I get a black screen on my Aspire 5610-4720 laptop that is telling me there is a media test failure & to check cable & another message that says, " exiting broadcom PXE ROM. operating system not found?..What can I do to fix this laptop?
    Problem Solver:
  • 14 Answers
Looks like your hard drive has a problem and cannot be recognised. The laptop is trying to boot from the network ( PXE rom). Check the bios to see if there is a hard drive present. If not it is most likely the electronics of the hard drive - replace it. When you turn on the laptop listen carefully around the hard drive. Do you hear a clicking or repeated set of sounds. If so there is a physical problem with drive - replace it. If it sounds like it is spinning up ok you could try a reinstall of OS. Most likely this will fail, and, even if it does it most likely will reoccur.
Good luck
Posted on Aug 14, 2008
I turned laptop on and get this message over and NVIDIA Boot Agent 249.0542 Copyright (C) 2001-2005 NVIDIA Corporation Copyright (C) 1997-2000 Intel Corporation PXE-E61: media test failure, check...
your harddrive is either failed or your harddrive master boot record is corrupt and you will have to reinstall windows or the linux you used
Dec 14, 2010 | Computers & Internet
When I turn the computer on, I get the following message: PXE-E61 media test failure, check cable PXE-M0F exiting intel boot agent Reboot and select proper boot device or insert boot media in selected...
This happens when the BIOS can't find the hard disk. If you're lucky it's just the hard disk that has failed, if you're not it's the motherboard itself the one that failed.
To find out which replace the hard disk with a good one then try to boot in th BIOS - if you can it's the hard disk, if you can't it's the motherboard.
Nov 26, 2010 | Gateway 510 X (10272197) PC Desktop
Hi When I start up my Acer Aspire L100 mini desktop, it makea clicking noise, which emits from with the computer and then the computer freezes with the screen below. Also, sometime I have to power off on,...
You can solve this problem by:
-- cleaning system junk
-- optimizing computer services
-- repairing registry
-- defraging registry
-- clearing browsers junk
do these things with some secure tool such as Intel Software Partner Reginout.
Also remember to uninstall and reinstall updated drivers for your devices. Thanks
Nov 10, 2010 | Acer Aspire L100 PC Desktop
My aspire l310 won't boot. It keeps telling me media cable test failure and disk boot failure. Help daniel
sounds like hard disk related. turn it off and disconnect the power cord, remove and reconnect both the power and data cables to the hard disk, disconnect any external USB storage and remove any floppy disk, if any. If you get the same result, try to connect the har disk using different power & data cables (IDE/SATA), and test it on another SATA channel if available. If same error, you may need to reformat the hard disk and reinstall WIndows, or you may have to get a new Hard Disk if it fails even when tried on another computer.
Aug 31, 2010 | Computers & Internet
PXE-E61 media test failure check cable
Your unit is telling you that there is a cable problem (between HDD & MoBo) try a new one or if you have another drive with same cable swop over.
Sep 18, 2009 | IBM NetVista PC Desktop
GETTING MESSAGES.....HARD DRIVE NOT INSTALLED MEDIA TEST FAILURE, CHECK CABLE.....IBM T22 LAPTOP
Most likely is your hard drive connection is not functioning. Can you please provide more details on the problem? Does it happen every time you try to boot, or only sometimes? Have any new devices been added? Memory changed? Computer dropped or immersed in water?
Jul 13, 2009 | Lenovo Computers & Internet
Failure hdd at startup
This error indicates the hard drive is not detected or not plugged in. Open the case and see if the hard drive cabling is connected. Some SATA cables don't stay connected particularly if the cables do not latch properly.
Apex44
Mar 04, 2009 | IBM Computers & Internet
My laptop says a disk red error occurred and will not boot up it goes in circles asking for restarts and says the same thing also iam getting this message as well PXE-E61 MEDIA TEST FAILURE CHECK...
"PXE-E61 MEDIA TEST FAILURE CHECK CABLE"
This means that the motherboard and harddrive are not communicating correctly, there is no data cable to connect the harddrive to the motherboard on a laptop the harddrive connecting plug is soldered directly to the the motherboard.
Either your harddrive is dying, or your motherboard has gone faulty. Laptop repairs are quite involved, if you are not familiar with taking laptops apart I would suggest you get profesional help with this problem.
If you want to have a go yourself I can point you in the direction of websites I use when doing laptop repairs.
Sep 10, 2008 | Computers & Internet
Hi. I have an Acer laptop that is shutting down after 10-15 mins, and when trying to restart comes up with the following message - PXE-E61: Media test failure - check cable. Closely followed by -...
Your Acer is trying to boot from Network and not hard drive.
You will have to go into the set-up utility(BIOS) and de-select network as a boot option.
Jun 14, 2008 | Acer Computers & Internet
Media Test Failure, Check Cable.....
This is an Invalid / Non System Disk error.In your Bios settings change the "First boot device" option to your hard disk.If you have only one hard disk set it to "HDD 0"
Other causes of the problem are:
  1. Floppy or CD that is not bootable is currently in the computer.
  2. Hard disk's power or data cable is not connected properly(loose contact)
Oct 12, 2007 | Acer Aspire L310 (ASL310UD631A) PC...
Computers & Internet Logo
87 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
