Question about D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge
D-Link 604 4-port
My problem using this router is that everytime I'm trying to make a call using Skype or any other Voip the call would always dropped and also the person on the other line is hearing me clearly while me on the other hand is hearing nothing. But when I'm hooked up directly with my modem everything is smoothly operating. Audio on both side are clear and open.
How would I be able to surpass this problem using this DI-604 so the Audio back and fort would be accessible.
thanks,
craig_14344 of the Phil
    Scholar:
  • 87 Answers
SOURCE:
I need to know if the D link DI 604 Router can be used for a wirless networking
No, is the short answer. It only has the 4 ports which have to be wired with ethernet cables. So this Router is a wired router.
Mar 25, 2011 | D-Link DI-604 4-Port Cable/DSL Router...
My router d-link DI-604 is constantlya unplugging... and disconnecting from internet
Check you have the latest firmware and also check you haven't set idle time out (it should be 0 = always on)
Also see if there are other routers in the vicinity especially n-routers which will knock it offline so you should change the channels.
Aug 29, 2010 | D-Link DI-604 4-Port Cable/DSL Router...
Cant connect the d-link website after ip replacement.
Have you tried to reset your router? If not, do so. It will reset everything to factory default.
To reset, look for a hole near the ports, where it says RESET. Use a pointed object such as a paper clip.
Hope it helps.
Aug 24, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
D LINK DI 604 KEEPS KICKING ME OFF
are any lights going off or flashing on mdm ? then call isp . . when was the last time you pwr cyc mdm AND router if it has been awhile try that turn both off for for 3 to 5 min turn mdm on first wait for dsl light wait 2 min turn router on wait 2 min try again if still have problems connect direct to mdm and if still doing it it isn't the router it is the internet connection or mdm
Apr 07, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Switched internet service providers now the router doesn't work
You might want to check the routers settings to make sure that it is not configured to use PPOE connection which is for DSl and the Broadband connection. You can find the routers address by searching google. Linksys uses 192.168.1.1. You can always try resetting the router by pushing the reset button usually found by the power plug in the back.
Feb 19, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Router configuration cant be accesed
Set your computer's IP address to be 192.168.0.10 then try again.
Oct 30, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
D-LINK DI-604 STATIC IP
Log into the router and go to the configuration page for your WAN port. Change the connection type to static ip.
Apr 02, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
D-Link DI-604 Router can be use in Wireless Broadband?
You can use any wireless access point. If you would like to stay with Dlink, you could try the DWL-2100AP. You would just need to plug it in to an open port on your router.
Dec 28, 2007 | D-Link DI-604 4-Port Cable/DSL Router...
Open Questions:
See all D-Link DI-604 4-Port Cable/DSL Router (DI-604) Questions
D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge Logo
696 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
