Hi, my desktop (MSI - 945GCM478) is not booting ,is always trying to boot when i turn it on but every second turn off and turns on again and dont boot at all !! What could be the problem ?? Thanks
  • 2 more comments
  • RUI MOREIRA
    RUI MOREIRA May 17, 2011
    Hello, i have donne every thing you have told me to , but still the same :(
  • RUI MOREIRA
    well, the problem is ...i cannot have access to nothing , because the pc dont even boot, is always trying to boot but like one second turns off and turns on again and repeat all over again.
  • RUI MOREIRA
    Hello, thanks for the prompt answer, but is like a christmas tree the time between the off and on.
    i have try almost everything ,but i still think the motherboard have some issue, because before, only make this twice, now keeps going all the time
  • RUI MOREIRA
    RUI MOREIRA May 24, 2011
    Thanks, but i have try it and nothing, any way the motherboard needs to be replaced isn it ?
    Thanks
  • 2,574 Answers
Please follow the basic troubleshooting steps found in this guide>>
http://pcsupport.about.com/od/findbysymptom/ht/pconthenoff.htm
PSU maybe the cause of random restarts
Posted on May 17, 2011
  • 1 more comment
  • Reparatii PC - Service IT
    Test the board outside the case in barebone configuration (CPU & one memory module, keyboard, all power connectors), clear CMOS with main A/C power cable removed from PSU and see if that changes anything.
    Please read MSI 945GCM478 Manual carefully. This manual provides details about how to use and to resolve problems.
    click here to Download the manual
    PDF manuals require the Adobe Acrobat Reader for viewing and printing.
    After all the troubelshooting...YES
  • 4,281 Answers
First open the cpu cover then pull cmos cell from motherboard for 10 seconds. Reconnect RAM memory.Processor and it's fan. Reconnect both connection to harddrive change the SATA or IDE cable of harddrive. Remove pci card if any. Let me know if you need further assistance. Thanks for using FixYa.
  • Make sure harddrive is recognized in bios.
    For that when you power up the computer press F1 or F2 or del or ALT+F2 key to enter in bios.
    Then make sure harddrive is recognized.
    If it is recognized then need to repair windows with windows disk.
My MSI AE2220-26SUS 21.5 in computer appears to have wiped out windows 7. I can turn it on but when it starts to boot up, I get enter disc and reboot, is the problem in the bios settings?
Probably your bios settings, check your power and data cables are connected properly, and change them if necesary, if this dont work, boot from a live cd OS or hirens boot to check if there is a hdd with info on it... may be a hdd or win failure too.
Apr 26, 2014 | Computers & Internet
Msi windtop won't turn on
Diouly-dcp's answer
easy..
but only if you will agree to loose all your data,,
plan a
when you turn on your computer press f3 continuously, and reboot your computer(restore or reinstall).
plan b
buy a windows CD,, can be windows 7 or windows 8,,, base on your computer's bit (32 or 64),, buy a CD wich compatible with your computer,which have the windows booting files, and turn on your computer and open the CD pocket and put the CD in your computer, and turn it off,, and turn it on again,, wait.. for a few second, it might say (press any key to boot with CD),, and hit enter it will install the windows that was in the cd. and there you have a new computer.
Nov 05, 2012 | MSI WindTop AE1900-90SUS 19 Desktop PC,...
When i turn on my PC toys CPU and emachines monitor it says disk boot failure enter system disk
hi,
you have two option as follows:
1.when you start PC press F2 enter in BIOS set it to boot from HDD then restart,if this step does not help then number 2
2.reinstal the OS
Sep 26, 2012 | E-Machines eMachines Desktop PC
My tower beeps when i turn it on i have unplugged all the cords, transferred it to another power point and it continues to do this it beeps for 2 seconds and then beeps for 5 seconds and then pauses for a...
Try turning it off from the wall open the case and remove the ram (memory sticks ) from the mother board if there is one stick carefully clean the metal contacts with a new white eraser and reinstall it (if there are two sticks only replace one stick at a time ) if it boots with one stick then this was the problem if it doesnt boot and you have two memory sticks swap them and try again if it boots this time try shuting it back down and replace the second stic if it stops working again remove the faulty stick and replace it with a good one .(make sure you turn the computer of and unplug it every time you remove the memory .
I hope this helps Andrew a
Apr 07, 2011 | Acer Aspire M5100 AM5100-U5313A AMD...
Windows failed to start. A recent hardware or software change might be the cause. file\boot\bcd status 0xc000014c info an error occurred while reading the boot configuration data. I dont have the cd
hi Friend, In this case I would recommend you that as soon as you turn on the system start tapping the key "F8", you will get into the "Advanced Boot Options" menu.
In that list, select the option the last known good configuration and try to restart it. If it happens again then again try the same option for 3 times.
Dec 09, 2010 | Computers & Internet
G31TM-P21 normally boots with series of beeps. Now will not boot properly from CD start sequence (for reinstalling op system) and gives a short beep about every 5 seconds. No information found on MSI...
According to the sequence of beeps your getting from your computer, ther is a possibility that there is a problem with the memory module or RAM on your computer. Try reseating the memory then try to boot up again.
Cheers!!
Sep 02, 2010 | MSI G31TMP21 (890552671946) Motherboard
When I turn on the power, the fans start to turn but then quit after a couple seconds.
hi,
i,d suggest CPU/Memory or motherboard Fault.
try removing 1 stick of memory, then re-boot. ( if theres 2 In )
remove the cpu fan, Check for Dust Blockage, remove CPU. And re-seat-seal-replace Fan. ( re-boot )
remove power from Case ( mains power ) remove side panel, locate CMOS Battery ( Silver coin-Cell ) On motherboard for 10 Seconds, then replace, repower and boot up.
Any of these could resolve your problems.
Mike @ Compurepair.
Nov 03, 2009 | MSI MS-6523 Motherboard
When I turn on my MSI M510C notebook - I get this message "reboot and select proper boot device or insert boot media in selected boot device and press a key" and cannot do anything else. Can someone t
I've read this problem due to new hardware interferences with desktop computers, all they had to do is change a few pins around on the harddrives.. since this is a laptop, and is quite difficult and dodgy to access the hardware, the only other suggestion is to reinstall windows with a recovery disk, or windows CD-ROM.
Hope this helps :)
May 27, 2009 | MSI MEGABOOK M510C Notebook
I was trying to hook up 3 monitors on my dell optiplrx gx620 with a new video card- then i put 2 video card hoping to get 3rd monitor working ---now i dont get any display and alarm sounds when i turn on...
Take out the two last cards you added and boot again.
Then turn it off and insert only one card at the time to find which one is the faulty.
Good Luck!!!
Mar 12, 2009 | IBM NetVista PC Desktop
Motherboard MS 7005 v.1
Hi, i dont have the sound drivers for MS7005V1 and i dont find themany, one can help me.
Thanks
Nov 19, 2008 | MSI K8MM-V Motherboard
Computers & Internet Logo
87 people viewed this question
David Payne
David Payne
