Wilson Jones 2000 shredder has completely shut down. What year is this shredder from? Several services calls put the machine back in working condition, but this past shut down seems final. Please advise and if you have a brief manual you could fax we would appreciate your help.
alvinbga
  • 130 Answers
SOURCE: Brother Intellifax 1270E plain paper fax
It could be either. take the machine to anothewr line see if the
error goes away.If it does not call brother customer service. There is an adjustment for input sensitivity of so brother fax machines. It may be in your operators manual
Posted on Jun 11, 2008
SOURCE: fax laser panasonic 402
??test??
Posted on Aug 26, 2008
SOURCE: "Call Service 3"
ok thait is right
Posted on Jun 03, 2009
JayBlair
  • 328 Answers
SOURCE: drum error message
check the silver spring loaded contacts inside the drum cavity make sure they casn be pushed in and spring back out. Also clea them with a dry cotton swab
Posted on Jun 11, 2009
  • 18 Answers
SOURCE: New help getting Pitney Bowes 8050 fax machine to work
The code is the same as the model number 8050, Your battery has failed and will not keep it's settings if it loses power.
Posted on Aug 24, 2009
My 17 year old Wilson Jones 1153 Model shredder can't be left plugged in-It drains the electrical circuits and turns our heater off. Other than that,it works great.Is this worth repairing-Suggestions?
Just take it apart and unplug the switch that is keeping it on. take pictures when you pull apart the cases. sometimes some of the screws are under labels. Should be no more than five screws. Paper has an oily presence and causes these type of failures.
Apr 18, 2017 | Wilson Jones Office Equipment & Supplies
Our Wilson Jones 2000 shredder is jammed. I put too many papers in it at once, didn't realize they were folded on the bottom. How do I clear the jam?
Try reversing it. If that fails, get access to the shredding mechanism (with power off) and pick the paper out piece by piece and bit by bit.
Oct 21, 2016 | Shredder Office Equipment & Supplies
How do open and close Wilson Jones 365-49 Large Handing Post Binder
Open the binder flat, press the top right stick thing (sorry, don't know a better word for it), and press it to your right. Lift the metal (right side) up and out. To put back in, just place in the papers, and then take the right metal strip of three prongs, and snap it back into place. Hope this makes sense.
Apr 05, 2012 | Wilson Jones 365-49 Large Hanging Post...
Shredder is Wilson Jones 130 auto. I believe staff shredded to many sheets at one time. No no lights no power forwards or backwards. Is there a reset or fuse, can't find one
Oddly, my Wilson Jones 130 auto just did exactly the same thing. I'm the only one that uses it (that I know of) and one day it worked, the next it didn't. There is no paper stuck in it. There are no power lights, nothing works. Does anyone know the location of a reset button or something?
Jun 21, 2011 | Office Equipment & Supplies
I would like to know how to oil an Wilson-Jones 1250 schredder.
Wow, a name from the past.... with any shredder the easiest way to "oil it" is just to put a bead of oil in an "S" pattern down a sheet of paper to be shredded and then shred the sheet of paper.
If you shred a lot you should do this more frequently...if its only occassional shredding OR if its a strip cut shredder then you don't have to do this as often.
Jun 16, 2011 | Office Equipment & Supplies
Paper Jam in Wilson Jones 1500. Reverse doesn't clear it. Is the plastic cover where the paper is fed removable?
You should probably unplug it. Two screws in back and under. Slide front cover back an inch.Disconnect cable and clean unit with vacuum.
You can hand cycle it in both directions to loosen up the blades.
Aug 12, 2009 | Office Equipment & Supplies
Need forward & reverse plastic key buttons
Spray some contact cleaner into the buttons and this may free them up. try this
Apr 15, 2009 | OfficeMax 0M96431 Shredder
Shredder says service due. cannot clear display
Clearing the "Service Due" prompt:
1. Lift safety flap (plastic cover over paper entrance).
2. Depress Reverse and Stop button simultaneously 2-4 seconds.
3. LCD display reads, "Service Info 1"
4. Press Stop button once to obtain "Service Info 2"
5. Depress Forward and Reverse buttons simult. 2-4 seconds.
6. "Service Due" prompt will be cleared and service hours zero.
7. Snap safety flap down to close.
Apr 06, 2009 | ACCO Brands Office Equipment & Supplies
286 people viewed this question
jasbo
jasbo
