Question about Proform 380 CS Treadmill !
Upon plugging in the incline starts , goes all the way up them back down . Just keeps repeating. How can I stop it?
    Top Expert:
  • Proform Master
  • 12,223 Answers
Watch the videos:
http://www.youtube.com/watch?v=TquYcOzGIw4&feature=related
http://www.youtube.com/watch?v=9G4MZh8JO2Q
http://www.youtube.com/watch?v=M7qJrRbdfBc
http://www.youtube.com/watch?v=MIIxoPtvhy8
hthttp://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
Some equipment has two sections in the board SCR:
Led up +dn. up= up WHEN THE MOTOR UP AND VICE-VERSA.
after that has 2 relais test for open and closes. clean the contact with special spray for clean contact. If the problem persist, the motor or the board is faulty.
Posted on Nov 14, 2011
Why wont my (floor model) nordictrack T9 Ci work? unplugged it and plugged it back in and it keeps going through the start up and then the buttons don't work.
Likely your incline switch is jammed or defective. Could also be that the panel circuit is defective and needs replacing. This panel circuit would need to be removed and tested to pinpoint the exact issue.
Oct 16, 2014 | Nordic Track Nordictrack T9 Ci Treadmill...
What is wrong with and how can I fix the incline on my Nordictrack commercial 1750 treadmill?
This sounds as though the motor is bad, they cost around $130.00, ther is a n electronic controller that controls it, but as it is trying to raise I would think that the switch and controller are functioning. Best of luck and please post back f this helps.
May 25, 2014 | Nordic Track Commercial 1750 Treadmill...
C2250 treadmill incline recalibration - incline goes up, not down
Plug the power out and plug it back in after a count of 50 could be that it needs to be reset .then plug back in the power and see what its doing if no luck go to manual and look for reset
Jan 06, 2014 | Nordic Track Exercise & Fitness
Incline stuck at 12
please follow this steps and fix it. Merry Christmas
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill. ·2
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
·3
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset
Dec 18, 2013 | Nordic Track NordicTrack - E 7.5
Continuous incline with no lights on display except 2 lines on the incline
RUN the software calibration, for easy diagnose, troubleshooting, and fix it.
God bless you
Sep 04, 2012 | Icon Epic T60 Treadmill
Kettler atlantis 51L error!!!! what is the solutions?
I will advice you try re-calibrate your treadmill, follow the procedure below to re-calibrate it,
Step 1 Stand on the side rails of the treadmill for safety purposes. Remove the safety key. Step 2 Press and hold the two incline buttons. The incline buttons are blue and on the left side of the display. Hold the up and down button simultaneously. Release the buttons when the display reads "Calibration."
Step 3 Press the green start button located either above or below the large, red stop button (depending on your model). Stay on the side rails as the treadmill belt begins to move. Both the speed and incline should go through their full range from lowest to highest, and then back down again.
Step 4 Repeat the process if the display does not read "Calibration Successful." Contact the business where you purchased your treadmill if repeating the calibration process does not result in a successful calibration.
Aug 17, 2011 | Exercise & Fitness
Proform 350s crosstrainer treadmill; surges 3 MPH to 4MPH
Walking Belt is Worn: The only certain way to test for a worn walking belt is to take a DC amp draw (if you have a DC treadmill) or an AC draw (for AC). Trying to look at the belt or a feel test is highly unreliable. Better tests, if you lack a DC ammeter (they are expensive for a good one), are a coast test or an incline test. The coast test is to get on the treadmill as the lowest incline setting and walk on the treadmill at 3 MPH. Pull the safety key and it should take you 2-3 full steps to stop (this is a general rule…some like a few Tunturi models stop on a dime even with a healthy belt but for most models, this tests works well upon). Fewer steps indicate high friction. The incline test is to put the treadmill at max incline and walk on it at 3 MPH. If the treadmill operates normally at max incline but bogs down at minimum incline, replace the walking belt. Gravity takes over for the drive system eliminating much of the friction problem. On some heavily worn walking belts, this test will not eliminate the problem. Go to your local hard ware store and purchase silicone spray. Apply Lubricant by lift one side of the running belt spray contents length wise starting at motor shroud to the back end repeat this process on the other side. If this unit bogs down again then you will have replace the running belt and possibly the deck
May 27, 2010 | Proform CrossTrainer Treadmill
When i plug in my weslo 60se treadmill, the incline motor runs up and down and the screen is blank
plug it back in(power cord) insurt key, let the incline go up,then it will go back down on "her" own-do not touch anything, she's teaching herself/going back to school, or they say"calibrating" when she goes back down, it will stop and you will hear a "beep beep" and then your screen will apear,ready to walk-in future IT will do this from time to time, just let her do her thing... a Sears teadmill tech
Jan 05, 2010 | Weslo Cadence 60 SE Treadmill
Proform 550xp Treadmill in continuous incline/decline mode!!!
i just called the manufacturer on this and found out i have a faulty control panel, but these are the steps they told me to go through to reset. If it works, then you are good, if not, you may also have a control panel issue.
1. plug in and turn on treadmill, keep red key out
2. press and hold the stop button and speed up button at the same time and hold them while you insert the red key
3. after red key is inserted, let go of both buttons
**CAUTION - be sure to stand on side bars of treadmill, clear of the belt for this next part bc it will go VERY FAST***
4. press stop button once
5. press speed up button until it reads 85 (see what i mean?!)
6. press stop button once
7. press incline down or up one time and it should get back into normal mode. mine just started a series of flashing lights and "8"s in all the "windows" so my panel needs to be replaced. here is the number i called - 1-877-993-7999. Good Luck!
Dec 30, 2009 | Exercise & Fitness
Incline goes up and down constantly. Console doesn't work
It sounds like it's in calibration mode and you need to let it go all the way up and then down and set itself. If you have done that and it keeps going into that mode then you probably pulled or moved some wiring while moving it.
Sep 15, 2017 | Proform iLog 750 Treadmill
Proform 380 CS Treadmill ! Logo
87 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
