Srdiag.exe runs. The CMD session will automatically close when complete, and the .CAB file will be created as desired in your 'Windows\system32\restore' directory. Please be patient as this could take several minutes.
on Mar 18, 2008 | Microsoft Windows XP Professional With...
I changed the standard program to run the exe file of a dos game to dosbox to launch it faster, this works great, but the problem is that all my other exe files are now impossible to run because i also...
Go to the link below and download the EXE File Association Fix. (I know it says win XP but it works fine in Vista and Windows 7 as well). Unzip that file and run it. You should be all set after that.
http://www.dougknox.com/xp/file_assoc.htm
Jun 27, 2011 | Computers & Internet
Hi, As soon as i try to open any file on the hard disk, I get this message (in spanish) : "Windows can't find the file Recycler/b845cf76.exe. Be sure name is correctly written and try...
You computer is/was infected by a virus. What you first need to do is make sure any virus software you are running is up-to-date and run a full system scan. make sure any viruses it finds are dealt with. you then need to go to Start - Programs - Control - System- System Restore and turn off system restore on all of your hard drives. This will remove your restore files from the system. This should not be a problem as you will be creating a new one shortly. Shut down the system. Restart the system and run another full system scan. If that comes up clean, go back into System Restore and turn it back on. You should be good to go at this point, so try to open a file on the system. If you require additional assistance, please do not hesitate to ask.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 09, 2011 | Samsung Computers & Internet
I have vaio vgn-fw390. my lab-top can not hibernate neither in windows nor in linux. i'll thank you if you solve my problem
Try running a system restore and restore your system back to an previous date when your hibernate is working.
Open System Restore by clicking the Start button, clicking All Programs, clicking Accessories, clicking System Tools, and then clicking System Restore.? If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Note: Before you start System Restore, save any open files and close all programs. System Restore will restart your computer.
Or Try
sometimes the BCD file may have issues.
You can try this to fix the BCD file.
1. Run CMD.EXE as administrator
2. Run the following command: bcdedit -enum all
Look for "Resume from Hibernate" in the output from the command above(example below):
identifier {3d8d3081-33ac-11dc-9a41-806e6f6e6963}
device partition=C:
path \Windows\system32\winresume.exe
description Windows Vista (TM) Enterprise (recovered)
inherit {resumeloadersettings}
filedevice partition=C:
filepath \hiberfil.sys
pae Yes
debugoptionenabled No
3. Once you have found it, copy the value for identifier (in this example - {3d8d3081-33ac-11dc-9a41-806e6f6e6963})
4. Run the following command: bcdedit /deletevalue {3d8d3081-33ac-11dc-9a41-806e6f6e6963} inherit
5. Test hibernation.
May 14, 2011 | Sony Computers & Internet
Im unable to open any downloaded exe. files and i cant access my system restore. my operating is windows xp pro
If possible, try to run your computer in safe mode. Use Malware Bytes to scan and remove virus. If it won't open as an .exe, try changing it's extension.
Oct 24, 2010 | Microsoft Windows XP Professional SP3 Full...
Able to download the exe file obtained online onto
Have you tried to restart your computer?
Is the error only appears to this software?
Did the file came from HP's official site?
That file might be corrupted
try to download the file again
Feb 26, 2010 | HP Photosmart 7850 InkJet Printer
Everytime i try to open an application or anything, it says the file "rundll32.exe" is not a win32 file, how do i change
Hi hansomeone45
Maybe you have virus on your computer, and it has infected the file rundll32.exe and therefore you cannot use it.
You can try several things I explain here :
IF you have a backup copy of your hard disc´s you can restore from the backup copy.
You can try to system restore in at the : start- all programs- accessories- system accessories- system restore
or in : start- help and support- and there find "system restore"
System restore will roll back the computer as it was before (day, week, month ago).
You can reinstall the computer for the procedure please look here :
http://support.microsoft.com/kb/315341
You can read about the file here :
http://en.kioskea.net/contents/processus/rundll32-exe.php3
Or you can try to run this app :
http://www.rundll-exe.com/
OR
http://www.goarticles.com/cgi-bin/showa.cgi?C=1945037
Remember you can try to copy the file from another computer to your computer !
Hope that helps
Have a nice weekend
Please rate my answer
Sep 25, 2009 | Microsoft Windows XP Home Edition
Im having a problem with this virus known as funny ust scandal,which have same effect like the others who eencounter the problem..it automatically controls my yahoo messenger and sending the virus likewas...
Following can be tried
1 Update your virus defination and remove the virus
2. Run ksaper or Trend micro online scan
3. Do asystem restore so that ur pc will return to his normal status
  • format c drive & install windows
  • AVOID OPENING ANY FOLDER BY DOUBLE CLICK - USE THE EXPLORE BUTTON.
  • to folder options, show hidden files, show system files.
  • Make a search for (*.exe), inslude hidden files in ur search
  • delete found files (xmass.exe , funnyscande.exe , autorun.info)
  • delete any files in the system restore that has the same icon.
  • robably the problem will be done now .. but you can use kasper online scan
4. Download a registry cleaner and run on system (cclean is good tool)
Apr 14, 2009 | Microsoft Windows XP Professional With...
Microsoft Windows 7 Home Premium 64BIT Operating System Software  OEM DVD Logo
62 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
