Question about Volkswagen Car Audio & Video
The radio in our 96 VW Jetta doesn't work - which
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Volkswagen Master
  • 2,226 Answers
You may want to go ahead and check all of your fuses as almost all radios these days require two power sources in order to work.
Posted on May 17, 2011
Hello , I have a new Tiguan trend and fun 2.0 and my dash light and radio won't work.
Check the manual and find the fuse box or boxes. find the dash lite fuse, it may say " interior illumination" If it is good check also the radio fuse.
If the fuses are good, you have to visit a wv dealer for detailed fault finding.
If the car still have warranty, don`t mess with the electrical system.
The car also have can bus electrical system, and it can go wrong when you try to fault find your self.
The fault could be the light switch, fuses, the radio.
Here is a fuse list for a golf:
http://mit.edu/dennis/www/vw/fuses.html
Check the Fog light relay, instrument panel light dimmer switch fuse.
Good luck
Jan 08, 2013 | RupseTM For VW: New BORA / PASSAT CC /...
I have a 96 vw jetta and i cannot find the safety neutral switch
My 98 Golf (manual trans) doesn't start during hot weather; are you possiibly talking about what is also referred to as the 'clutch switch'? (makes it so clutch pedal must be pushed in to start car) If so, I understand it's under the clutch pedal... looking to purchase switch now, so this is about all I know for now. Hope this helps...
Sep 01, 2012 | 1998 Volkswagen Jetta
In just bought a 2010 Jetta TDI and it has the touch screen radio. I was playing with it and now the touchscreen doesn't work...almost like i disabled the touch part. How do I turn it back on to the...
I would give VW a call.
Try here:
http://www.vw.com/customerservice/contactus/en/us/
Other websites with Jetta help:
http://repairpal.com/cars/volkswagen/jetta
http://www.a2resource.com/
Have you checked the fuse box? There should be a dedicated radio fuse.
Cheers,
Steve
PS please vote on my answer or give a testimonial if I have helped out.
Oct 12, 2010 | Volkswagen New Jetta Cars & Trucks
Where is the fuse to my radio? on my 2001 1.8t jetta
there is a fuse in the back of the radio if the other fuses are good i am a vw tech and if it is a vw radio in the car you are lucky it lasted this long it is probably a bad radio
Apr 30, 2010 | 2001 Volkswagen Jetta TDI
I own a 2000 VW Jetta. Radio completely Dead
Have you checked the radio fuse? You may have blown the fuse when you jumped the car. The fuse box should be out under the hood encased in black plastic.
Jan 06, 2010 | 2003 Volkswagen Jetta TDI
1997 vw jetta radio does not work fuse is okay
sounds like your good olld blapunkt internal fuse is cooked
pull the radio out and look to see if there is a fuse behind the radio
Dec 31, 2009 | 1997 Volkswagen Jetta
The radio just turned off in my 02 vw jetts
This seems to be a common problem with this series of radio. If you open the drivers door and pop the fuse panel cover off the side of the dash, then locate fuse number 42 ( should be 25 amp). Remove the fuse, check to see if it is blown(it usually isn't), if it isn't blown leave it out for about 30 seconds to 1 minute and then reinstall. Hope this helps it worked on my 02 Jetta TDI.
Nov 07, 2009 | 2002 Volkswagen Jetta TDI
96 vw jetta doesn't shift
you might have bad ground to transmision that happen to my 01 jetta were it would just kind of rmp no shifting gears dealer said it was bad ground to trany
Apr 19, 2009 | 1996 Volkswagen Jetta
Place for a fuse in jetta gl 96
INSIDE THE COLUMN  RIGHT BEHIND THE STEERING WHEEL
Sep 15, 2008 | 1996 Volkswagen Jetta
2002 vw jetta radio panel does not turn on nor the radio works.
Fuse number 42 is for the radio reset. Pull it out and put it back in. It's a warranty problem, expired now no doubt.
Aug 19, 2008 | 2002 Volkswagen Jetta TDI
Car Audio & Video Logo
185 people viewed this question
Top Volkswagen Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Jose Velazquez
Jose Velazquez
Are you a Volkswagen Car Audio and Video Expert? Answer questions, earn points and help others
