Question about Kenwood Car Audio & Video
Me deck doesnt save presets or anything - Kenwood Car Audio & Video
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Kenwood Master
  • 2,226 Answers
Check to see if the yellow wire is going to a constant power source, ie it still has power when the key is turned off.
Posted on May 17, 2011
My record player plays slow in 33 speed how can I fix it?
It depends if the deck is a belt driven model or Direct Drive.
If it is a belt model then it's possible that the belt is not in the correct place. Some decks have speed preset control for the two speeds. Sometimes it can be found hidden under the deck. It will be adjusted by a small screwdriver. You will of course have to get the speed right yourself. The preset can sometimes be found inside the deck. Most likely accessible via the underside of the deck.
A direct drive model has separate circuits for the two speeds and would require a technician to sole the problem.
Oct 04, 2015 | Audio Players & Recorders
How do i enter the code when i have higher digits than 6 in it ?
Not knowing what deck you have I am going to assume that you need to press the number 1 preset until it comes up with the first digit of the code. You need to follow the same procedure for the number 2,3 and 4 presets for the other digits. I don't know if you will have to press anything else after that because I have no idea what deck you are dealing with.
Sep 22, 2011 | Car Audio & Video
Why doesnt it save my clock and preset settings
There is a wire on your stereo called the (constant) wire, it is usually either yellow or orange, this wire needs to be spliced into your power wire. It is constantly hot,hence the name. Find this wire and your presets and your clock should be good to go. let me know if this helps
Nov 25, 2010 | BOSS AUDIO SYSTEMS BV9994I Car Video...
How to preset radio stations on a panasonic cq-7401u head unit
you tune to the station you want then press and hold a preset button
Nov 17, 2010 | Panasonic Car radio CD CQ-C1110GN CD...
Hello, I cannot get my device to transmitt to any Radio Frequeny in mycar, how to do it? and does this device has its Internal memory to save songs?
try turning on your device and let it play for a while and turn on your deck and put it on FM (most portable transmitters work on this band) and hit seek till you know it hits your devices frequency (usually you can set a frequency for your device via its settings or if its preset use your deck to find it)
i hope this helps
Aug 06, 2010 | Car Audio & Video
How do u enter 0 when entering code for car radio when only numbers 1-6 on radio?
for the first digit you need to press preset 1 until the number you need comes up, usually the first number will be 0. goes from 0 to 0. once you have the first number you go to preset 2 and repeat the procedure. repeat this procedure for the next presets until the code is entered. not knowing what the deck is, i don't know if you need to press anything else. for some decks you simply have to enter the code. for others you need to press another button.
Jun 11, 2010 | Car Audio & Video
AV1C-N3 problems
yellow wire on back of pioneer unit is probably on wrong wire try switching it with the red wire ........yellow is constant power (saves memory time and last part of song or movie so when you get in the car again it will start from where it left off) if this doesn't work ground it to the car itself (black wire to frame not wire in-dash) try the wire switch first ........hope i was able to help
Jan 31, 2009 | Pioneer AVIC-N3 Car DVD Player
Does the light always on (on the pioneer deh-45dh)
them yes, it is normal. the small light around the deck is just a feature to make it look nice. it wont hurt the battery, it uses no more electricity than it does to save the presets in the radio. your good:-)
Jan 05, 2009 | Car Audio & Video
ONKYO HI-MD DECK md-133 can't edit Sonic Stage formatted minidiscs
Anything downloaded from Sonicstage in Atrac3plus cannot be edited on the deck. Sony put that restriction so you don't change anything. They love DRM on music. Stick to old MD, much better.
May 08, 2008 | Audio Players & Recorders
Car Audio & Video Logo
19 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
