Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Water is in the bottom of frig, whirlpool inside advantage, et1chk/et1chm,
  • Whirlpool Master
  • 8,220 Answers
That water should be draining out the hole in the evaporation compartment. The defrost drain is stopped up. Remove the service panel and get the junk out the hole and the water from defrost will drain out instead of in the bottom.
If ice is forming in the hole a neat trick to know is to run a wire from the defrost heater down in the hole a hair to keep ice from forming over the drain hole.
Posted on May 17, 2011
I need to replace the interior water line on my Whirpool Frig. I had stored the frig in a very hot trailer for 2 weeks. It seems that the poly Eth water line inside the frig and developed mold. I removed...
Hello Phillip! We are terribly sorry to hear of your concern with your Whirlpool Refrigerator. We would recommend the use a Local Certified Technician in your area to properly replace that water line. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name,user id (Phillip), phone number, street address, zip code, model & serial number, and date of purchase on the appliance. We look forward to your reply.
Jun 17, 2017 | Whirlpool GD2SHGX Refrigerator
I have Whirlpool frig. When it goes into defrost water drip inside the frig and collects at the bottom. The water appears to be coming into the frig through a channell in the center back of the freezer...
Hi Patrick, Looks like you have a drain hole that is plugged up with ice, there is a easy way to fix it, I will refer you to this video that shows you how to clear the drain. Take care Ryan http://www.youtube.com/watch?v=_ycWz_U_GDU
May 29, 2011 | Refrigerators
Water at bottome of refrigerator
Under the draws in the back, there should be a drain hole that drains water down to the drain pan under the unit. Check to make sure it's not blocked with food or frozen water.
Jul 16, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Very slow drip from water dispenser. How do I fix
Good day,
A slow continues drip, but still dispenses O.K. is caused by the dual water valve on the bottom rear of the machine not closing completely.
Only fix is replacing the water valve assembly.
Mar 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water in bottom of the fridge. I figured the
copper wire is best with a bit of cloth to pull thru
Feb 05, 2010 | Whirlpool 20.9 cu. ft. Top Freezer...
Hi, I have a 20.9 cf (#ET1CHK/ET1CHM). Water
I HAD THE SAME ISSUE EVERY FEW MONTHS. REMOVE THE BACK COVER IN THE FREEZER, YOU WILL SEE A SILVER TRY WITH MOST LIKELY ICE IN IT. THAW THAT ICE AND THERE IS A DRAIN HOLE IN IT. USING A HAIR DRIER GET THE TUBE TO THAW ALSO. ONCE WATER IS FLOWING TAKE A PIECE OF 12 GAUGE BARE COPPER WIRE AND SLIP IT ABOUT 18" INTO THE HOLE. WRAP THE OTHER SIDE OF THE WIRE AROUND THE WIRE COIL YOU SEE WHICH IS THE DEFROSTER. WHEN IT WARMS IT WILL HEAT THE WIRE ALSO AND KEEP THE DRAIN CLEAR
Dec 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Defrost parts missing ? Whirlpool ET1CHK / ET1CHM
there should be a wiring diagram in the kick grille at the bottom of the refrig.
Mar 02, 2009 | Refrigerators
Water dripping from somewhere inside the refrigerator
I believe the problem is with the drain line when the frig goes into defrost mode
see if you can trace the drain line that oes into the evaporator pan at the bottom of the frig
facing the frig remove the bottom panel that goes across the front and pull out the evaporator tray to see if it is dry
take a flashlight and see if you can see a plastic tube that the water should be dripping into the pan
try to trace the tube up into the frig ther is some type of catch basin inside the frig on the back panel usually around middle area
If you are not able to find it you can call whrlpol customer service 1-800-253-1301
or call an appliance service enter and as them f they can walk you through the problem
Good Luck
Jan 02, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Is there a filter to be changed ar cleaned on the water dispenser?
MOST FILTERS ARE LOCATED INSIDE THE FRIG. TOP RIGHT,OR ON THE BOTTOM FRONT BY THE GRILL OR ON THE WATER LINE BEHIND THE FRIG. .LET ME KNOW-MIKE
Jun 25, 2008 | Whirlpool Refrigerators
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
328 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
